  2. Software Development
  3. ROS
  4. VOXL2 ROS2 Starling Code Inconsistencies
14 Posts 3 Posters 7.3k Views
  • G Offline
    G Offline
    GlennTee
    wrote on last edited by GlennTee
    Hello, I'm running the PX4 ROS2 offboard control example from https://docs.px4.io/main/en/ros2/offboard_control.html#foxy and am having some inconsistent behavior. When I run the program, the drone arms, takes off, and lands as expected. However, during subsequent runs, the drone never arms (The props never spin at all), but the program still continues running as indicated by the print statements that show up. Sometimes, if I close the terminal and run the program again in a new terminal, this problem is fixed as the drone will arm and fly most times, but not always. Am I missing something that cleanly shuts down after running? I'm running the code shown below:
    #!/usr/bin/env python3
    import rclpy
    from rclpy.node import Node
    from rclpy.qos import QoSProfile, ReliabilityPolicy, HistoryPolicy, DurabilityPolicy
    from px4_msgs.msg import OffboardControlMode, TrajectorySetpoint, VehicleCommand, VehicleLocalPosition, VehicleStatus
    import time
    import math
    class OffboardControl(Node):
    """Node for controlling a vehicle in offboard mode."""
    def __init__(self) -> None:
        super().__init__('offboard_control_takeoff_and_land')
        # Configure QoS profile for publishing and subscribing
        qos_profile = QoSProfile(
            reliability=ReliabilityPolicy.BEST_EFFORT,
            durability=DurabilityPolicy.TRANSIENT_LOCAL,
            history=HistoryPolicy.KEEP_LAST,
            depth=1
        # Create publishers
        self.offboard_control_mode_publisher = self.create_publisher(
            OffboardControlMode, '/fmu/in/offboard_control_mode', qos_profile)
        self.trajectory_setpoint_publisher = self.create_publisher(
            TrajectorySetpoint, '/fmu/in/trajectory_setpoint', qos_profile)
        self.vehicle_command_publisher = self.create_publisher(
            VehicleCommand, '/fmu/in/vehicle_command', qos_profile)
        # Create subscribers
        self.vehicle_local_position_subscriber = self.create_subscription(
            VehicleLocalPosition, '/fmu/out/vehicle_local_position', self.vehicle_local_position_callback, qos_profile)
        self.vehicle_status_subscriber = self.create_subscription(
            VehicleStatus, '/fmu/out/vehicle_status', self.vehicle_status_callback, qos_profile)
        # Initialize variables
        self.offboard_setpoint_counter = 0
        self.vehicle_local_position = VehicleLocalPosition()
        self.vehicle_status = VehicleStatus()
        self.takeoff_height = -1.0
        # Create a timer to publish control commands
        self.timer = self.create_timer(0.1, self.timer_callback)
    def vehicle_local_position_callback(self, vehicle_local_position):
        """Callback function for vehicle_local_position topic subscriber."""
        self.vehicle_local_position = vehicle_local_position
    def vehicle_status_callback(self, vehicle_status):
        """Callback function for vehicle_status topic subscriber."""
        self.vehicle_status = vehicle_status
    def arm(self):
        """Send an arm command to the vehicle."""
        self.publish_vehicle_command(
            VehicleCommand.VEHICLE_CMD_COMPONENT_ARM_DISARM, param1=1.0)
        self.get_logger().info('Arm command sent')
    def disarm(self):
        """Send a disarm command to the vehicle."""
            VehicleCommand.VEHICLE_CMD_COMPONENT_ARM_DISARM, param1=0.0)
        self.get_logger().info('Disarm command sent')
    def engage_offboard_mode(self):
        """Switch to offboard mode."""
            VehicleCommand.VEHICLE_CMD_DO_SET_MODE, param1=1.0, param2=6.0)
        self.get_logger().info("Switching to offboard mode")
    def land(self):
        """Switch to land mode."""
        self.publish_vehicle_command(VehicleCommand.VEHICLE_CMD_NAV_LAND)
        self.get_logger().info("Switching to land mode")
    def publish_offboard_control_heartbeat_signal(self):
        """Publish the offboard control mode."""
        msg = OffboardControlMode()
        msg.position = True
        msg.velocity = False
        msg.acceleration = False
        msg.attitude = False
        msg.body_rate = False
        msg.timestamp = int(self.get_clock().now().nanoseconds / 1000)
        self.offboard_control_mode_publisher.publish(msg)
    def publish_position_setpoint(self, x: float, y: float, z: float):
        """Publish the trajectory setpoint."""
        msg = TrajectorySetpoint()
        msg.position = [x, y, z]
        msg.yaw = 1.57079  # (90 degree)
        self.trajectory_setpoint_publisher.publish(msg)
        self.get_logger().info(f"Publishing position setpoints {[x, y, z]}")
    def publish_vehicle_command(self, command, **params) -> None:
        """Publish a vehicle command."""
