    Getting Range finder information in ROS and more.
    ROS
    • J
      Judoor 0
      I'd like to get the range finder data in ROS, right now it doesn't appear in mpa_to_ros, what should I change for it to appear?
      I cannot get it from MAVROS either, the distance_sensor doesn't appear in my topics. But it appears on GQC and i've got the right value.
      Is it cause I set it up wrong in voxl-px4.conf (right now the value is NONE).
      Also, how can i get an idea of when the VIO / OV start to fail so I can activate a failsafe in my ROS Node?
      Setup : Starling 2 max, dual cam, with TOF
      Have a good day
      Julien
      • J
        Judoor 0 @Judoor 0
        @Judoor-0 For the rangefinder part i've looked into the mpa_to_ros code and modified it to add rangefinder_data_t and republished it in a ros_topic.
        But for the covariance/error of the vio I still have no clue how to get it
        Julien
        J T 2 Replies Last reply Reply Quote 0
        • J
          Judoor 0 @Judoor 0
          @Alex-Kushleyev I don't know who can help me on this one, I tried to modify the mpa_to_ros package and I think I did it successfully (adding range-sensor and some vins status). How can I share it, so someone from your team can verify it and then if it's good enough put it on the gitlab ?
          Julien
          • T
            teddy.zaremba @Judoor 0
            Hi @Judoor-0,
            Interesting I'm assuming you're looking at the rangefinders pipe. I can take a look at your code, or you can make a MR back into mpa-to-ros2.
            Also, something to consider is using microdds and subscribing to the "fmu/in/obstacle_distance" topic.
            • J
              Judoor 0 @teddy.zaremba
              @teddy-zaremba Hi teddy,
              I'm on ROS 1 so it's just MPA_TO_ROS and not MPA_TO_ROS2.
              Yes I looked at the rangefinder pipes and did get the rangefinder data and republished_it in ROS and same with the ov_status.
              I don't have access to microdds in ROS1 unless I do a ROS2 to ROS1 bridge.
              Julien
              T 1 Reply Last reply Reply Quote 0
              • T
                Hi @Judoor-0,
                Cool! Feel free to make a MR or post the link to your code if you want someone to review it.
