  3. unable to build voxl-tflite-server in voxl-cross
3 Posts 2 Posters 678 Views 1 Watching
  • P Offline
    P Offline
    paul.foley
    wrote on last edited by paul.foley
    I'm trying to build voxl-tflite-server in voxl cross. Below is my setup:
    • voxl-cross:V4.0
    • voxl-tflite-server
      • cloned repo at this commit https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tflite-server/-/commit/adbed8cd3fc7c08956a1a1e0759f344bc0285054
    Host system:
    • OS: Red Hat Enterprise Linux 9.6 (Plow)
    • Docker:
    docker version
    Client: Docker Engine - Community
    Version: 28.3.1
    API version: 1.51
    Go version: go1.24.4
    Git commit: 38b7060
    Built: Wed Jul 2 20:58:10 2025
    OS/Arch: linux/amd64
    Context: default
    Server: Docker Engine - Community
    Engine:
    Version: 28.3.1
    API version: 1.51 (minimum version 1.24)
    Git commit: 5beb93d
    Built: Wed Jul 2 20:56:24 2025
    Experimental: false
    containerd:
    Version: 1.7.27
    GitCommit: 05044ec0a9a75232cad458027ca83437aae3f4da
    runc:
    Version: 1.2.5
    GitCommit: v1.2.5-0-g59923ef
    docker-init:
    Version: 0.19.0
    GitCommit: de40ad0
    I followed the instructions in voxl-tflite-server/README.md. I'm able to launch voxl-cross with the voxl-tflite-server repo directory mounted in the container. I ran the following command and got the following results.
    /home/root# ./install_build_deps.sh qrb5165 dev
    using qrb5165 dev debian repo
    Ign:1 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ InRelease
    Ign:2 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Release
    Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ Packages [25.4 kB]
    Fetched 25.4 kB in 1s (46.8 kB/s)
    Reading package lists... Done
    installing:
    libmodal-pipe
    libmodal-json
    voxl-opencv
    qrb5165-tflite
    Building dependency tree
    The following NEW packages will be installed:
      libmodal-json:arm64 libmodal-pipe:arm64 qrb5165-tflite:arm64 voxl-opencv:arm64
    0 upgraded, 4 newly installed, 0 to remove and 2 not upgraded.
    Need to get 24.8 MB of archives.
    After this operation, 0 B of additional disk space will be used.
    Get:1 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libmodal-json 0.4.7-202505011742 [46.9 kB]
    Get:2 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ libmodal-pipe 2.13.4-202507031002 [118 kB]
    Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ qrb5165-tflite 2.8.0-2-202210071637 [11.0 MB]
    Get:4 http://voxl-packages.modalai.com ./dists/qrb5165/dev/binary-arm64/ voxl-opencv 4.5.5-3-202504301748 [13.6 MB]
    Fetched 24.8 MB in 4s (6792 kB/s)
    debconf: unable to initialize frontend: Dialog
    debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 4.)
    debconf: falling back to frontend: Readline
    Selecting previously unselected package libmodal-json:arm64.
    (Reading database ... 31293 files and directories currently installed.)
    Preparing to unpack .../libmodal-json_0.4.7-202505011742_arm64.deb ...
    Unpacking libmodal-json:arm64 (0.4.7-202505011742) ...
    Selecting previously unselected package libmodal-pipe:arm64.
    Preparing to unpack .../libmodal-pipe_2.13.4-202507031002_arm64.deb ...
    Unpacking libmodal-pipe:arm64 (2.13.4-202507031002) ...
    Selecting previously unselected package qrb5165-tflite:arm64.
    Preparing to unpack .../qrb5165-tflite_2.8.0-2-202210071637_arm64.deb ...
    Unpacking qrb5165-tflite:arm64 (2.8.0-2-202210071637) ...
    Selecting previously unselected package voxl-opencv:arm64.
    Preparing to unpack .../voxl-opencv_4.5.5-3-202504301748_arm64.deb ...
    Unpacking voxl-opencv:arm64 (4.5.5-3-202504301748) ...
    Setting up libmodal-json:arm64 (0.4.7-202505011742) ...
    Setting up qrb5165-tflite:arm64 (2.8.0-2-202210071637) ...
    Setting up voxl-opencv:arm64 (4.5.5-3-202504301748) ...
    Setting up libmodal-pipe:arm64 (2.13.4-202507031002) ...
