  3. Motor stalling/failing - VOXL2 Starling
starling
3 Posts 2 Posters 707 Views 1 Watching
  • J Offline
    JoeAR_21
    One of our recently acquired motors has been failing, it spins up then briefly stops and starts back up, the voxl-esc spin reveals the following:
    INFO: ESC Information:
    INFO: ---------------------
    ID : 0 // problematic motor
    Board : version 37: ModalAi 4-in-1 ESC (M0134-1)
    UID : 0x203330385246571800230046
    Firmware : version 39, hash eb6fb500
    Bootloader : version 183, hash b4fa2cf8
    UID : 0x203330385246571900310040
    UID : 0x203330385246571900310042
    UID : 0x203330385246571900280025
    [GCC 8.4.0]
    dpkg-query: no packages found matching...
    Found voxl-esc tools bin version: 1.6
    VOXL Platform: M0054
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000
    WARNING: skipping user prompt to start the test due to override
    [0.013] (0) RPM: 0, PWR: 0, VOLTAGE: 6.760V, TEMPERATURE: 36.92C, CURRENT: -0.032A
    [0.032] (0) RPM: 29, PWR: 0, VOLTAGE: 6.768V, TEMPERATURE: 36.90C, CURRENT: -0.032A
    [0.052] (0) RPM: 59, PWR: 1, VOLTAGE: 6.768V, TEMPERATURE: 36.91C, CURRENT: -0.008A
    [0.073] (0) RPM: 90, PWR: 2, VOLTAGE: 6.769V, TEMPERATURE: 36.89C, CURRENT: -0.016A
    [0.092] (0) RPM: 119, PWR: 2, VOLTAGE: 6.765V, TEMPERATURE: 36.91C, CURRENT: 0.000A
    [0.114] (0) RPM: 150, PWR: 3, VOLTAGE: 6.770V, TEMPERATURE: 36.91C, CURRENT: 0.000A
    [0.132] (0) RPM: 179, PWR: 4, VOLTAGE: 6.768V, TEMPERATURE: 36.94C, CURRENT: -0.016A
    [0.153] (0) RPM: 205, PWR: 4, VOLTAGE: 6.768V, TEMPERATURE: 36.93C, CURRENT: 0.016A
    [0.175] (0) RPM: 228, PWR: 5, VOLTAGE: 6.761V, TEMPERATURE: 36.92C, CURRENT: 0.024A
    [0.192] (0) RPM: 269, PWR: 6, VOLTAGE: 6.766V, TEMPERATURE: 36.88C, CURRENT: 0.024A
    [0.219] (0) RPM: 309, PWR: 6, VOLTAGE: 6.768V, TEMPERATURE: 36.87C, CURRENT: 0.000A
    [0.234] (0) RPM: 314, PWR: 7, VOLTAGE: 6.769V, TEMPERATURE: 36.86C, CURRENT: 0.016A
    [0.252] (0) RPM: 358, PWR: 8, VOLTAGE: 6.766V, TEMPERATURE: 36.90C, CURRENT: 0.040A
    [0.280] (0) RPM: 392, PWR: 8, VOLTAGE: 6.768V, TEMPERATURE: 36.91C, CURRENT: 0.024A
    [0.292] (0) RPM: 418, PWR: 9, VOLTAGE: 6.765V, TEMPERATURE: 36.89C, CURRENT: 0.072A
    [0.312] (0) RPM: 449, PWR: 10, VOLTAGE: 6.765V, TEMPERATURE: 36.91C, CURRENT: 0.072A
    [0.336] (0) RPM: 464, PWR: 10, VOLTAGE: 6.764V, TEMPERATURE: 36.90C, CURRENT: 0.080A
    [0.352] (0) RPM: 509, PWR: 11, VOLTAGE: 6.766V, TEMPERATURE: 36.88C, CURRENT: 0.104A
    [0.379] (0) RPM: 528, PWR: 11, VOLTAGE: 6.755V, TEMPERATURE: 36.89C, CURRENT: 0.072A
    [0.394] (0) RPM: 554, PWR: 12, VOLTAGE: 6.761V, TEMPERATURE: 36.90C, CURRENT: 0.072A
