  3. AR0144 RGB output on VOXL2
image-sensor
41 Posts 3 Posters 22.7k Views 2 Watching
    OK, I was able to confirm this configuration:
    • VOXL2
    • M0173 + 3x AR0144 + 1x IMX412 (C27 config)
    • M0155 + 1x AR0144 plugged into J8
      • AR0144 i2c slave id change via resistor
      • small camera driver modification for new slave id
    • also verified the synchronization between the 4 AR0144
    The resistor swap was relatively easy, but i used a special "tweezer" soldering iron tip. I can be difficult without the right tools.. Let me check if we can do a swap for the custom order..
    See the image with marked slave id select resistor that needs to move to a pad right above the current placement. It can be a bit tricky to do it 🙂
    Here are two image samples taking using IMX412 and AR0144. IMX412 is slightly cropped on the sides, but it's also a slightly narrower lens. AR0144 image is without LSC correction. Also images slightly out of focus because the test pattern is very close to the camera. The brightness in the IMX412 image is more evenly distributed (larger, better lens), so the center of the image is not over-exposed, unlike the AR0144. This should be corrected with the proper LSC..
    IMX412
    AR0144-color
    J 1 Reply Last reply
      IMX412
      AR0144-color
      Jordyn Heil
      @Alex-Kushleyev, I just got the color AR0144s and was wondering what changes I need to make to the config file to get the RGB output from the AR0144s. I chose configuration 27, but when I open the stream in the VOXL web portal, I only get monochrome streams from the AR0144.
      • J Jordyn Heil
        #23
        @Jordyn-Heil , you will need to use a recent version of voxl-camera-server (you can build it from dev or get a package from the nightly builds).
        Then edit the camera server config file (/etc/modalai/voxl-camera-server.conf) and replace the camera type ar0144 with ar0144-color. If you get an error (unknown camera type), it means you are using older version of camera server.
        Currently, the debayering is happening on the CPU.
        Here is the place where processing is happening for the color version of AR0144. https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/dev/src/hal3_camera_mgr.cpp?ref_type=heads#L1477
        • debayer from GRBG to RGB
        • run AWB (auto white balance)
        • run AE (auto exposure)
        • send out RGB, grey, and original raw bayer frames
        Please try it out.
          Please try it out.
          Jordyn Heil
          @Alex-Kushleyev, building from the dev branch worked great, thanks!
          On a separate note, for my application, I will need the coax cables connecting the cameras to be slightly longer. Do you all make longer cables, or are you aware of any other suppliers that make longer versions of these cables?
          • J Jordyn Heil
            @Jordyn-Heil , yes we make cables from 35 to 180mm : https://www.modalai.com/products/mcbl-00084
            If you are purchasing new cameras and need a non-standard cable length (I believe standard is 80mm), you may need to contact us by email for a custom order.
              • VOXL2
              Jordyn Heil
              @Alex-Kushleyev, I recently got the M0173, so I can finally test all cameras running concurrently. I made the resistor swap for the AR0144 plugged into J8, but could you walk me through the camera driver modification I need to make for the new slave id?
              I have voxl-camera-server v2.2.4 of the dev build, but I am only able to view my streams in color (through the VOXL Web Portal) when I set misp_venc_enable to false in the configuration file. Otherwise, I get errors for each AR0144 camera that say the following:
              "MISP Initializing for camera tracking_front
              Got unsupported format in getUVStartFromFmt, returning nullptr"
              Also, I am unable to view the IMX412 stream when it is connected to the M0173 in the C27 config. What additional modifications need to be made to solve these issues?
              • J Jordyn Heil
                #27
                @Jordyn-Heil ,
                Please use the sensormodule driver for the specific camera slot (which has been updated to use alternate slave address 0x20 instead of default 0x30 via the resistor change): https://storage.googleapis.com/modalai_public/temp/ar0144/ar0144_drivers_alt_slave_addr_0x20_20250709.zip
                In my test with 4 AR0144, i connected the standard C27 configuration, and added the 4th AR0144 like so:
                So the 4th AR0144 camera will have the camera Slot 4,
                If you tell me where exactly you are plugging in all the cameras, i can help with figuring out which slot IDs each camera has.
