  3. Dual FLIR Lepton thermal cameras with VOXL2 Mini and Sparrow
5 Posts 2 Posters 928 Views 1 Watching
  • K Offline
    K Offline
    KLindgren
    I have the 2 Leptons connected according to the image+pinout in this page but I have not found any guidance on software changes to enable use of the second Lepton (e.g., changes to /etc/modalai/voxl-lepton-server.conf). Does the Lepton Server support 2 cameras? I see the shutter of the second Lepton cycling for FFC at the same time as the first Lepton so it appears to be operating properly. Running the Lepton server only shows the first camera's config loaded and executed.
    • J Offline
      jared
      So far we've updated https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/m0104/m0104-modalai-qupv3.dtsi and added an alias back to https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/m0104/m0104-kona.dtsi as described below and rebuilt the kernel. We see spidev14.0 but only get "Waiting for first frame" message when trying to run voxl-lepton-server from SPI device 14.
      Any ideas? So far we're completely stuck.
      Changes to https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/m0104/m0104-modalai-qupv3.dts:
      /* M0104 - J10 - GPIO 40-44 */
      &qupv3_se14_spi {
              status = "ok";
              spidev@0 {
                      compatible = "spidev";
                      reg = <0>;
                      spi-max-frequency = <50000000>;
      /* M0104 - J10 JST connector */
      &qupv3_se14_2uart {
              status = "disabled";
      Changes to https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/m0104/m0104-kona.dtsi:
      spi14 = &qupv3_se14_spi;
      J 1 Reply Last reply
      • J jared
        &qupv3_se14_spi {
                status = "ok";
                spidev@0 {
                        reg = <0>;
        &qupv3_se14_2uart {
        jared
        wrote on last edited by jared
        Any ideas @Vinny or @Alex-Kushleyev ? This is unfortunately a pretty big blocker for us.
        /dev/spidev14.0 exists but isn't working. Regardless of whether we have the lepton plugged or unplugged from J5 on the m0188, voxl-lepton-server(and even dd) just hangs when we try to read from spi 14.0. And this is after we set 67 high (voxl-gpio -w 67 1). See below for dd outputs from spidev0.0 compared to spidev14.0.
        Lepton unplugged
        voxl2-mini:/$ dd if=/dev/spidev0.0 bs=164 count=1 | hexdump -C
        1+0 records in
        1+0 records out
        164 bytes copied, 0.00235198 s, 69.7 kB/s
        00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
        000000a4
        Lepton plugged into m0188 J10
        1+0 records in
        1+0 records out
        164 bytes copied, 0.00223693 s, 73.3 kB/s
        00000000 07 ff ff ff 80 00 00 00 00 00 00 00 00 00 00 00 |................|
        00000010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 e6 |................|
        00000020 a7 42 38 4c 4e 04 00 01 00 00 00 00 00 00 00 00 |.B8LN...........|
        00000030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
        000000a4
        Lepton unplugged
        voxl2-mini:/$ dd if=/dev/spidev14.0 bs=164 count=1 | hexdump -C
        (Just hangs)
        Lepton plugged into m0188 J5
        (Just hangs)
        • J jared
          Lepton unplugged
          1+0 records in
          1+0 records out
          000000a4
          1+0 records in
          1+0 records out
          000000a4
          Lepton unplugged
          (Just hangs)
          (Just hangs)
          jared
          Ok looks like it was partially a TrustZone issue. I'm now using the .mbn from sdk 1.0.0 and I can at least read from spidev14.0. But still no dice to actually get the camera to read actual data.
          This is the correct pinout from the M0104 J10 to the M0188 J4, yes?
          What I'm getting now:
          1+0 records in
          1+0 records out
          164 bytes copied, 0.0010337 s, 159 kB/s
          000000a4
          • J jared
            1+0 records in
            1+0 records out
            000000a4
            jared
            No new progress in the last few days. Do you have any idea what the issue might be @Alex-Kushleyev ?
