  3. Starling 2: TOF sensor not recognized by VOXL Portal
starling
28 Posts 3 Posters 6.6k Views 1 Watching
    @Hector-Gutierrez , I am sorry, i was not able to access the image you shared. Can you please just resize / crop the image so that it fits into the forum? Just please make sure the details are still easy to see.
    Thank you!
    Hector GutierrezH Offline
    Hector Gutierrez
    @Alex-Kushleyev - Any updates on this thread ? Let me know if there is anything else I could try or if you consider this a hardware problem with the PMD sensor itself. Thanks, Hector
    • Hector GutierrezH Hector Gutierrez
      @Hector-Gutierrez , sorry about the delay.. Before submitting RMA (i will provide instructions), can you please share the output of dmesg after you run voxl-camera-server -l ? this will let me confirm that there is an attempt to ping the TOF sensor and it fails. You could save the output of dmesg into a text file and share it or paste it here.
      A successful dmesg output should look something like this (this is from a Starling 2 Max), which has an extra IMX412 camera:
      [ 1712.362675] CAM_ERR: CAM-MEM: cam_mem_mgr_create_debug_fs: 126 failed to create dentry
      [ 1712.383711] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
      [ 1712.393864] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
      [ 1712.393868] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
      [ 1712.393916] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
      [ 1712.470777] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.58
      [ 1712.472096] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.56
      [ 1712.474369] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.60
      [ 1712.474408] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.79
      [ 1712.498846] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:0,slave_addr:0x30,sensor_id:0x356
      [ 1712.498997] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.79
      [ 1712.502731] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.60
      [ 1712.502868] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.56
      [ 1712.502981] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.58
      [ 1712.526976] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.58
      [ 1712.527116] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.60
      [ 1712.527175] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.56
      [ 1712.527326] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.79
      [ 1712.541852] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:1,slave_addr:0x34,sensor_id:0x577
      [ 1712.541967] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.79
      [ 1712.543257] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.56
      [ 1712.543316] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.60
      [ 1712.543392] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.58
      [ 1712.561608] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
      [ 1712.563718] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
      [ 1712.565875] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
      [ 1712.567770] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
      [ 1712.575483] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:3,slave_addr:0x7a,sensor_id:0x2975
      [ 1712.577616] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
      [ 1712.579717] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
      [ 1712.579758] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
      [ 1712.579812] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
      [ 1712.604128] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.58
      [ 1712.606318] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.56
      [ 1712.608394] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.60
      [ 1712.608473] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.79
      [ 1712.631999] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:6,slave_addr:0x30,sensor_id:0x356
      [ 1712.632517] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.79
      [ 1712.636492] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.60
      [ 1712.636595] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.56
      [ 1712.636686] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.58
      [ 1712.662182] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.59
      [ 1712.662338] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.60
      [ 1712.662399] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.56
      [ 1712.662543] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
      [ 1712.677605] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:2,slave_addr:0x34,sensor_id:0x577
      [ 1712.677728] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
      [ 1712.679699] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.56
      [ 1712.679736] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.60
      [ 1712.679789] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.59
      [ 1712.739998] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
      Specifically, the following line says that the TOF sensor has been probed successfully:
      If the probe fails, you would see some CCI errors. If you do not see anything related to slave address 0x7a , the the sensor is not being probed and the issue is on the SW configuration side, which we can investigate further.
      Hector GutierrezH 2 Replies Last reply
        Hector Gutierrez
        @Alex-Kushleyev said in Starling 2: TOF sensor not recognized by VOXL Portal:
        Can you send me the syntax to get the dmesg output from voxl-camera-server -l ? I've tried a few options but I do not get an output that looks like the one you show. Thanks.
          Hector Gutierrez
          @Alex-Kushleyev : got the output of dmesg. It is too large to cut and paste here, but you can download the text file from this link:
          https://quickconnect.to/asapstorage/d/s/144lSyeQPPdNEZhCoWVCOjXUTudhlakC/Yfk8uh0E8Vk96kuc_96XHvRM6svAJSIF-bLWAR1fcaQw
          (dont click on the link: copy and paste to a browser window).
          Or send me the syntax to get a filtered output as you have above. Thanks.