    [0.413] (0) RPM: 599, PWR: 13, VOLTAGE: 6.760V, TEMPERATURE: 36.91C, CURRENT: 0.088A
    [0.432] (0) RPM: 629, PWR: 14, VOLTAGE: 6.760V, TEMPERATURE: 36.90C, CURRENT: 0.168A
    [0.452] (0) RPM: 658, PWR: 14, VOLTAGE: 6.761V, TEMPERATURE: 36.88C, CURRENT: 0.152A
    [0.483] (0) RPM: 679, PWR: 14, VOLTAGE: 6.762V, TEMPERATURE: 36.89C, CURRENT: 0.128A
    [0.493] (0) RPM: 719, PWR: 14, VOLTAGE: 6.762V, TEMPERATURE: 36.92C, CURRENT: 0.136A
    [0.515] (0) RPM: 751, PWR: 14, VOLTAGE: 6.761V, TEMPERATURE: 36.93C, CURRENT: 0.152A
    [0.532] (0) RPM: 779, PWR: 14, VOLTAGE: 6.755V, TEMPERATURE: 36.92C, CURRENT: 0.144A
    [0.552] (0) RPM: 808, PWR: 14, VOLTAGE: 6.757V, TEMPERATURE: 36.94C, CURRENT: 0.120A
    [0.577] (0) RPM: 845, PWR: 15, VOLTAGE: 6.754V, TEMPERATURE: 36.92C, CURRENT: 0.168A
    [0.592] (0) RPM: 868, PWR: 15, VOLTAGE: 6.755V, TEMPERATURE: 36.94C, CURRENT: 0.080A
    [0.612] (0) RPM: 898, PWR: 15, VOLTAGE: 6.757V, TEMPERATURE: 36.93C, CURRENT: 0.160A
    [0.633] (0) RPM: 930, PWR: 15, VOLTAGE: 6.760V, TEMPERATURE: 36.93C, CURRENT: 0.176A
    [0.652] (0) RPM: 959, PWR: 15, VOLTAGE: 6.761V, TEMPERATURE: 36.95C, CURRENT: 0.208A
    [0.672] (0) RPM: 989, PWR: 15, VOLTAGE: 6.758V, TEMPERATURE: 36.94C, CURRENT: 0.192A
    [0.694] (0) RPM: 1004, PWR: 15, VOLTAGE: 6.755V, TEMPERATURE: 36.94C, CURRENT: 0.176A
    [0.712] (0) RPM: 1049, PWR: 16, VOLTAGE: 6.759V, TEMPERATURE: 36.95C, CURRENT: 0.208A
    [0.733] (0) RPM: 1080, PWR: 16, VOLTAGE: 6.759V, TEMPERATURE: 36.94C, CURRENT: 0.160A
    [0.752] (0) RPM: 1108, PWR: 16, VOLTAGE: 6.759V, TEMPERATURE: 36.95C, CURRENT: 0.176A
    [0.788] (0) RPM: 1126, PWR: 16, VOLTAGE: 6.748V, TEMPERATURE: 36.95C, CURRENT: 0.160A
    [0.792] (0) RPM: 1168, PWR: 16, VOLTAGE: 6.755V, TEMPERATURE: 36.95C, CURRENT: 0.144A
    [0.813] (0) RPM: 1184, PWR: 16, VOLTAGE: 6.752V, TEMPERATURE: 36.96C, CURRENT: 0.120A
    [0.832] (0) RPM: 1228, PWR: 17, VOLTAGE: 6.755V, TEMPERATURE: 36.97C, CURRENT: 0.216A
    [0.852] (0) RPM: 1259, PWR: 17, VOLTAGE: 6.755V, TEMPERATURE: 37.00C, CURRENT: 0.112A
    [0.873] (0) RPM: 1277, PWR: 17, VOLTAGE: 6.756V, TEMPERATURE: 36.98C, CURRENT: 0.120A
    [0.893] (0) RPM: 1318, PWR: 17, VOLTAGE: 6.756V, TEMPERATURE: 36.97C, CURRENT: 0.072A
    [0.913] (0) RPM: 1350, PWR: 17, VOLTAGE: 6.759V, TEMPERATURE: 36.96C, CURRENT: 0.136A
    [0.932] (0) RPM: 1379, PWR: 17, VOLTAGE: 6.756V, TEMPERATURE: 37.01C, CURRENT: 0.136A
    [0.952] (0) RPM: 1409, PWR: 18, VOLTAGE: 6.759V, TEMPERATURE: 36.98C, CURRENT: 0.192A
    [0.977] (0) RPM: 1429, PWR: 18, VOLTAGE: 6.752V, TEMPERATURE: 36.99C, CURRENT: 0.136A
    [0.994] (0) RPM: 1469, PWR: 18, VOLTAGE: 6.753V, TEMPERATURE: 36.97C, CURRENT: 0.144A