                Regarding the following error, "Got unsupported format in getUVStartFromFmt, returning nullptr", i think it should be ok. Does the camera server exit in this case? it should not exit. I just tried it (to enable misp venc) and it still provides the color stream (although the h264/h265 stream is does not get published, since this specific processing pipeline is not set up for that).
                For using M0173, did you set up your kernel for 1.0.1 variant? I assume so, otherwise, voxl-configure-cameras would not let you select C27? Please confirm. Do you have the cameras connected in the same way as shown in the C27 diagram? https://docs.modalai.com/voxl2-coax-camera-bundles/#mdk-m0173-1-02 . It is possible that because one of the cameras is missing (not detected) because you swapped the resistor for alternate i2c id, then the camera ID for hires is wrong in the voxl_camera_server.conf.
                Here are all the sensormodules that i have for this setup in /usr/lib/camera/ (assuming the modified AR0144 is connected to J8, so slot 4.
                com.qti.sensormodule.ar0144_combo_0.bin
                com.qti.sensormodule.ar0144_combo_6.bin
                com.qti.sensormodule.ar0144_fsin_0x20_4.bin
                com.qti.sensormodule.ar0144_fsin_2.bin
                com.qti.sensormodule.imx412_fpv_1.bin
                com.qti.sensormodule.irs2975c_3.bin
                voxl-camera-server -l shows (four AR0144 visible with sensor ID 0x0356) and the corresponding slot IDs and camera IDs:
                DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0030, Sensor Id: 0x0356
                DEBUG:   Cam idx: 1, Cam slot: 1, Slave Address: 0x0034, Sensor Id: 0x0577
                DEBUG:   Cam idx: 2, Cam slot: 2, Slave Address: 0x0030, Sensor Id: 0x0356
                DEBUG:   Cam idx: 3, Cam slot: 3, Slave Address: 0x007A, Sensor Id: 0x2975
                DEBUG:   Cam idx: 4, Cam slot: 4, Slave Address: 0x0020, Sensor Id: 0x0356
                DEBUG:   Cam idx: 5, Cam slot: 6, Slave Address: 0x0030, Sensor Id: 0x0356
                The 4th AR0144 will actually be in slot 4, so it will bump the other AR0144 in slot 6 from being cam id 4 to cam id 5. Slot 6 is the AR0144 that is standard in the C27 config.
                Please double check everything step by step and let me know if something is still not working.
                J 2 Replies Last reply
                  @Jordyn-Heil ,
                  Jordyn Heil
                  @Alex-Kushleyev, I am still unable to see anything from the IMX412 or the extra AR0144 that has the new slave address of 0x20.
                  I have the 0x30 address AR0144s and the IMX412 connected exactly as shown in this photo (minus the TOF sensor).
                  The additional AR0144 with the resistor change is connected to J8 via the M0155.
                  I downloaded the given sensormodule drivers, and this is my setup in /usr/lib/camera/:
                  com.qti.tuned.cmk_imx577.bin
                  com.qti.tuned.cmk_ov9282.bin
                  com.qti.tuned.default.bin
                  com.qti.tuned.imx412_fpv.bin
                  com.qti.tuned.ov9782.bin
                  com.qti.tuned.sony_imx335.bin
                  I am on kernel variant 1.01, and when I select C27, the only things I change are "type" (switch from ar0144 to ar0144-color), misp_venc_enable (set false), delete the entry for the TOF sensor, and add an identical entry for the additional ar0144-color but with "camera_id" = 5.
                  When I run voxl-camera-server -l, I am not able to see the DEBUG: lines. This is my output:
                  Number of cameras detected: 5
                    @Jordyn-Heil ,
                    Jordyn Heil
                    @Alex-Kushleyev, I've done some more digging, and I think I found the issue.
                    I have confirmed that all 5 cameras are seen properly and stream to the Voxl Web Portal when I disable venc on all cameras and just enable preview.
