  2. VOXL SDK and Software
  3. RTSP connection from drone unreliable since update to SDK 1.4.1
starling2 maxrtspvoxl-streamervoxl-sdk
4 Posts 2 Posters 2.1k Views 2 Watching
  • G Offline
    G Offline
    griffin
    Since updating from SDK 1.3.5 to 1.4.1 on a starling 2 max I am experiencing intermittent issues when connecting to the RTSP streams from the drone. Sometimes these connect quickly with no issues, other times they hang on waiting for progress to finish in the gstream pipeline. For example, running the command gst-launch-1.0 rtspsrc location=rtsp://192.168.254.138:8901/live latency=0 ! rtph264depay ! avdec_h264 ! videoconvert ! autovideosink may result in:
    Setting pipeline to PAUSED ...
    Pipeline is live and does not need PREROLL ...
    Progress: (open) Opening Stream
    Pipeline is PREROLLED ...
    Prerolled, waiting for progress to finish...
    Progress: (connect) Connecting to rtsp://192.168.254.138:8901/live
    ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not open resource for reading and writing.
    Additional debug info:
    ../gst/rtsp/gstrtspsrc.c(8130): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
    Failed to connect. (Generic error)
    ERROR: pipeline doesn't want to preroll.
    Setting pipeline to NULL ...
    Freeing pipeline ...
    after significant delay. These errors seem to correlate with how long the system has been on. Additionally, the VOXL 2 boards now get extremely hot and seem to be under significant load
    G 1 Reply Last reply
    • G griffin
      G Offline
      G Offline
      griffin
      When this does occurs I see nothing unusual in the systemctl status messages:
      ● voxl-streamer-hires-down.service - voxl-streamer
         Loaded: loaded (/usr/bin/voxl-streamer; enabled; vendor preset: enabled)
         Active: active (running) since Thu 2025-02-27 23:48:55 UTC; 15min ago
        Process: 1479 ExecStartPre=/bin/sleep 5 (code=exited, status=0/SUCCESS)
       Main PID: 1955 (voxl-streamer)
          Tasks: 2 (limit: 4915)
         CGroup: /system.slice/voxl-streamer-hires-down.service
                 └─1955 /usr/bin/voxl-streamer -s -p 8901 -i hires_down_small_encoded
      Feb 27 23:48:55 m0054 voxl-streamer[1955]: w: 1024 h: 768 fps: 30 format: H264
      Feb 27 23:48:55 m0054 voxl-streamer[1955]: Stream available at rtsp://127.0.0.1:8901/live
      Feb 28 00:02:55 m0054 voxl-streamer[1955]: A new client rtsp://192.168.254.44:52848(null) has connected, total clients: 1
      Feb 28 00:02:55 m0054 voxl-streamer[1955]: Camera server Connected
      Feb 28 00:04:03 m0054 voxl-streamer[1955]: rtsp client disconnected, total clients: 0
      Feb 28 00:04:03 m0054 voxl-streamer[1955]: no more rtsp clients, closing source pipe intentionally
      Feb 28 00:04:04 m0054 voxl-streamer[1955]: A new client rtsp://192.168.254.44:38768(null) has connected, total clients: 1
      Feb 28 00:04:04 m0054 voxl-streamer[1955]: Camera server Connected
      Feb 28 00:04:10 m0054 voxl-streamer[1955]: rtsp client disconnected, total clients: 0
      Feb 28 00:04:10 m0054 voxl-streamer[1955]: no more rtsp clients, closing source pipe intentionally
      voxl-inspect-cpu returns:
      Name   Freq (MHz) Temp (C) Util (%)
      cpu0       1075.2     85.3    19.45
      cpu1       1075.2     84.1    10.51
      cpu2       1075.2     84.1    12.28
      cpu3       1075.2     84.9    10.03
      cpu4        710.4     84.9    19.34
      cpu5        710.4     86.1    20.54
      cpu6        710.4     84.5    19.73
      cpu7        844.8     84.9     4.80
      Total                 84.9    14.59
      10s avg                       15.06
      small cores only              13.07
      big cores only                16.11
      GPU         587.0     80.7     7.43
      GPU 10s avg                    7.31
      memory temp:       85.3 C
      memory used:  4195/7671 MB
      Flags
      CPU freq scaling mode: auto
      Standby Not Active
      and top:
      top - 00:07:09 up 10 min,  0 users,  load average: 3.28, 2.91, 1.67
      Tasks: 476 total,   2 running, 300 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 15.0 us, 14.0 sy,  0.0 ni, 67.3 id,  0.0 wa,  2.8 hi,  0.9 si,  0.0 st
      KiB Mem :  7855496 total,  2772832 free,  4527956 used,   554708 buff/cache
      KiB Swap:  3927744 total,  3927744 free,        0 used.  3552948 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
