    Error in VOXL mini 4 in 1 ESC diagram
    VOXL Compute & Autopilot
    • h3roboticsH
      h3robotics
      I am having strange issues with the VOXL2. I had hooked it up with a 4-in-1 mini ESC using the diagram here: https://docs.modalai.com/images/d0014/CWD-D0014-4-CXX-M22-TX-REV2.jpg. It turns out there is an error on the way wiring is shown (see the red circle):
      With that wiring, I was unable to get the LTE v2 pro modem working. It was not being detected. I was also not able to get any battery info.
      Now I have fixed the wiring as per the pinout of the connectors. But I am seeing the following issues:
      • still I am not able to detect the LTE v2 modem.
      • still no battery info. When I try to manually stop/start the "voxl_esc" driver in PX4 mavlink console, it gives me errors and fails to start.
      • ADB over usb C does not work if the ESC UART connector J18 is not plugged into the VOXL 2.
      Can you help me? I hope nothing is burnt/ broken due to the error in wiring above 😞
      • h3roboticsH h3robotics referenced this topic on
        Alex Kushleyev ModalAI Team @h3robotics
        @h3robotics The diagram has been fixed. Thank you for reporting it.
        https://docs.modalai.com/voxl2-d0014/
        We will continue working on your issue in another thread.
        h3roboticsH 1 Reply Last reply Reply Quote 0
        • h3roboticsH
          h3robotics @Alex Kushleyev
          @Alex-Kushleyev the RX and TX lines need to be swapped at the J18 connector as well, please 🙂
            @h3robotics , Thank you, you are right again. We will update!