                    DEBUG:   Cam idx: 3, Cam slot: 4, Slave Address: 0x0020, Sensor Id: 0x0356
                    DEBUG:   Cam idx: 4, Cam slot: 6, Slave Address: 0x0030, Sensor Id: 0x0356
                    However, when I enable venc, I get this error:
                    DEBUG:   Buffer Count Expected: 16
                    DEBUG:   Buffer Count Actual: 16
                    DEBUG:   Port Def 0:
                    	Count Min: 8
                    	Count Actual: 16
                    	Buffers Contiguous: Yes
                    	Buffer Alignment: 0
                    DEBUG:   Port Def 1:
                    	Count Min: 4
                    	Count Actual: 16
                    	Buffers Contiguous: No
                    	Buffer Alignment: 0
                    DEBUG:   OMX_EventCmdComplete
                    WARNING: Encoder expecting(16) more buffers than module allocated(1)
                    ERROR:   OMX Set config failed!
                    ERROR:   Failed to initialize encoder for camera: hires
                    ERROR:   Failed to start camera: hires
                    My Voxl is running the most recent voxl-camera-server dev branch, and in hal3_camera_mgr.cpp, the following are all defined:
                    #define NUM_PREVIEW_BUFFERS  16 // used to be 32, really shouldnt need to be more than 7
                    #define NUM_SNAPSHOT_BUFFERS 16 // used to be 8, just making it consistent with the rest that are now 16
                    #define NUM_MISP_BUFFERS     16
                    #define NUM_STREAM_BUFFERS   16 // shouldn't need more than 10, if the buffer pool is empty then OMX should be dropping more frames
                    #define NUM_RECORD_BUFFERS   16 // shouldn't need more than 10, if the buffer pool is empty then OMX should be dropping more frames
                    All of these are set to 16, so why is my Voxl saying that it doesn't have 16 buffers available? It's also not competing for resources since I tested this out with just one camera having venc enabled.
                    • J Jordyn Heil
                      DEBUG:   Port Def 0:
                      	Count Min: 8
                      	Count Actual: 16
                      	Buffer Alignment: 0
                      DEBUG:   Port Def 1:
                      	Count Min: 4
                      	Count Actual: 16
                      	Buffer Alignment: 0
                      Jordyn Heil
                      wrote on last edited by Jordyn Heil
                      #30
                      After adding in some extra debug statements in the voxl-camera-server codebase, these are my findings:
                      The mpa_ion_buf_pool_alloc_bufs function is allocating 16 buffers but only properly initializing 1 buffer out of 16. The remaining 15 buffers contain corrupted or invalid data, as evidenced by the debug output showing mostly NULL pointers, invalid file descriptors, and bad memory addresses.
                      [DEBUG] Buffer[0]: vaddress=0x5588128d50, fd=-2010712080, size=85, width=85, height=-2013126160, stride=85, slice=-2011714000
                      [DEBUG] Buffer[1]: vaddress=(nil), fd=-1, size=0, width=0, height=0, stride=0, slice=0
                      [DEBUG] Buffer[2]: vaddress=(nil), fd=-1, size=0, width=0, height=0, stride=0, slice=0
                      [DEBUG] Buffer[3]: vaddress=(nil), fd=-1, size=0, width=127, height=-2044747776, stride=127, slice=0
                      [DEBUG] Buffer[4]: vaddress=(nil), fd=800, size=127, width=127, height=0, stride=0, slice=102
                      [DEBUG] Buffer[5]: vaddress=0x24000000000000, fd=1024, size=127, width=0, height=104, stride=0, slice=0
                      [DEBUG] Buffer[6]: vaddress=0x50000000000, fd=-2014735536, size=0, width=0, height=0, stride=0, slice=0
                      [DEBUG] Buffer[7]: vaddress=0x60000000320, fd=0, size=0, width=0, height=0, stride=0, slice=0
                      [DEBUG] Buffer[8]: vaddress=0x400, fd=0, size=0, width=0, height=0, stride=0, slice=0
                      [DEBUG] Buffer[9]: vaddress=0x5587d77ba0, fd=0, size=0, width=0, height=0, stride=0, slice=0
                      [DEBUG] Buffer[10]: vaddress=(nil), fd=-2079350784, size=0, width=0, height=0, stride=0, slice=0
                      [DEBUG] Buffer[11]: vaddress=(nil), fd=-2082496512, size=0, width=0, height=0, stride=2359296, slice=0
                      [DEBUG] Buffer[12]: vaddress=0x900000000, fd=-1, size=0, width=2359296, height=0, stride=1280, slice=800
                      [DEBUG] Buffer[13]: vaddress=0x7f8337a000, fd=120, size=2359296, width=1280, height=800, stride=1536, slice=1024
