  2. Software Development
  3. ROS
  4. Getting Range finder information in ROS and more.
Scheduled Pinned Locked Moved ROS
6 Posts 2 Posters 3.4k Views
  • J Offline
    J Offline
    Judoor 0
    I'd like to get the range finder data in ROS, right now it doesn't appear in mpa_to_ros, what should I change for it to appear?
    I cannot get it from MAVROS either, the distance_sensor doesn't appear in my topics. But it appears on GQC and i've got the right value.
    Is it cause I set it up wrong in voxl-px4.conf (right now the value is NONE).
    Also, how can i get an idea of when the VIO / OV start to fail so I can activate a failsafe in my ROS Node?
    Setup : Starling 2 max, dual cam, with TOF
    Have a good day
    Julien
    J 1 Reply Last reply
    • J Judoor 0
      Have a good day
      Julien
      J Offline
      J Offline
      Judoor 0
      @Judoor-0 For the rangefinder part i've looked into the mpa_to_ros code and modified it to add rangefinder_data_t and republished it in a ros_topic.
      But for the covariance/error of the vio I still have no clue how to get it
      Julien
      J T 2 Replies Last reply
      • J Judoor 0
        Julien
        J Offline
        J Offline
        Judoor 0
        @Alex-Kushleyev I don't know who can help me on this one, I tried to modify the mpa_to_ros package and I think I did it successfully (adding range-sensor and some vins status). How can I share it, so someone from your team can verify it and then if it's good enough put it on the gitlab ?
        Julien
        • J Judoor 0
          Julien
          T Offline
          T Offline
          teddy.zaremba
          Hi @Judoor-0,
          Interesting I'm assuming you're looking at the rangefinders pipe. I can take a look at your code, or you can make a MR back into mpa-to-ros2.
          Also, something to consider is using microdds and subscribing to the "fmu/in/obstacle_distance" topic.
          • T teddy.zaremba
            Hi @Judoor-0,
            J Offline
            J Offline
            Judoor 0
            @teddy-zaremba Hi teddy,
            I'm on ROS 1 so it's just MPA_TO_ROS and not MPA_TO_ROS2.
            Yes I looked at the rangefinder pipes and did get the rangefinder data and republished_it in ROS and same with the ov_status.
            I don't have access to microdds in ROS1 unless I do a ROS2 to ROS1 bridge.
            Julien
            T 1 Reply Last reply
            • J Judoor 0
              Julien
              T Offline
              T Offline
              teddy.zaremba
              Hi @Judoor-0,
              Cool! Feel free to make a MR or post the link to your code if you want someone to review it.