    Processing triggers for libc-bin (2.31-0ubuntu9.17) ...
    Done installing dependencies
    Installing dependencies seems to complete successfully. Trying to build results in the following.
    /home/root# ./build.sh qrb5165
    CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
      Compatibility with CMake < 3.10 will be removed from a future version of
      CMake.
      Update the VERSION argument <min> value or use a ...<max> suffix to tell
      CMake that the project does not need compatibility with older versions.
    WARN you're using a deprecated toolchain, please use the new toolchains:
    WARN qrb5165_ubun1_18.04_aarch64.toolchain.cmake
    WARN qrb5165_ubun2_20.04_aarch64.toolchain.cmake
    -- Using voxl-cross 64-bit toolchain for QRB5165 ubun1 18.04
    -- C Compiler     : /usr/bin/aarch64-linux-gnu-gcc-10
    -- C++ Compiler   : /usr/bin/aarch64-linux-gnu-g++-10
    -- Sysroot        : /opt/sysroots/qrb5165_1
    -- C flags        : -idirafter /usr/include -march=armv8.2-a
    -- CXX flags      : -idirafter /usr/include -march=armv8.2-a
    -- EXE Link Flags : -L/opt/sysroots/qrb5165_1/usr/lib/aarch64-linux-gnu -L/opt/sysroots/qrb5165_1/lib -L/opt/sysroots/qrb5165_1/usr/lib -L/usr/lib64 -L/usr/lib
    -- SO Link Flags  : -L/opt/sysroots/qrb5165_1/usr/lib/aarch64-linux-gnu -L/opt/sysroots/qrb5165_1/lib -L/opt/sysroots/qrb5165_1/usr/lib -L/usr/lib64 -L/usr/lib
    -- The C compiler identification is GNU 10.5.0
    -- The CXX compiler identification is GNU 10.5.0
    -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-10 - skipped
    -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-10 - skipped
    CMake Deprecation Warning at src/CMakeLists.txt:1 (cmake_minimum_required):
      CMake.
    -- Configuring done (1.2s)
    -- Generating done (0.1s)
    -- Build files have been written to: /home/root/build
    [  6%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/config_file.cpp.o
    In file included from /home/root/src/config_file.cpp:1:
    /home/root/src/../include/config_file.h:37:10: fatal error: modal_json.h: No such file or directory
       37 | #include <modal_json.h>
    compilation terminated.
    make[2]: *** [src/CMakeFiles/voxl-tflite-server.dir/build.make:79: src/CMakeFiles/voxl-tflite-server.dir/config_file.cpp.o] Error 1
    make[1]: *** [CMakeFiles/Makefile2:106: src/CMakeFiles/voxl-tflite-server.dir/all] Error 2
    make: *** [Makefile:136: all] Error 2
    Based on the warning about the deprecated toolchain, I updated TOOLCHAIN_QRB5165 in build.sh
    TOOLCHAIN_QRB5165="/opt/cross_toolchain/qrb5165_ubun1_18.04_aarch64.toolchain.cmake"
    I also tried
    TOOLCHAIN_QRB5165="/opt/cross_toolchain/qrb5165_ubun2_20.04_aarch64.toolchain.cmake"
    That got rid of the warnings but I still got the error about
    I verified that modal_json.h is in /usr/include
    /home/root# ls -l  /usr/include/modal_json.h
    -rw-r--r--. 1 root root 15619 May  2 00:42 /usr/include/modal_json.h
    I modified voxl-tflite-server/src/CMakeLists.txt to explicitly include /usr/include but that didn't help.
    include_directories(
        /usr/include/
        ../include/
        ..include/model_helper/
    I then created /tmp/include as a softlink to /usr/include
    root@artb-vm9-dev11:/tmp# ls -l
    total 0
    drwxr-xr-x. 2 root root  6 Jul  8 20:16 bionic-pkgs
    lrwxrwxrwx. 1 root root 13 Jul  9 00:17 include -> /usr/include/
    I modified voxl-tflite-server/src/CMakeLists.txt to explicitly include /tmp/include and that fixed the compilation error and everything compiled. .
        /tmp/include/
        ../include/
    However, then it failed when linking.