    [1.013] (0) RPM: 1483, PWR: 18, VOLTAGE: 6.753V, TEMPERATURE: 36.98C, CURRENT: 0.056A
    [1.033] (0) RPM: 1529, PWR: 18, VOLTAGE: 6.755V, TEMPERATURE: 36.98C, CURRENT: 0.120A
    [1.052] (0) RPM: 1559, PWR: 18, VOLTAGE: 6.755V, TEMPERATURE: 36.98C, CURRENT: 0.128A
    [1.079] (0) RPM: 1589, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 36.98C, CURRENT: 0.224A
    [1.094] (0) RPM: 1606, PWR: 19, VOLTAGE: 6.754V, TEMPERATURE: 36.99C, CURRENT: 0.120A
    [1.112] (0) RPM: 1649, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 37.00C, CURRENT: 0.160A
    [1.133] (0) RPM: 1679, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 36.99C, CURRENT: 0.160A
    [1.152] (0) RPM: 1708, PWR: 19, VOLTAGE: 6.756V, TEMPERATURE: 36.99C, CURRENT: 0.136A
    [1.176] (0) RPM: 1725, PWR: 19, VOLTAGE: 6.745V, TEMPERATURE: 36.99C, CURRENT: 0.224A
    [1.194] (0) RPM: 1771, PWR: 19, VOLTAGE: 6.753V, TEMPERATURE: 36.99C, CURRENT: 0.192A
    [1.212] (0) RPM: 1798, PWR: 20, VOLTAGE: 6.755V, TEMPERATURE: 37.01C, CURRENT: 0.168A
    [1.235] (0) RPM: 1813, PWR: 20, VOLTAGE: 6.758V, TEMPERATURE: 36.98C, CURRENT: 0.136A
    [1.252] (0) RPM: 1859, PWR: 20, VOLTAGE: 6.756V, TEMPERATURE: 36.99C, CURRENT: 0.152A
    [1.276] (0) RPM: 1874, PWR: 20, VOLTAGE: 6.756V, TEMPERATURE: 37.01C, CURRENT: 0.096A
    [1.292] (0) RPM: 1919, PWR: 20, VOLTAGE: 6.755V, TEMPERATURE: 37.05C, CURRENT: 0.224A
    [1.314] (0) RPM: 1950, PWR: 20, VOLTAGE: 6.755V, TEMPERATURE: 37.04C, CURRENT: 0.136A
    [1.332] (0) RPM: 1979, PWR: 20, VOLTAGE: 6.755V, TEMPERATURE: 37.04C, CURRENT: 0.152A
    [1.353] (0) RPM: 2008, PWR: 21, VOLTAGE: 6.755V, TEMPERATURE: 37.03C, CURRENT: 0.176A
    [1.375] (0) RPM: 2025, PWR: 21, VOLTAGE: 6.748V, TEMPERATURE: 37.03C, CURRENT: 0.152A
    [1.394] (0) RPM: 2069, PWR: 21, VOLTAGE: 6.755V, TEMPERATURE: 37.02C, CURRENT: 0.176A
    [1.413] (0) RPM: 2086, PWR: 21, VOLTAGE: 6.756V, TEMPERATURE: 37.00C, CURRENT: 0.136A
    [1.432] (0) RPM: 2129, PWR: 21, VOLTAGE: 6.756V, TEMPERATURE: 37.02C, CURRENT: 0.160A
    [1.453] (0) RPM: 2159, PWR: 21, VOLTAGE: 6.757V, TEMPERATURE: 37.01C, CURRENT: 0.168A
    [1.480] (0) RPM: 2189, PWR: 22, VOLTAGE: 6.760V, TEMPERATURE: 37.03C, CURRENT: 0.176A
    [1.493] (0) RPM: 2220, PWR: 22, VOLTAGE: 6.755V, TEMPERATURE: 37.01C, CURRENT: 0.160A
    [1.513] (0) RPM: 2239, PWR: 22, VOLTAGE: 6.755V, TEMPERATURE: 37.03C, CURRENT: 0.128A
    [1.532] (0) RPM: 2279, PWR: 22, VOLTAGE: 6.755V, TEMPERATURE: 37.02C, CURRENT: 0.136A
    [1.552] (0) RPM: 2308, PWR: 22, VOLTAGE: 6.757V, TEMPERATURE: 37.04C, CURRENT: 0.216A
    [1.578] (0) RPM: 2327, PWR: 22, VOLTAGE: 6.750V, TEMPERATURE: 37.05C, CURRENT: 0.120A
    [1.593] (0) RPM: 2370, PWR: 22, VOLTAGE: 6.759V, TEMPERATURE: 37.04C, CURRENT: 0.200A