       1461 root     -81   0 8650380 231620  66028 S 114.9  2.9  11:17.22 voxl-camera-ser
       2134 root     -51   0 1345204 107148  39084 S  77.2  1.4   7:28.22 voxl-open-vins-
       1751 root      20   0 1011024  92336  11144 S  26.8  1.2   2:39.99 px4
       1915 root      20   0  269308   6100   5524 S   4.3  0.1   0:25.73 voxl-mavlink-se
       1503 root      20   0  852088  11892   6696 S   3.3  0.2   0:21.72 voxl-vision-hub
        366 root      20   0       0      0      0 I   2.6  0.0   0:05.38 kworker/u16:11-
       1953 root      20   0  617468  15208   9424 S   2.3  0.2   0:07.13 voxl-streamer
        407 root      20   0       0      0      0 I   2.0  0.0   0:03.25 kworker/u16:14-
        408 root      20   0       0      0      0 I   2.0  0.0   0:04.61 kworker/u16:15-
       1592 root      -2   0       0      0      0 S   1.7  0.0   0:10.26 qrtr_rx
        262 root      -3   0       0      0      0 S   1.3  0.0   0:06.29 kgsl_worker_thr
       1673 root     -81   0  195696   6204   5624 S   1.3  0.1   0:07.66 voxl-imu-server
       1813 root       0 -20       0      0      0 I   1.3  0.0   0:04.09 kworker/u17:8-c
       2179 root      20   0       0      0      0 I   1.0  0.0   0:04.12 kworker/u18:2-k
       2211 root      20   0       0      0      0 I   1.0  0.0   0:03.58 kworker/u18:4-q
      21475 root       0 -20       0      0      0 I   1.0  0.0   0:02.39 kworker/u17:0-c
      30554 root      20   0       0      0      0 I   1.0  0.0   0:02.28 kworker/u18:6-k
         48 root      20   0       0      0      0 S   0.7  0.0   0:02.29 rcuop/4
       1183 logd      30  10  382204   3076   2504 S   0.7  0.0   0:03.33 logd
       1279 root      20   0   97136   7620   6976 S   0.7  0.1   0:03.49 voxl-rangefinde
       2146 root      20   0       0      0      0 I   0.7  0.0   0:02.28 kworker/u18:0-k
         10 root      20   0       0      0      0 S   0.3  0.0   0:02.20 ksoftirqd/0
         11 root      20   0       0      0      0 I   0.3  0.0   0:02.37 rcu_preempt
         21 root      20   0       0      0      0 S   0.3  0.0   0:01.98 ksoftirqd/1
         29 root      20   0       0      0      0 S   0.3  0.0   0:01.95 ksoftirqd/2
         32 root      20   0       0      0      0 S   0.3  0.0   0:00.40 rcuop/2
         37 root      20   0       0      0      0 S   0.3  0.0   0:02.04 ksoftirqd/3
         56 root      20   0       0      0      0 S   0.3  0.0   0:01.03 rcuop/5
         62 root      20   0       0      0      0 I   0.3  0.0   0:00.67 kworker/6:0-eve
         64 root      20   0       0      0      0 S   0.3  0.0   0:01.59 rcuop/6
         89 root      20   0       0      0      0 S   0.3  0.0   0:02.05 qmp_aop
        301 root      rt   0       0      0      0 S   0.3  0.0   0:01.34 spi3
       1449 root      20   0       0      0      0 I   0.3  0.0   0:00.70 kworker/4:3-eve
       1465 root      20   0   18868   1616   1472 S   0.3  0.0   0:02.68 voxl-cpu-monito
       1472 root      20   0    6780   3660   3316 S   0.3  0.0   0:01.64 voxl-portal
      The cpu load seems to be quite high, noticeably higher than before updating.
      • G griffin
        Total                 84.9    14.59
        10s avg                       15.06
        GPU         587.0     80.7     7.43
        GPU 10s avg                    7.31
        memory temp:       85.3 C
        Flags
        Standby Not Active
        and top:
        G Offline
        G Offline
        griffin
        @Alex-Kushleyev @tom any response or advice?
        • G griffin
          @griffin , this seems like an network issue. So please try the following:
          • open a terminal and just run the following command to "inspect" the hires stream so that it is always going and you can check if it's running any time : voxl-inspect-cam hires_down_small_encoded
          • start a continuous ping test from your host that is trying to receive the video feed
          • keep testing the video feed until you see the issue occur and check if ping is dropping out and double check voxl-inspect-cam output to make sure the data is flowing.
          What i expect is the output of voxl-inspect-cam should be continuously updating and you may see ping having trouble. Please let me know what you observe.
          Regarding the voxl2 heating up, i will check with the team. open-vins-server is running (VIO) and it has been recently updated to use GPU for feature detection, so a slight increase in voxl2 temperature may be possible.