    [ 73%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/model_helper/yolov5_model_helper.cpp.o
    [ 80%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/model_helper/yolov8_model_helper.cpp.o
    [ 86%] Building C object src/CMakeFiles/voxl-tflite-server.dir/resize.c.o
    [ 93%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/utils.cpp.o
    [100%] Linking CXX executable voxl-tflite-server
    /usr/lib/gcc-cross/aarch64-linux-gnu/10/../../../../aarch64-linux-gnu/bin/ld: cannot find -lsync
    collect2: error: ld returned 1 exit status
    make[2]: *** [src/CMakeFiles/voxl-tflite-server.dir/build.make:308: src/voxl-tflite-server] Error 1
    I could try installing the missing sync library but based on the prior issues I encountered it seems like maybe I need to use different versions of voxl-cross and voxl-tflite-server. Ultimately I'm targeting a Starling 2 Max. Here is the configuration for that:
    voxl2:/$ voxl-version
    kernel:       #1 SMP PREEMPT Mon Nov 11 22:59:41 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.2.1
    voxl-suite:   1.4.1
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
    Last Updated: 2023-03-02 12:58:40
    List:
    libmodal-cv                               0.5.16
    libmodal-exposure                         0.1.3
    libmodal-pipe                             2.10.6
    libqrb5165-io                             0.4.9
    libvoxl-cci-direct                        0.2.5
    modalai-slpi                              1.1.19
    qrb5165-imu-server                        1.1.2
    qrb5165-rangefinder-server                0.1.4
    qrb5165-system-tweaks                     0.3.4
    voxl-camera-calibration                   0.5.9
    voxl-camera-server                        2.1.1
    voxl-configurator                         0.9.7
    voxl-cpu-monitor                          0.5.3
    voxl-elrs                                 0.4.1
    voxl-esc                                  1.5.1
    voxl-feature-tracker                      0.5.2
    voxl-io-server                            0.0.4
    voxl-lepton-server                        1.3.3
    voxl-lepton-tracker                       0.0.4
    voxl-logger                               0.4.9
    voxl-mavcam-manager                       0.5.7
    voxl-mavlink-server                       1.4.4
    voxl-modem                                1.1.5
    voxl-mpa-tools                            1.3.7
    voxl-open-vins                            0.4.16
    voxl-open-vins-server                     0.3.0
    voxl-opencv                               4.5.5-2
    voxl-osd                                  0.1.1
    voxl-portal                               0.7.5
    voxl-px4                                  1.14.0-2.0.94
    voxl-px4-params                           0.6.3
    voxl-qvio-server                          1.1.1
    voxl-reset-slpi                           0.0.1
    voxl-state-estimator                      0.0.4
    voxl-streamer                             0.7.5
    voxl-suite                                1.4.1
    voxl-tflite-server                        0.3.9
    voxl-utils                                1.4.4
    voxl-vision-hub                           1.8.17
    voxl-vtx                                  1.1.8
    voxl2-system-image                        1.8.02-r0
    Any guidance would be greatly appreciated.
    Thank you,
    Paul
    • P paul.foley
      • voxl-cross:V4.0
      Host system:
      • Docker:
      docker version
      Version: 28.3.1
      API version: 1.51
      Git commit: 38b7060
      Context: default
      Engine:
      Version: 28.3.1
      Git commit: 5beb93d
      Experimental: false
      containerd:
      Version: 1.7.27
      runc:
      Version: 1.2.5
      docker-init:
      Version: 0.19.0
      GitCommit: de40ad0
      installing:
      libmodal-pipe
      libmodal-json
      voxl-opencv
      qrb5165-tflite
        CMake.
        CMake.
      I also tried
          /usr/include/
          ../include/
      total 0
          /tmp/include/
          ../include/
      hw platform:  M0054
      mach.var:     1.2.1
      voxl-suite:   1.4.1
      Packages:
      List:
      libmodal-cv                               0.5.16
      libqrb5165-io                             0.4.9
      modalai-slpi                              1.1.19
      voxl-elrs                                 0.4.1
      voxl-esc                                  1.5.1
      voxl-logger                               0.4.9
      voxl-modem                                1.1.5
      voxl-opencv                               4.5.5-2
      voxl-osd                                  0.1.1
      voxl-portal                               0.7.5
      voxl-streamer                             0.7.5
      voxl-suite                                1.4.1
      voxl-utils                                1.4.4
      voxl-vtx                                  1.1.8
      Thank you,
      Paul
      @paul-foley See here: https://forum.modalai.com/post/22907
      P 1 Reply Last reply
        P Offline
        P Offline
        paul.foley
        @tom that worked, thank you!