    [1.612] (0) RPM: 2399, PWR: 23, VOLTAGE: 6.756V, TEMPERATURE: 37.04C, CURRENT: 0.168A
    [1.633] (0) RPM: 2413, PWR: 23, VOLTAGE: 6.756V, TEMPERATURE: 37.05C, CURRENT: 0.144A
    [1.652] (0) RPM: 2459, PWR: 23, VOLTAGE: 6.761V, TEMPERATURE: 37.06C, CURRENT: 0.104A
    [1.676] (0) RPM: 2474, PWR: 23, VOLTAGE: 6.761V, TEMPERATURE: 37.07C, CURRENT: 0.152A
    [1.692] (0) RPM: 2519, PWR: 23, VOLTAGE: 6.762V, TEMPERATURE: 37.04C, CURRENT: 0.176A
    [1.712] (0) RPM: 2549, PWR: 23, VOLTAGE: 6.761V, TEMPERATURE: 37.03C, CURRENT: 0.144A
    [1.734] (0) RPM: 2571, PWR: 23, VOLTAGE: 6.758V, TEMPERATURE: 37.03C, CURRENT: 0.128A
    [1.752] (0) RPM: 2609, PWR: 24, VOLTAGE: 6.755V, TEMPERATURE: 37.04C, CURRENT: 0.136A
    [1.775] (0) RPM: 2643, PWR: 24, VOLTAGE: 6.753V, TEMPERATURE: 37.02C, CURRENT: 0.128A
    [1.792] (0) RPM: 2669, PWR: 24, VOLTAGE: 6.755V, TEMPERATURE: 37.01C, CURRENT: 0.008A
    [1.812] (0) RPM: 2698, PWR: 24, VOLTAGE: 6.755V, TEMPERATURE: 36.98C, CURRENT: 0.120A
    [1.832] (0) RPM: 2728, PWR: 24, VOLTAGE: 6.756V, TEMPERATURE: 36.97C, CURRENT: 0.104A
    [1.853] (0) RPM: 2760, PWR: 24, VOLTAGE: 6.756V, TEMPERATURE: 36.98C, CURRENT: 0.112A
    [1.882] (0) RPM: 2775, PWR: 24, VOLTAGE: 6.755V, TEMPERATURE: 36.99C, CURRENT: 0.128A
    [1.896] (0) RPM: 2806, PWR: 25, VOLTAGE: 6.754V, TEMPERATURE: 36.98C, CURRENT: 0.128A
    [1.912] (0) RPM: 2849, PWR: 25, VOLTAGE: 6.757V, TEMPERATURE: 37.00C, CURRENT: 0.136A
    [1.934] (0) RPM: 2867, PWR: 25, VOLTAGE: 6.754V, TEMPERATURE: 37.02C, CURRENT: 0.184A
    [1.952] (0) RPM: 2908, PWR: 25, VOLTAGE: 6.756V, TEMPERATURE: 36.98C, CURRENT: 0.176A
    [1.976] (0) RPM: 2924, PWR: 25, VOLTAGE: 6.747V, TEMPERATURE: 36.98C, CURRENT: 0.104A
    [1.994] (0) RPM: 2971, PWR: 25, VOLTAGE: 6.755V, TEMPERATURE: 36.98C, CURRENT: 0.128A
    [2.012] (0) RPM: 2998, PWR: 26, VOLTAGE: 6.751V, TEMPERATURE: 36.97C, CURRENT: 0.208A
    [2.033] (0) RPM: 3525, PWR: 10, VOLTAGE: 6.757V, TEMPERATURE: 36.97C, CURRENT: 0.088A
    [2.052] (0) RPM: 3525, PWR: 10, VOLTAGE: 6.756V, TEMPERATURE: 36.98C, CURRENT: 0.184A
    [2.074] (0) RPM: 3525, PWR: 10, VOLTAGE: 6.758V, TEMPERATURE: 36.97C, CURRENT: 0.128A
    [2.093] (0) RPM: 0, PWR: 0, VOLTAGE: 6.766V, TEMPERATURE: 36.99C, CURRENT: -0.064A
    [2.113] (0) RPM: 15, PWR: 0, VOLTAGE: 6.768V, TEMPERATURE: 37.00C, CURRENT: -0.040A
    [2.132] (0) RPM: 58, PWR: 1, VOLTAGE: 6.768V, TEMPERATURE: 37.02C, CURRENT: -0.016A
    [2.153] (0) RPM: 89, PWR: 1, VOLTAGE: 6.781V, TEMPERATURE: 37.04C, CURRENT: -0.032A
    [2.177] (0) RPM: 106, PWR: 2, VOLTAGE: 6.761V, TEMPERATURE: 37.02C, CURRENT: -0.008A
    [2.192] (0) RPM: 148, PWR: 3, VOLTAGE: 6.762V, TEMPERATURE: 37.02C, CURRENT: -0.040A