                      [DEBUG] Buffer[14]: vaddress=0x7f8307a000, fd=0, size=1280, width=1536, height=1024, stride=0, slice=-2012890624
                      [DEBUG] Buffer[15]: vaddress=(nil), fd=-1, size=1536, width=0, height=-2014372240, stride=85, slice=0
                      [DEBUG] Found 1 valid buffers out of 16 allocated
                      The debug output shows that only Buffer[13] has valid data with proper values: vaddress=0x7f8337a000, fd=120, size=2359296, width=1280, height=800. The library reports success but returns mostly unusable buffers, which causes the OMX encoder to fail during initialization since it expects a minimum number of valid buffers, of which, it only found 1 before (hence, the message, WARNING: Encoder expecting(16) more buffers than module allocated(1)).
                      I implemented a temporary workaround that identifies the single valid buffer from the corrupted pool and duplicates its metadata to create 8 usable buffers (I was able to decrease the expected to 8 from 16, but I couldn't get any lower). This involves moving valid buffers to the front of the pool and zeroing out remaining buffers to prevent crashes. The workaround allows the OMX encoder to initialize with the minimum required buffers instead of failing with only 1 valid buffer.
                      This is clearly a temporary solution and not a permanent fix. The root cause lies in the mpa_ion_buf_pool_alloc_bufs function, which appears to have a memory management issue. I was unable to find the implementation of that function, so I was unable to debug any further.
                      I'm not sure if something else regarding the configuration on my Voxl was causing that issue. I was unable to find anything, but let me know if I'm missing something very obvious.
                      • J Jordyn Heil
                        @Jordyn-Heil , i have seen this issue before. This is because you are compiling the camera server app against one version of libmodal-pipe library, but a different version is running on voxl2. There was an api change in the header file causing this issue. The solution is to use latest libmodal pipe (from dev) while cross compiling and running on voxl. You dont need to update the whole sdk, just update that lib.
                          Jordyn Heil
                          @Alex-Kushleyev, thank you! That solved my issue!
                          I can successfully stream the grey MISP streams over RTSP from my color AR0144s, but I am unable to stream colored frames over RTSP. Is the processing pipeline to do this implemented, and if so, what modifications need to be made to send and access these streams over RTSP?
                          Also, I believe you mentioned earlier that the VOXL GPU can handle panoramic stitching between camera streams? I am currently using the CPU to do panoramic stitching, but there is too much lag for my application, so I would like to try and use a compute shader to offload the work to the GPU. What is the best way to do this on the VOXL2?
                          • J Jordyn Heil
                            @Jordyn-Heil , yes i need to add the part that feeds the frames into the video encoder for the ar0144 color use case. it's not difficult, i will do it this week.
                            Regarding GPU usage, I have only done OpenCL programming on VOXL2, but OpenGL is also supported, I can probably find some resources to help with that. Which one of the two do you prefer? OpenCL would probably be easier (for me to help you) since we have done much more with that already.
                              Jordyn Heil
                              @Alex-Kushleyev, great, thanks for doing that!
                              OpenCL should work just fine!
                              • J Jordyn Heil
                                #35
                                @Jordyn-Heil , sorry for the delay.
                                I will provide an initial example of getting 4 AR0144 streams into a standalone app and doing something with all of them on the GPU using OpenCL. This should be a nice example / starting point for multi-camera image fusion.
                                Initially I will just use our standard mpa approach to get the image buffers from camera server to the standalone app. After that i will also try to do the same using the ION buffer support (which is already in camera server) which will allow us to map the buffers to GPU without doing any copy operations or sending image data over pipes. using ION buffer sharing will allow to further reduce the cpu and memory bandwidth usage, but it's still a bit of experimental feature and will need some more testing.
