  3. updating M0065
updating M0065
Scheduled Pinned Locked Moved ESCs, Sensors and Accessories
2 Posts 2 Posters 1.7k Views 1 Watching
  • ModeratorM Offline
    I’m setting up a delta-wing platform with the VOXL2 and using the VOXL2 IO board (M0065). I followed the instructions provided here to update the firmware.
    However, I couldn’t locate the m0065_firmware.bin file mentioned in the instructions on the public downloads site. Instead, I used the voxl2_io_firmware_m0065_v1_35_58c82813.bin file. I later realized that this firmware is only compatible with VOXL2 SDK v1.1.1, while I’m currently using SDK v1.4.1. I don't see any other firmware file for the m0065.
    Could you please advise how I should proceed to reflash the IO board with the correct firmware version compatible with SDK v1.4.1?
    I appreciate any guidance you can provide.
    • ModeratorM Moderator
      The latest firmware for M0065 can be found on gitlab here
      or directly on voxl2 in /usr/share/modalai/voxl2-io-tools/firmware/
      Once updated, the firmware will be detected as version 2. The previous version 1 is no longer supported due to several bugs.