    [2.212] (0) RPM: 167, PWR: 3, VOLTAGE: 6.757V, TEMPERATURE: 37.01C, CURRENT: 0.016A
    [2.232] (0) RPM: 208, PWR: 4, VOLTAGE: 6.762V, TEMPERATURE: 37.05C, CURRENT: 0.072A
    [2.253] (0) RPM: 239, PWR: 5, VOLTAGE: 6.763V, TEMPERATURE: 37.01C, CURRENT: 0.008A
    [2.275] (0) RPM: 254, PWR: 5, VOLTAGE: 6.766V, TEMPERATURE: 37.03C, CURRENT: 0.048A
    [2.292] (0) RPM: 298, PWR: 6, VOLTAGE: 6.766V, TEMPERATURE: 37.04C, CURRENT: 0.016A
    [2.313] (0) RPM: 328, PWR: 7, VOLTAGE: 6.763V, TEMPERATURE: 37.05C, CURRENT: 0.056A
    [2.332] (0) RPM: 358, PWR: 8, VOLTAGE: 6.762V, TEMPERATURE: 37.08C, CURRENT: 0.032A
    [2.354] (0) RPM: 373, PWR: 8, VOLTAGE: 6.761V, TEMPERATURE: 37.11C, CURRENT: 0.024A
    [2.375] (0) RPM: 423, PWR: 9, VOLTAGE: 6.761V, TEMPERATURE: 37.09C, CURRENT: 0.032A
    [2.393] (0) RPM: 448, PWR: 10, VOLTAGE: 6.761V, TEMPERATURE: 37.08C, CURRENT: 0.032A
    [2.412] (0) RPM: 478, PWR: 10, VOLTAGE: 6.761V, TEMPERATURE: 37.11C, CURRENT: 0.080A
    [2.432] (0) RPM: 508, PWR: 11, VOLTAGE: 6.762V, TEMPERATURE: 37.11C, CURRENT: 0.048A
    [2.454] (0) RPM: 523, PWR: 11, VOLTAGE: 6.762V, TEMPERATURE: 37.10C, CURRENT: 0.112A
    [2.475] (0) RPM: 572, PWR: 12, VOLTAGE: 6.762V, TEMPERATURE: 37.14C, CURRENT: 0.184A
    [2.494] (0) RPM: 600, PWR: 13, VOLTAGE: 6.760V, TEMPERATURE: 37.13C, CURRENT: 0.096A
    [2.513] (0) RPM: 621, PWR: 14, VOLTAGE: 6.758V, TEMPERATURE: 37.12C, CURRENT: 0.056A
    [2.532] (0) RPM: 658, PWR: 14, VOLTAGE: 6.760V, TEMPERATURE: 37.11C, CURRENT: 0.112A
    [2.553] (0) RPM: 673, PWR: 14, VOLTAGE: 6.761V, TEMPERATURE: 37.10C, CURRENT: 0.168A
    [2.573] (0) RPM: 720, PWR: 14, VOLTAGE: 6.755V, TEMPERATURE: 37.13C, CURRENT: 0.136A
    [2.594] (0) RPM: 751, PWR: 14, VOLTAGE: 6.754V, TEMPERATURE: 37.13C, CURRENT: 0.200A
    [2.612] (0) RPM: 778, PWR: 14, VOLTAGE: 6.755V, TEMPERATURE: 37.14C, CURRENT: 0.128A
    [2.633] (0) RPM: 808, PWR: 14, VOLTAGE: 6.755V, TEMPERATURE: 37.15C, CURRENT: 0.104A
    [2.653] (0) RPM: 838, PWR: 15, VOLTAGE: 6.756V, TEMPERATURE: 37.14C, CURRENT: 0.192A
    [2.673] (0) RPM: 855, PWR: 15, VOLTAGE: 6.756V, TEMPERATURE: 37.16C, CURRENT: 0.128A
    [2.694] (0) RPM: 901, PWR: 15, VOLTAGE: 6.758V, TEMPERATURE: 37.14C, CURRENT: 0.168A
    [2.712] (0) RPM: 928, PWR: 15, VOLTAGE: 6.756V, TEMPERATURE: 37.17C, CURRENT: 0.160A
    [2.734] (0) RPM: 944, PWR: 15, VOLTAGE: 6.755V, TEMPERATURE: 37.19C, CURRENT: 0.200A
    [2.753] (0) RPM: 988, PWR: 15, VOLTAGE: 6.755V, TEMPERATURE: 37.17C, CURRENT: 0.096A
    [2.792] (0) RPM: 1044, PWR: 16, VOLTAGE: 6.754V, TEMPERATURE: 37.13C, CURRENT: 0.136A
    [2.795] (0) RPM: 1053, PWR: 16, VOLTAGE: 6.753V, TEMPERATURE: 37.13C, CURRENT: 0.152A
