  2. VOXL SDK and Software
  3. Micro-coax dual interposer board for M0166 cameras
camera
3 Posts 3 Posters 940 Views 2 Watching
  • S Offline
    S Offline
    SKA
    Is there a board available that is similar to the VOXL 2 Mini Dual High-res and Boson MIPI Adapter (MCCA-M0194-1) for tracking cameras?
    We are looking to connect 2 M0166 cameras to a VOXL 2 Mini as a synced stereo pair without using the M0173 board. Thanks!
    Alex KushleyevA VinnyV 2 Replies Last reply
    • S SKA
      Hello @SKA ,
      I will double check, but i do not think that we have what you are asking for. However, there is M0188 which will allow you to connect up to 4 M0166 tracking cameras and 2 M0161 hires cameras concurrently. Would that work for you? 🙂
      https://docs.modalai.com/M0188/
      https://www.modalai.com/products/m0188
      Please note that if you use M0188, you will need to install the VOXL2 mini sdk and select the variant that supports M0188 (it uses a different kernel to map all the camera IO correctly).
      • S SKA
        VinnyV Offline
        VinnyV Offline
        Vinny
        Hi @SKA
        Alex's instincts are correct, we do not have a smaller plug in board for just tracking in a synce'd config. We only had an M0155 for one image sensor for a while, so your best bet is what Alex said and get the new M0188 for VOXL 2 Mini (VOXL 2 uses M0173, whereas VOXL 2 Mini uses M0188)
        It's quite cost competitive for what it does!!
        https://www.modalai.com/collections/all/products/m0188
