  3. Clarification on Starling2 (C27) Specifications and Propeller Compatibility
3 Posts 2 Posters 803 Views
  • C Offline
    C Offline
    coreyazion
    Dear ModalAI Team,
    We are in the process of purchasing the Starling2 (C27) and have a few questions that require clarification.
    1. Import Clearance Information Requirements
    We need to provide the following details for import clearance, but we were unable to find them on the Starling2 datasheet or the product page:
    • Dimensions (Height, Width, Length)
    • Maximum speed of the drone
    Could you kindly provide these specifications?
    Additionally, regarding the weight of the drone, the datasheet lists it as 285g, while the product page states 280g. Could you confirm which figure more accurately reflects the weight of the C27 Starling2?
    2. Propeller Specifications
    Based on this discussion, it appears that the Replacement Starling Propellers (set of 4) are compatible with Starling2 and that they are DJI 4726 propellers. Could you confirm if this information is correct?
    We appreciate your assistance and look forward to your response.
    JacobJ 1 Reply Last reply
    • C coreyazion
      Dear ModalAI Team,
      JacobJ Offline
      JacobJ Offline
      Jacob
      wrote on last edited by Jacob
      @coreyazion Hello!
      Thank you for reaching out, I have some of this information and have asked relevant parties to gather the rest.
      We have a detailed CAD Model available to download for the Starling 2, which is referenced near the bottom of that Datasheet. You can hide and show any of the components at will to get exact measurements in any configuration you create for it.
      Center to center for motors is 132mm length, and 176mm width. The props themselves will cause it to be larger. The props are about 60mm long (from center of screw) and are themselves about 7.5mm away from the center of the motor to center of the prop mounting screw. So with props fully extended, the total length x width would be 267mm x 311mm. Height is about 86mm, from the top of the GPS hoop to the bottom of the feet.
      Folded up and with the prop retainers on, it is 154.200mm x 198.200mm x 86.279mm.
      I have reached out for: Maximum Speed, Weight (with and without prop retainers), prop manufacturer.
      My best guess as to the weight being off by 5g is one of them measured with the prop retainers one, and one without. For flight, they come off and I believe would be the 280g. If in storage with them on, closer to the 285g.
      C 1 Reply Last reply
      • JacobJ Jacob
        @coreyazion Hello!
        C Offline
        C Offline
        coreyazion
        Thank you for your detailed response!
        It has already addressed much of the urgent information we needed.
        We look forward to receiving more details on the props and speed.