            #25
            @Hector-Gutierrez
            You need to use the formatted text quote, click an icon above that looks like this: </>
            I dont think i can access the dmesg file you shared. Here is how you can generate a short version with just what i need to see:
            • run “dmesg -w” run view continuous out put from dmesg
            • press enter a few times to create a few empty lines that you can find later
            • run “voxl-camera-server -l” in another terminal
            • copy past just the new lines that appeared, which you should see based on the extra newlines you created
            Hector GutierrezH 1 Reply Last reply
              @Hector-Gutierrez
              Hector Gutierrez
              @Alex-Kushleyev : here is the output:
              [  206.798954] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a6:e5
              [  206.801089] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
              [  206.801105] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x40d00
              [  215.356522] CAM_INFO: CAM-CRM: cam_req_mgr_process_flush_req: 2177 Last request id to flush is 5890
              [  215.356586] CAM_INFO: CAM-ISP: __cam_isp_ctx_flush_req_in_top_state: 3046 Last request id to flush is 5890
              [  215.356694] CAM_INFO: CAM-ISP: __cam_isp_ctx_flush_req_in_top_state: 3069 Stop HW complete. Reset HW next.
              [  215.367444] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1117 CAM_STOP_DEV Success, sensor_id:0x356,sensor_slave_addr:0x30
              [  215.367450] CAM_INFO: CAM-CSIPHY: cam_csiphy_core_cfg: 982 STOP_DEV: CSIPHY_IDX: 0, Device_slot: 0, Datarate: 592000000, Settletime: 2800000000
              [  215.367473] CAM_INFO: CAM-ISP: cam_ife_mgr_release_hw: 4755 Release HW success ctx id: 2
              [  215.368902] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.79
              [  215.372057] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.60
              [  215.372072] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.56
              [  215.372085] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.58
              [  215.372128] CAM_INFO: CAM: cam_res_mgr_shared_pinctrl_put: 270 Need hold put this pinctrl
              [  215.372143] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1047 CAM_RELEASE_DEV Success, sensor_id:0x356,sensor_slave_addr:0x30
              [  216.395442] msm_vidc:   err : 00000002: h264e: msm_comm_flush: Already in flush
              [  216.508604] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1117 CAM_STOP_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
              [  216.508616] CAM_INFO: CAM-CSIPHY: cam_csiphy_core_cfg: 982 STOP_DEV: CSIPHY_IDX: 1, Device_slot: 0, Datarate: 1500000000, Settletime: 2200000000
              [  216.515038] CAM_INFO: CAM-ISP: cam_ife_mgr_release_hw: 4755 Release HW success ctx id: 0
              [  216.515922] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.79
              [  216.517960] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.56
              [  216.517973] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.60
              [  216.517986] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.58
              [  216.518049] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1047 CAM_RELEASE_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
              [  216.618202] CAM_INFO: CAM-CRM: cam_req_mgr_process_flush_req: 2177 Last request id to flush is 5927
              [  216.618268] CAM_INFO: CAM-ISP: __cam_isp_ctx_flush_req_in_top_state: 3046 Last request id to flush is 5927
              [  216.618374] CAM_INFO: CAM-ISP: __cam_isp_ctx_flush_req_in_top_state: 3069 Stop HW complete. Reset HW next.
              [  216.621881] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1117 CAM_STOP_DEV Success, sensor_id:0x356,sensor_slave_addr:0x30
              [  216.621891] CAM_INFO: CAM-CSIPHY: cam_csiphy_core_cfg: 982 STOP_DEV: CSIPHY_IDX: 2, Device_slot: 0, Datarate: 592000000, Settletime: 2800000000
              [  216.628363] CAM_INFO: CAM-ISP: cam_ife_mgr_release_hw: 4755 Release HW success ctx id: 3
              [  216.629040] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
              [  216.633125] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.60
              [  216.633166] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.56
              [  216.633212] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.59
              [  216.633667] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1047 CAM_RELEASE_DEV Success, sensor_id:0x356,sensor_slave_addr:0x30
              [  216.687846] CAM_INFO: CAM-CRM: cam_req_mgr_process_flush_req: 2177 Last request id to flush is 5930
              [  216.687904] CAM_INFO: CAM-ISP: __cam_isp_ctx_flush_req_in_top_state: 3046 Last request id to flush is 5930
              [  216.687998] CAM_INFO: CAM-ISP: __cam_isp_ctx_flush_req_in_top_state: 3069 Stop HW complete. Reset HW next.