                                Please give me a few more days.
                                  Jordyn Heil
                                  @Alex-Kushleyev, no worries! I appreciate your help on this!
                                  In the meantime, would you be able to share the CAD file for the M0173 breakout board? I was not able to find it anywhere.
                                  VinnyV 1 Reply Last reply
                                  • J Jordyn Heil
                                    VinnyV Offline
                                    VinnyV Offline
                                    Vinny
                                    Hi @Jordyn-Heil
                                    We try to keep this regularly updated, but sometimes miss some... in this case, M0173 is there 🙂 https://docs.modalai.com/pcb-catalog/
                                      Jordyn Heil
                                      @Alex-Kushleyev, were you able to update the dev build of voxl-camera-server to encode the ar0144 color streams?
                                      • J Jordyn Heil
                                        @Jordyn-Heil ,
                                        Sorry for the delay.
                                        In order to test the AR0144 Color RTSP stream, you can use voxl-streamer. I just pushed a small changed that fixed the pipe description for AR0144 color output from YUV to RGB. The current implementation publishes RGB, but the mpa pipe description was set to YUV, so voxl-streamer did not work.
                                        So right now, i can run voxl-streamer:
                                        voxl2:/$ voxl-streamer -i tracking_front_misp_color
                                        Waiting for pipe tracking_front_misp_color to appear
                                        Found Pipe
                                        detected following stats from pipe:
                                        w: 1280 h: 800 fps: 30 format: RGB
                                        Stream available at rtsp://127.0.0.1:8900/live
                                        A new client rtsp://<my ip>:36952(null) has connected, total clients: 1
                                        Camera server Connected
                                        rtsp client disconnected, total clients: 0
                                        no more rtsp clients, closing source pipe intentionally
                                        Removed 1 sessions
                                        voxl-streamer will receive the RGB image and use the hardware encoder to encode the images into the video stream.
                                        The corresponding changes are on voxl-camera-server dev branch of voxl-camera-server.
                                        Will that work for you, or do you need the voxl-camera-server to publish the encoded stream? In that case, since voxl-camera-server only supports encoding YUVs, I would need to conver to YUV then feed the image into the encoder.
                                        I will follow up regarding GPU stuff in the next post.
                                          @Jordyn-Heil ,
                                          Found Pipe
                                          Removed 1 sessions
                                          #40
                                          @Jordyn-Heil ,
                                          I am working on some examples of how to use the GPU with images received from the camera server via MPA (raw bayer, yuv, rgb).
                                          I just wanted to clarify your use case.
                                          • Currently, the camera server receives RAW8 bayer image from AR0144 camera (it can be RAW10/12 but it is not yet working reliably, different story)
                                          • the camera server then uses CPU to de-bayer the image into RGB
                                          • RGB is then sent out via MPA and can be viewed by voxl-portal (which supports RGB) or can be encoded via voxl-streamer, which also supports RGB input.
                                          Now, in order to do any image stitching, the following would need to be done in the client application
                                          • subscribe the the multiple camera streams (whether bayer or RGB)
                                          • load camera calibration (intrinsic) for each camera
                                          • load extrinsic parameters for each camera
                                          • load LSC (lens shading correction) tables for each camera (or could be the same for all, close enough)
                                          • for simplicity, lets assume that there is one large output buffer is allocated for all cameras to be pasted into (panorama image). and when individual images come in, the job of the app is to do the following:
                                            • apply LSC corrections to the whole image
                                            • (optional) perform white balance corrections (to be consistent across all cameras) (would need some analysis across all images)
                                            • undistort the image according to the fisheye calibration params
                                            • project the image according to the extrinsics calibration into the stitched image
                                          this would ignore the time synchronization aspect for now and basically as each image comes in, the stitched image is updated.
                                          Also, for your algorithm development, do you work with RGB image or YUV?
                                          I am planning to share something simple first, which will subscribe to the 3 or 4 AR0144 cameras, load some intrinsics and extrinsics and overlay the images in a larger image (without explicitly calibrating the extrinsics). Then we can go from there.
