  3. Error in VOXL mini 4 in 1 ESC diagram
4 Posts 2 Posters 3.3k Views 1 Watching
  • h3roboticsH Offline
    h3roboticsH Offline
    h3robotics
    I am having strange issues with the VOXL2. I had hooked it up with a 4-in-1 mini ESC using the diagram here: https://docs.modalai.com/images/d0014/CWD-D0014-4-CXX-M22-TX-REV2.jpg. It turns out there is an error on the way wiring is shown (see the red circle):
    With that wiring, I was unable to get the LTE v2 pro modem working. It was not being detected. I was also not able to get any battery info.
    Now I have fixed the wiring as per the pinout of the connectors. But I am seeing the following issues:
    • still I am not able to detect the LTE v2 modem.
    • still no battery info. When I try to manually stop/start the "voxl_esc" driver in PX4 mavlink console, it gives me errors and fails to start.
    • ADB over usb C does not work if the ESC UART connector J18 is not plugged into the VOXL 2.
    Can you help me? I hope nothing is burnt/ broken due to the error in wiring above 😞
    • h3roboticsH h3robotics referenced this topic on
      @h3robotics The diagram has been fixed. Thank you for reporting it.
      https://docs.modalai.com/voxl2-d0014/
      We will continue working on your issue in another thread.
      h3roboticsH 1 Reply Last reply
        h3roboticsH Offline
        h3roboticsH Offline
        h3robotics
        @Alex-Kushleyev the RX and TX lines need to be swapped at the J18 connector as well, please 🙂
          @h3robotics , Thank you, you are right again. We will update!