        msg = VehicleCommand()
        msg.command = command
        msg.param1 = params.get("param1", 0.0)
        msg.param2 = params.get("param2", 0.0)
        msg.param3 = params.get("param3", 0.0)
        msg.param4 = params.get("param4", 0.0)
        msg.param5 = params.get("param5", 0.0)
        msg.param6 = params.get("param6", 0.0)
        msg.param7 = params.get("param7", 0.0)
        msg.target_system = 1
        msg.target_component = 1
        msg.source_system = 1
        msg.source_component = 1
        msg.from_external = True
        self.vehicle_command_publisher.publish(msg)
    def timer_callback(self) -> None:
        """Callback function for the timer."""
        self.publish_offboard_control_heartbeat_signal()
        if self.offboard_setpoint_counter == 10:
            self.engage_offboard_mode()
            self.arm()
        if self.vehicle_local_position.z > self.takeoff_height and self.vehicle_status.nav_state == VehicleStatus.NAVIGATION_STATE_OFFBOARD:
            self.publish_position_setpoint(0.0, 0.0, self.takeoff_height)
        elif self.vehicle_local_position.z <= self.takeoff_height:
            self.land()
            exit(0)
        if self.offboard_setpoint_counter < 11:
            self.offboard_setpoint_counter += 1
    def main(args=None) -> None:
    print('Starting offboard control node...')
    rclpy.init(args=args)
    offboard_control = OffboardControl()
    rclpy.spin(offboard_control)
    offboard_control.destroy_node()
    rclpy.shutdown()
    if name == 'main':
    try:
    main()
    except Exception as e:
    print(e)
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      Hi @GlennTee - will try and recreate this and get back to yuo!
      C 1 Reply Last reply
        C Offline
        C Offline
        claw
        @Zachary-Lowell-0 Any luck recreating this?
          Zachary Lowell 0
          @Zachary-Lowell-0 said in VOXL2 ROS2 Starling Code Inconsistencies:
          C
          1 Reply Last reply 10 minutes ago Reply
          planning on trying to recreate tomorrow in the AM - have you tested this via HITL at all as well?
            C
            C Offline
            C Offline
            claw
            @Zachary-Lowell-0 No, we're novices and trying to just focus on the Starling. HITL, would be a distraction (unless you say differently) from the task at hand.
              Zachary Lowell 0
              @claw no worries - I recorded a loom for you watch - https://www.loom.com/share/409b4b9ca9974d54b534af7020414632 - please give it a gander and lmk if it helps - I have a strong feeling its because there is NOT a sleeper call for a second or two between swapping to offboard and arming the drone.
              Also HITL/SITL testing by far and away is the standard to do first before moving to a drone especially with some experimental code - I would heavily emphasize you always debug first in this scenario before moving to the real bird - purely really just for safety reasons. Anyways, please give a watch and let me know!!
              Zach
                Zachary Lowell 0
                oh also please ensure you have offboard_figure_8 set to off in voxl-vision-hub.conf in /etc/modalai.
                G 2 Replies Last reply
                  G Offline
                  G Offline
                  GlennTee
                  @Zachary-Lowell-0 Thank you so much, this appears to have fixed it! I'm now able to consistently run and exit the program cleanly.
                    G Offline
                    G Offline
                    GlennTee
                    #9
                    @Zachary-Lowell-0 I do have another question: would you happen to know of any resources or examples involving April Tag detection and alignment using the VOXL2 ROS2 PX4 Starling? My goal is to try to use my drone to detect an April Tag, align with it, and land on it. Preferably, I would like to do this in Python if possible.
                    G 1 Reply Last reply
                    • G GlennTee
                      G Offline
                      G Offline
                      GlennTee
                      I also was wondering if there also a way to read the battery voltage? In my case, I want to be able to read the battery voltage in my code in able to tell the drone to do specific things based on if the voltage is high or low.
                        Zachary Lowell 0
                        @GlennTee said in VOXL2 ROS2 Starling Code Inconsistencies:
                        @GlennTee on the voxl2 there is a program called voxl-tag-detection that will detect tags in the h36 family. You can also detect battery via voxl-inspect-battery - the reason I bring these pipes up is because you can leverage them in your ros2 code via C++ nodes. So you can create a node in CPP that will subscribe to these modalAI MPA pipes and then publish the data into a ros2 topic.
                        LMK if that helps - we actually did just merge in a branch of voxl-mpa-to-ros2 that will publish the tag information over a ros2 interface. In theory you can do the same with battery voltage: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/blob/dev/colcon_ws/src/voxl_mpa_to_ros2/src/interfaces/tag_interface.cpp?ref_type=heads
                        Zach
                        G C 2 Replies Last reply
                          Zach
                          G Offline
                          G Offline
                          GlennTee
                          @Zachary-Lowell-0 Thank you so much, I will try that out!
                            Zach
                            C Offline
                            C Offline
                            claw
                            @Zachary-Lowell-0 Thank you for your help and guidance. Is there a way to get the status information like battery voltage using Python?
                              Zachary Lowell 0
                              @claw said in VOXL2 ROS2 Starling Code Inconsistencies:
                              @claw yes you can follow this post to get battery over the DDS: https://forum.modalai.com/topic/4353/voxl2-px4-ros2-mpa-to-ros2-for-battery-voltage-problems/12?_=1745355297145