    [2.811] (0) RPM: 1077, PWR: 16, VOLTAGE: 6.754V, TEMPERATURE: 37.15C, CURRENT: 0.096A
    [2.833] (0) RPM: 1109, PWR: 16, VOLTAGE: 6.756V, TEMPERATURE: 37.13C, CURRENT: 0.152A
    [2.853] (0) RPM: 1125, PWR: 16, VOLTAGE: 6.750V, TEMPERATURE: 37.12C, CURRENT: 0.136A
    [2.872] (0) RPM: 1168, PWR: 16, VOLTAGE: 6.756V, TEMPERATURE: 37.13C, CURRENT: 0.040A
    [2.892] (0) RPM: 1198, PWR: 16, VOLTAGE: 6.755V, TEMPERATURE: 37.12C, CURRENT: 0.200A
    [2.912] (0) RPM: 1228, PWR: 17, VOLTAGE: 6.755V, TEMPERATURE: 37.11C, CURRENT: 0.120A
    [2.932] (0) RPM: 1258, PWR: 17, VOLTAGE: 6.758V, TEMPERATURE: 37.09C, CURRENT: 0.136A
    [2.952] (0) RPM: 1310, PWR: 17, VOLTAGE: 6.751V, TEMPERATURE: 37.09C, CURRENT: 0.336A
    [2.987] (0) RPM: 1310, PWR: 17, VOLTAGE: 6.751V, TEMPERATURE: 37.09C, CURRENT: 0.336A
    [2.995] (0) RPM: 1343, PWR: 17, VOLTAGE: 6.755V, TEMPERATURE: 37.12C, CURRENT: 0.152A
    [3.012] (0) RPM: 1377, PWR: 17, VOLTAGE: 6.751V, TEMPERATURE: 37.12C, CURRENT: 0.160A
    [3.032] (0) RPM: 1408, PWR: 18, VOLTAGE: 6.755V, TEMPERATURE: 37.15C, CURRENT: 0.072A
    [3.054] (0) RPM: 1425, PWR: 18, VOLTAGE: 6.756V, TEMPERATURE: 37.16C, CURRENT: 0.152A
    [3.072] (0) RPM: 1468, PWR: 18, VOLTAGE: 6.755V, TEMPERATURE: 37.17C, CURRENT: 0.120A
    [3.095] (0) RPM: 1502, PWR: 18, VOLTAGE: 6.755V, TEMPERATURE: 37.17C, CURRENT: 0.160A
    [3.112] (0) RPM: 1528, PWR: 18, VOLTAGE: 6.755V, TEMPERATURE: 37.17C, CURRENT: 0.160A
    [3.132] (0) RPM: 1558, PWR: 18, VOLTAGE: 6.755V, TEMPERATURE: 37.18C, CURRENT: 0.168A
    [3.153] (0) RPM: 1588, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 37.20C, CURRENT: 0.120A
    [3.173] (0) RPM: 1619, PWR: 19, VOLTAGE: 6.750V, TEMPERATURE: 37.16C, CURRENT: 0.136A
    [3.193] (0) RPM: 1648, PWR: 19, VOLTAGE: 6.750V, TEMPERATURE: 37.14C, CURRENT: 0.144A
    [3.212] (0) RPM: 1677, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 37.17C, CURRENT: 0.192A
    [3.232] (0) RPM: 1708, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 37.14C, CURRENT: 0.160A
    [3.253] (0) RPM: 1740, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 37.13C, CURRENT: 0.176A
    [3.272] (0) RPM: 1768, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 37.16C, CURRENT: 0.136A
    [3.292] (0) RPM: 1784, PWR: 19, VOLTAGE: 6.755V, TEMPERATURE: 37.17C, CURRENT: 0.168A
    [3.312] (0) RPM: 1828, PWR: 20, VOLTAGE: 6.757V, TEMPERATURE: 37.19C, CURRENT: 0.224A
    [3.334] (0) RPM: 1861, PWR: 20, VOLTAGE: 6.755V, TEMPERATURE: 37.19C, CURRENT: 0.128A
    [3.353] (0) RPM: 1874, PWR: 20, VOLTAGE: 6.757V, TEMPERATURE: 37.21C, CURRENT: 0.144A
    [3.388] (0) RPM: 1888, PWR: 20, VOLTAGE: 6.756V, TEMPERATURE: 37.20C, CURRENT: 0.144A
    [3.394] (0) RPM: 1950, PWR: 20, VOLTAGE: 6.752V, TEMPERATURE: 37.21C, CURRENT: 0.176A
