  2. VOXL SDK and Software
  3. Image Metadata from Snahsopt doesn't match Camera Specs from Datasheet
voxl-sdk
2 Posts 2 Posters 593 Views 2 Watching
  • M Offline
    M Offline
    m1baldwin
    wrote on last edited by m1baldwin
    We use the snapshot feature of voxl-camera-server to capture images while the drone is flying.
    As far as I understood the camera specs are encoded in this file: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/master/misc_files/usr/share/modalai/voxl-camera-server/camera_config.xml?ref_type=heads
    We use IMX412, and it has 2.7mm focal length
    But for example, we see the following when analze the exif data from an image (focal length is 2.2mm, fnumber is 2.4 but should be 3.2)
    File Type : JPEG
    File Type Extension : jpg
    MIME Type : image/jpeg
    JFIF Version : 1.01
    Exif Byte Order : Big-endian (Motorola, MM)
    Make : QTI-AA
    Camera Model Name : QCAM-AA
    Orientation : Horizontal (normal)
    X Resolution : 72
    Y Resolution : 72
    Resolution Unit : inches
    Modify Date : 2025:02:18 06:15:38
    Y Cb Cr Positioning : Centered
    Exposure Time : 1/133
    F Number : 2.4
    Exposure Program : Manual
    ISO : 100
    Exif Version : 0220
    Date/Time Original : 2025:02:18 06:15:38
    Create Date : 2025:02:18 06:15:38
    Components Configuration : Y, Cb, Cr, -
    Shutter Speed Value : 1/133
    Aperture Value : 2.4
    Brightness Value : 4.67
    Exposure Compensation : 0
    Max Aperture Value : 2.4
    Metering Mode : Average
    Light Source : D65
    Flash : Off, Did not fire
    Focal Length : 2.2 mm
    User Comment :
    Sub Sec Time : 407662
    Sub Sec Time Original : 407662
    Sub Sec Time Digitized : 407662
    Flashpix Version : 0100
    Color Space : sRGB
    Exif Image Width : 4056
    Exif Image Height : 3040
    Sensing Method : Not defined
    Exposure Mode : Manual
    White Balance : Manual
    Focal Length In 35mm Format : 2 mm
    Scene Capture Type : Standard
    Interoperability Index : R98 - DCF basic file (sRGB)
    Compression : JPEG (old-style)
    Thumbnail Offset : 2206
    Thumbnail Length : 21199
    Image Width : 4056
    Image Height : 3040
    Encoding Process : Baseline DCT, Huffman coding
    Bits Per Sample : 8
    Color Components : 3
    Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
    Aperture : 2.4
    Image Size : 4056x3040
    Megapixels : 12.3
    Scale Factor To 35 mm Equivalent: 0.9
    Shutter Speed : 1/133
    Create Date : 2025:02:18 06:15:38.407662
    Date/Time Original : 2025:02:18 06:15:38.407662
    Modify Date : 2025:02:18 06:15:38.407662
    Thumbnail Image : (Binary data 21199 bytes, use -b option to extract)
    Circle Of Confusion : 0.033 mm
    Field Of View : 167.3 deg
    Focal Length : 2.2 mm (35 mm equivalent: 2.0 mm)
    Hyperfocal Distance : 0.06 m
    Light Value : 9.6
    • M m1baldwin
      File Type : JPEG
      JFIF Version : 1.01
      Make : QTI-AA
      X Resolution : 72
      Y Resolution : 72
      F Number : 2.4
      ISO : 100
      Exif Version : 0220
      Light Source : D65
      User Comment :
      Color Space : sRGB
      Image Width : 4056
      Image Height : 3040
      Bits Per Sample : 8
      Aperture : 2.4
      Megapixels : 12.3
      Light Value : 9.6
      Hi @m1baldwin , are you using VOXL1 and VOXL2 ?