              [  216.692371] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1117 CAM_STOP_DEV Success, sensor_id:0x356,sensor_slave_addr:0x30
              [  216.692383] CAM_INFO: CAM-CSIPHY: cam_csiphy_core_cfg: 982 STOP_DEV: CSIPHY_IDX: 0, Device_slot: 1, Datarate: 592000000, Settletime: 2800000000
              [  216.698841] CAM_INFO: CAM-ISP: cam_ife_mgr_release_hw: 4755 Release HW success ctx id: 1
              [  216.699769] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.79
              [  216.703840] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.60
              [  216.703886] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.56
              [  216.703919] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.58
              [  216.705006] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1047 CAM_RELEASE_DEV Success, sensor_id:0x356,sensor_slave_addr:0x30
              [  216.712597] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30080
              [  216.721134] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
              [  216.761711] msm_vidc:   high: 00000002: h264e: Closed video instance: ffffffeefdebe000
              [  216.761933] msm_vidc:   high: 00000001: h264e: Closed video instance: ffffffef0e100000
              [  216.884653] CAM_ERR: CAM-MEM: cam_mem_mgr_create_debug_fs: 126 failed to create dentry
              [  216.895769] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
              [  216.906058] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
              [  216.906072] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
              [  216.906084] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
              [  216.929300] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.58
              [  216.931458] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.56
              [  216.933569] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.60
              [  216.933607] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Linked as a consumer to regulator.79
              [  216.956534] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:0,slave_addr:0x30,sensor_id:0x356
              [  216.956636] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.79
              [  216.960823] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.60
              [  216.960951] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.56
              [  216.961062] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor0: Dropping the link to regulator.58
              [  216.986327] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.58
              [  216.986474] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.60
              [  216.986534] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.56
              [  216.986670] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Linked as a consumer to regulator.79
              [  217.000967] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:1,slave_addr:0x34,sensor_id:0x577
              [  217.001068] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.79
              [  217.003181] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.56
              [  217.003308] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.60
              [  217.003456] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.58
              [  217.029376] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.59
              [  217.031600] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.56
              [  217.033826] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.60
              [  217.033928] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
              [  217.057861] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:2,slave_addr:0x30,sensor_id:0x356
              [  217.058009] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
              [  217.062570] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.60
              [  217.062700] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.56
              [  217.062812] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.59
              [  217.085707] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
              [  217.087825] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
              [  217.089993] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
              [  217.092187] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
              [  217.695551] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a6:e5
              [  218.274338] msm_vidc:   err : ffffffff: .....: DBLP Set: status 0
              [  218.624174] CAM_ERR: CAM-CCI: cam_cci_read: 1320 wait_for_completion_timeout rc = -110 FIFO buf_lvl: 0x0
              [  220.128139] CAM_ERR: CAM-CCI: cam_cci_flush_queue: 53 wait timeout
              [  220.128236] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-110
              [  220.128248] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -110
              [  220.128262] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x2975:
              [  220.130622] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
              [  220.132521] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
              [  220.132641] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
              [  220.132787] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
              [  220.160433] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.58
              [  220.163839] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.56
              [  220.166217] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.60
              [  220.166422] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Linked as a consumer to regulator.79
              [  220.191299] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:6,slave_addr:0x30,sensor_id:0x356
              [  220.191460] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.79
              [  220.195732] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.60
              [  220.195860] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.56
              [  220.195969] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor6: Dropping the link to regulator.58
              [  220.255634] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
              [  229.072542] RTW: wlan0- hw port(0) mac_addr =00:c0:ca:b3:a6:e5
              Let me know what else is needed. Thanks, Hector
                @Hector-Gutierrez ,
                the following lines mean that the the system is trying to probe the TOF device by communicating with it via I2C (CCI), but the probe fails.
                Assuming the TOF sensor is actually connected (which we established), it is likely that there is a hardware issue somewhere between M0173 and the TOF sensor (inclusive). My recommendation is to submit an RMA request, referencing this post. You should request a new TOF sensor assembly and M0173 board just in case. Specifically,
                • qty 1 MSU-M0178-1-01
                • qty 1 MDK-M0173-1-00 (bare board)
                Once you receive these parts, you should first test the new TOF sensor assembly and if that works fine, please send back the bad TOF and the new M0173. If replacing the new TOF sensor still does not work, you may need to try the new M0173 board, carefully disconnecting and re-connecting the camera cables). In either case, please return the extra TOF and M0173 (one of which may be non-functional).
                If you do have another VOXL2 board, you could first try the new TOF with new M0173 and then the old (currently not working) TOF sensor, just to test that path before swapping M0173 on the Starling 2 drone.
                To fill out RMA request, please go to https://www.modalai.com/rma and fill out the form.
                Sorry for the inconvenience!
                  @Hector-Gutierrez ,
                  Hector Gutierrez
                  @Alex-Kushleyev - thanks, I submitted the RMA request, will let you know after I have the chance to replace and test the replacement parts.
                  Thanks, Hector