    [3.412] (0) RPM: 1978, PWR: 20, VOLTAGE: 6.752V, TEMPERATURE: 37.21C, CURRENT: 0.160A
    [3.435] (0) RPM: 1992, PWR: 21, VOLTAGE: 6.755V, TEMPERATURE: 37.22C, CURRENT: 0.160A
    [3.452] (0) RPM: 2038, PWR: 21, VOLTAGE: 6.756V, TEMPERATURE: 37.18C, CURRENT: 0.120A
    [3.478] (0) RPM: 2077, PWR: 21, VOLTAGE: 6.756V, TEMPERATURE: 37.18C, CURRENT: 0.120A
    [3.493] (0) RPM: 2083, PWR: 21, VOLTAGE: 6.756V, TEMPERATURE: 37.20C, CURRENT: 0.120A
    [3.512] (0) RPM: 2128, PWR: 21, VOLTAGE: 6.756V, TEMPERATURE: 37.21C, CURRENT: 0.160A
    [3.532] (0) RPM: 2158, PWR: 21, VOLTAGE: 6.756V, TEMPERATURE: 37.22C, CURRENT: 0.192A
    [3.552] (0) RPM: 2188, PWR: 22, VOLTAGE: 6.757V, TEMPERATURE: 37.22C, CURRENT: 0.160A
    [3.574] (0) RPM: 2205, PWR: 22, VOLTAGE: 6.745V, TEMPERATURE: 37.22C, CURRENT: 0.152A
    [3.593] (0) RPM: 2249, PWR: 22, VOLTAGE: 6.754V, TEMPERATURE: 37.22C, CURRENT: 0.128A
    [3.612] (0) RPM: 2277, PWR: 22, VOLTAGE: 6.754V, TEMPERATURE: 37.22C, CURRENT: 0.216A
    [3.639] (0) RPM: 2292, PWR: 22, VOLTAGE: 6.755V, TEMPERATURE: 37.22C, CURRENT: 0.160A
    [3.652] (0) RPM: 2338, PWR: 22, VOLTAGE: 6.756V, TEMPERATURE: 37.20C, CURRENT: 0.160A
    [3.674] (0) RPM: 2354, PWR: 22, VOLTAGE: 6.756V, TEMPERATURE: 37.22C, CURRENT: 0.136A
    [3.693] (0) RPM: 2399, PWR: 23, VOLTAGE: 6.759V, TEMPERATURE: 37.21C, CURRENT: 0.208A
    [3.714] (0) RPM: 2429, PWR: 23, VOLTAGE: 6.756V, TEMPERATURE: 37.23C, CURRENT: 0.152A
    [3.732] (0) RPM: 2458, PWR: 23, VOLTAGE: 6.755V, TEMPERATURE: 37.25C, CURRENT: 0.112A
    [3.752] (0) RPM: 2488, PWR: 23, VOLTAGE: 6.757V, TEMPERATURE: 37.27C, CURRENT: 0.120A
    [3.791] (0) RPM: 2505, PWR: 23, VOLTAGE: 6.748V, TEMPERATURE: 37.27C, CURRENT: 0.136A
    [3.795] (0) RPM: 2552, PWR: 23, VOLTAGE: 6.755V, TEMPERATURE: 37.23C, CURRENT: 0.128A
    [3.812] (0) RPM: 2577, PWR: 24, VOLTAGE: 6.754V, TEMPERATURE: 37.19C, CURRENT: 0.136A
    [3.836] (0) RPM: 2595, PWR: 24, VOLTAGE: 6.758V, TEMPERATURE: 37.16C, CURRENT: 0.088A
    [3.852] (0) RPM: 2638, PWR: 24, VOLTAGE: 6.755V, TEMPERATURE: 37.17C, CURRENT: 0.112A
    [3.873] (0) RPM: 2669, PWR: 24, VOLTAGE: 6.758V, TEMPERATURE: 37.16C, CURRENT: 0.168A
    [3.895] (0) RPM: 2683, PWR: 24, VOLTAGE: 6.756V, TEMPERATURE: 37.15C, CURRENT: 0.120A
    [3.912] (0) RPM: 2728, PWR: 24, VOLTAGE: 6.755V, TEMPERATURE: 37.15C, CURRENT: 0.176A
    [3.933] (0) RPM: 2758, PWR: 24, VOLTAGE: 6.755V, TEMPERATURE: 37.16C, CURRENT: 0.032A
    [3.956] (0) RPM: 2775, PWR: 24, VOLTAGE: 6.755V, TEMPERATURE: 37.16C, CURRENT: 0.120A
    [3.974] (0) RPM: 2821, PWR: 25, VOLTAGE: 6.752V, TEMPERATURE: 37.18C, CURRENT: 0.128A
