  3. Playing with VFC
Playing with VFC
4 Posts 2 Posters 839 Views 1 Watching
  • Aaron PorterA Offline
    Aaron Porter
    I am playing around with VFC on one of the Starlings 1. I am able to takeoff in altitude mode and change over to Offboard mode. I thought that changing to offboard mode from altitude would cause the drone to go into VFC_Altitude mode however, I get a message in QGC that the mode is VFC_Manual and feels similar to manual mode as well. Not sure if I am missing something? Am I wrong in thinking that it should be in VFC_Altitude?
    I am using a joystick controller instead of an RC controller.
    Thank you for your time,
    Aaron Porter
    • Aaron PorterA Aaron Porter
      Aaron Porter
      @Aaron-Porter The VFC flight mode that will be entered when switching into offboard is dependant on what is specified in /etc/modalai/voxl-vision-hub.conf
      Example here:
      "vfc_submode_ch":	6,
      	"vfc_alt_mode_rc_min":	0,
      	"vfc_alt_mode_rc_max":	0,
      	"vfc_flow_mode_rc_min":	1700,
      	"vfc_flow_mode_rc_max":	2100,
      	"vfc_hybrid_flow_mode_rc_min":	0,
      	"vfc_hybrid_flow_mode_rc_max":	0,
      	"vfc_position_mode_rc_min":	1300,
      	"vfc_position_mode_rc_max":	1700,
      	"vfc_traj_mode_rc_min":	0,
      	"vfc_traj_mode_rc_max":	0,
      In this example, VFC flight modes are monitored on channel 6
      Depending on what position the switch is in, a different VFC mode will be entered
      So for example, if the middle position of flight modes is set to "Offboard", when the switch is flipped into the middle position ~1500, VFC position mode will be entered
        Aaron Porter
        Thank you, I was playing around with it.
        Seems like for the controller it is a bit difficult since all main the buttons on the Xbox controller are mapped to the same channels. But at least then are set to different values.
          Aaron Porter
          So something that I was seeing while testing this was having a bit of instability with Open VINS flying and altitude flying (Not Using VFC). I was seeing that voxl-open-vins-server stated that the IMU temperature was too high and kept resetting. After letting the VOXL2 cool down for a day I was able to have the Drone Fly in VFC mode but not sure how it flew compared to Position mode using VIO.
