  3. SeekThermal camera integration on VOXL2 Starling
4 Posts 2 Posters 737 Views 2 Watching
  • B Offline
    B Offline
    buem799
    Hi devs,
    I was trying to get a SeekThermal camera running through the VOXL drone. It's a model that is NOT listed on the supported devices but I still wanted to try because it would be a good middle ground option between the FLIR Lepton and Boson. I am aware that since it's not supported officially that there's no guarantee for it to work but I still wanted to quickly ask if you had any ideas that could maybe fix the fact that the VOXL2 Starling doesn't recognise the camera even after installing their SDK which is supposed to work on the VOXL architecture. (The 289d:0011 is the camera)
    On my laptop it looks like this:
    And when I run a script given by SeekThermal I get the following error:
    Thanks in advance
    • B buem799
      Hi devs,
      Thanks in advance
      Eric KatzfeyE Online
      @buem799 Yes, we use Seek camera but we do not support it externally yet. We have to run it in a Docker since the native VOXL 2 environment does not support the Seek SDK.
      B 1 Reply Last reply
        B Offline
        B Offline
        buem799
        @Eric-Katzfey Thanks for the info. Does that mean it would also be possible for me to access the SeekThermal if I set up the docker like you?
        If that's the case would you be so kind as to provide the docker image and whatever else I need or is that not publicly available?
        • B buem799
          @buem799 Yes, you would be able to use Seek. We do not currently support this, it's just some internal stuff we are using for Seek evaluation and development. Here is the contents of our Dockerfile, hopefully this is helpful to you.
          FROM arm64v8/ubuntu:focal
          WORKDIR /home
          RUN apt-get update
          RUN DEBIAN_FRONTEND=noninteractive apt-get install -y cmake libopencv-dev libusb-1.0-0-dev
          RUN DEBIAN_FRONTEND=noninteractive apt-get install -y git
          RUN DEBIAN_FRONTEND=noninteractive apt-get install -y g++ vim
          # This will update if there have been any updates to the voxl-dev branch and force a new git clone
          # ADD https://api.github.com/repos/modalai/libseek-thermal/git/refs/heads/dev version.json
          RUN git clone https://github.com/modalai/libseek-thermal.git
          RUN mkdir libseek-thermal/build
          WORKDIR /home/libseek-thermal/build
          RUN cmake ..
          RUN make
          RUN make install
          RUN ldconfig
          WORKDIR /home
          COPY Seek_Thermal_SDK_4.4.2.20.zip .
          RUN DEBIAN_FRONTEND=noninteractive apt-get install -y zip
          RUN unzip Seek_Thermal_SDK_4.4.2.20.zip
          RUN rm Seek_Thermal_SDK_4.4.2.20.zip
          RUN DEBIAN_FRONTEND=noninteractive apt-get install -y libsdl2-dev
          WORKDIR /home/Seek_Thermal_SDK_4.4.2.20/aarch64-linux-gnu
          RUN DEBIAN_FRONTEND=noninteractive apt-get install -y usbutils
          RUN DEBIAN_FRONTEND=noninteractive apt-get install -y udev
          RUN cp lib/libseekcamera.so /usr/local/lib
          RUN cp -r include/* /usr/local/include
          RUN mkdir -p /etc/udev
          RUN cp driver/udev/10-seekthermal.rules /etc/udev/rules.d
          # RUN udevadm control --reload
          RUN chmod a+x bin/*
          WORKDIR /home/Seek_Thermal_SDK_4.4.2.20/aarch64-linux-gnu/examples/build
          RUN cmake ..
          RUN make
          WORKDIR /home
          COPY libmodal-json*.deb .
          RUN dpkg -i libmodal-json*.deb
          RUN rm libmodal-json_*.deb
          COPY libmodal-pipe*.deb .
          RUN dpkg -i libmodal-pipe*.deb
          RUN rm libmodal-pipe*.deb
          ENV LD_LIBRARY_PATH=/usr/lib64
          WORKDIR /usr/local/workspace