    [3.993] (0) RPM: 2849, PWR: 25, VOLTAGE: 6.755V, TEMPERATURE: 37.18C, CURRENT: 0.152A
    [4.012] (0) RPM: 2877, PWR: 25, VOLTAGE: 6.755V, TEMPERATURE: 37.19C, CURRENT: 0.096A
    [4.037] (0) RPM: 2915, PWR: 25, VOLTAGE: 6.755V, TEMPERATURE: 37.17C, CURRENT: 0.080A
    [4.052] (0) RPM: 2938, PWR: 25, VOLTAGE: 6.754V, TEMPERATURE: 37.17C, CURRENT: 0.136A
    [4.072] (0) RPM: 2968, PWR: 25, VOLTAGE: 6.756V, TEMPERATURE: 37.19C, CURRENT: 0.176A
    [4.092] (0) RPM: 2997, PWR: 26, VOLTAGE: 6.756V, TEMPERATURE: 37.19C, CURRENT: 0.144A
    [4.112] (0) RPM: 3525, PWR: 10, VOLTAGE: 6.754V, TEMPERATURE: 37.18C, CURRENT: 0.112A
    [4.135] (0) RPM: 3525, PWR: 10, VOLTAGE: 6.755V, TEMPERATURE: 37.19C, CURRENT: 0.144A
    [4.152] (0) RPM: 3525, PWR: 10, VOLTAGE: 6.756V, TEMPERATURE: 37.17C, CURRENT: 0.048A
    [4.173] (0) RPM: 0, PWR: 0, VOLTAGE: 6.761V, TEMPERATURE: 37.16C, CURRENT: -0.032A
    [4.193] (0) RPM: 29, PWR: 0, VOLTAGE: 6.761V, TEMPERATURE: 37.18C, CURRENT: -0.024A
    [4.212] (0) RPM: 57, PWR: 1, VOLTAGE: 6.762V, TEMPERATURE: 37.18C, CURRENT: -0.080A
    [4.233] (0) RPM: 88, PWR: 1, VOLTAGE: 6.764V, TEMPERATURE: 37.17C, CURRENT: -0.032A
    It always spins up to speed then resets its power/goes to 0, I thought it was a soldering/wiring issue, but after re-soldering it to the board I am still facing the same issue. This is a recent issue likely after a VIO failure crash since it was working well beforehand. Do let me know if there is a software solution or re-calibration I should be doing for this new motor, or if a replacement can be provided, thanks!
    • J JoeAR_21
      [GCC 8.4.0]
      Hello @JoeAR_21 ,
      The debug log shows that the transition from the sinusoidal spin-up to closed-loop (based on back-emf) control is not working. There are several safety checks to prevent a bad motor from spinning up and the checks happen during this transition.
      Most likely the motor windings or leads are compromised, either one of the phases is disconnected or there may be a short between two phases.
      If you have a milliohm meter, you could accurately verify the phase resistance. A disconnected phase can be verified using a regular multi-meter by checking pairwise resistance between the 3 phases (should be the same and close to zero (in the range of 200-300 mOhm), depending on the specific motor used).
      While an ESC issue is also possible, however, it is less likely to occur during a crash, unless the ESC was mechanically damaged.
      J 1 Reply Last reply
        Hello @JoeAR_21 ,
        JoeAR_21
        @Alex-Kushleyev I will look into replacing the motors, is there anything I can do to prevent motor failures like this? my platform has been having a lot of QVIO failures
