  2. Software Development
  3. GPS-denied Navigation (VIO)
  4. OpenVINS Reinitializing Issue
Scheduled Pinned Locked Moved GPS-denied Navigation (VIO)
7 Posts 2 Posters 1.6k Views
  • S Offline
    S Offline
    SKA
    OpenVINS starts up as expected, then starts reinitializing repeatedly. The intrinsics and extrinsics are set up and working as expected with qvio.
    Running voxl-open-vins-server -d, I get the following:
    ====> Using EXTERNAL feature tracker <====
    >>>>>>>>>> Current reference counts:
    trackDB: 1
    trackFEATS: 1
    propagator: 2
    updaterMSCKF: 1
    updaterSLAM: 1
    active_tracks_initializer: 1
    initializer: 1
    thread is locked to cores: 4 5 6 7
    create_server_pipes
    connecting client pipes
    imu pipe name: imu_apps
    Number of Cameras active: 1
    Camera merge --- > ch: 1 to cam id: 0
    Opening camera pipe: tracking
    tmp_camera_pipe_names.push_back(): tracking
    VFT connected
    client "voxl-portal38440978" connected to overlay
    [INFO] world : 1.000000 1.000000  (2)
    FAILED TO FETCH IMG RINGBUF at time 0 -2 -2 -2 -2 -2
    [THERMAL] Resume processing done
    [ERROR] In init too long, timeout, retry  RESET 5012286699
    [ERROR] Triggered RESET type: 4
    [INFO] restarting managers STATELESS
    Set camera intrinsics and extrinsics
    How can I get past the reinitializing issue and run OpenVINS?
    • Cliff WongC Offline
      Cliff WongC Offline
      Cliff Wong
      wrote on last edited by Cliff Wong
      Hi there, typically when OVINS is resetting constantly, that means there's no image stream or feature data being sent to it. Since we see a video the image stream is ok.
      You want to run in a adb shell:
      a. cat /etc/modalai/voxl-open-vins-server.conf and confirm en_ext_feature_tracker: true
      b. run voxl-inspect-services and ensure voxl-feature-tracker is running. You can also check voxl-portal and confirm a feature_overlay video feed is present.
      c. then restart voxl-open-vins-server -d as you did above.
      The drone should be on a level surface when ovins is initializing.
      If that doesn't work, can you post your /etc/modalai/vio_cams.conf.
      S 1 Reply Last reply
      • Cliff WongC Cliff Wong
        S Offline
        S Offline
        SKA
        @Cliff-Wong Thanks for your response! I have en_ext_feature_tracker: true. I tried running voxl-feature-tracker and it ended in a seg fault (included below).
        I also noticed that after running voxl-open-vins-server, when I run voxl-inspect-services, voxl-open-vins-server remains Disabled and Not Running even though the ov_overlay video stream is visible and updating, and the voxl-open-vins-server has not been quit.
        voxl2:~$ voxl-feature-tracker
        num_features:                   30
        en_blur:                                0
        en_normalization:                       0
        en_stereo_sync_ts:                      0
        pixel_filter_size:                       2.000
        pixel_search_radius:                    10.000
        octave_search_radius:                    3.000
        vio_cam config:
        cam 0:
            enable:                1
            pipe_for_preview:      tracking
            pipe_for_tracking:     tracking
            is_occluded_on_ground: 0
            imu:                   imu_apps
            is_extrinsic_present:  1
            extrinsic cam wrt imu:
            parent:                imu_apps
            child:                 tracking
            T_cam_wrt_imu:        -0.017  -0.016   0.015
            RPY_imu_to_cam:        0.0     0.0     0.0
            R_cam_to_imu:          1.000  -0.000   0.000
                                   0.000   1.000  -0.000
                                   0.000   0.000   1.000
            cal file:              opencv_tracking_intrinsics.yml
            is_cal_present:        1
            cam cal intrinsics:
            width:                 640
            height:                480
            fx:                    277.865
            fy:                    278.515
            cx:                    310.027
            cy:                    230.207
            n_coeffs:              4
            is_fisheye:            1
            D: -0.0091 0.0038 0.0082 -0.0059
        thread is locked to cores: 0 1 2 3
        cvp_set_pixel_search_radius: 10.000000
        cvp_octave_search_radius: 3.000000
        cvp_en_id_sort: true
        opening pipe: tracking
        Setup completed! Waiting for images...
        Connected to cam 0 tracking
        ERROR: Width/Height mismatch, optic flow w/h should be [640 400]                 , instead got [320 240]
        ERROR getting cvp feature tracker handle
        created output pipes:
        Feature Pipe: tracked_feats
        Overlay Pipe: feature_tracker_overlay
        starting publisher thread
        Segmentation fault:
        Fault thread: voxl-feature-tr(tid: 4606)
        Fault address: (nil)
        Address not mapped.
        Segmentation fault
        Thanks for your help, let me know what you think! 🙂
        Cliff WongC 1 Reply Last reply
        • S SKA
          num_features:                   30
          en_blur:                                0
          en_normalization:                       0
          vio_cam config:
          cam 0:
              enable:                1
              imu:                   imu_apps
              parent:                imu_apps
              child:                 tracking
                                     0.000   1.000  -0.000
                                     0.000   0.000   1.000
              is_cal_present:        1
              cam cal intrinsics:
              width:                 640
              height:                480
              fx:                    277.865
              fy:                    278.515
              cx:                    310.027
              cy:                    230.207
              n_coeffs:              4
              is_fisheye:            1
          Segmentation fault:
          Address not mapped.
          Segmentation fault
          Cliff WongC Offline
          Cliff WongC Offline
          Cliff Wong
          @SKA Can you post your output from running on the drone:
          voxl-version?
          As well as what aircraft model is this? (appears to be Sentinel?)
          Older versions (pre Jan 2025) we may need to have yo run the ovins internal-mode tracker. Otherwise it maybe worth to upgrade to the latest SDK.
            voxl-version?
            S Offline
            S Offline
            SKA
            @Cliff-Wong Hi, thanks for your response! Here is the ouput of voxl-version:
            voxl2:~$ voxl-version
            kernel:       #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
            hw platform:  M0054
            mach.var:     1.0.0
            voxl-suite:   1.4.1-202502092201
            Packages:
            Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
            Last Updated: 2025-02-10 20:13:48
            List:
            libmodal-cv                               0.5.16
            libmodal-exposure                         0.1.3
            libmodal-json                             0.4.4
            libmodal-pipe                             2.10.6
            libqrb5165-io                             0.4.9
            libvoxl-cci-direct                        0.2.5
            modalai-slpi                              1.1.19
            qrb5165-imu-server                        1.1.2
            qrb5165-rangefinder-server                0.1.4
            qrb5165-system-tweaks                     0.3.4
            voxl-camera-calibration                   0.5.9
            voxl-camera-server                        2.1.0
            voxl-configurator                         0.9.7
            voxl-cpu-monitor                          0.5.3
            voxl-cross-template                       0.0.1
            voxl-eigen3                               3.4.0
            voxl-elrs                                 0.4.1
            voxl-esc                                  1.5.1
            voxl-feature-tracker                      0.5.2
            voxl-io-server                            0.0.4
            voxl-jpeg-turbo                           2.1.3-6
            voxl-lepton-server                        1.3.3
            voxl-lepton-tracker                       0.0.4
            voxl-logger                               0.4.9
            voxl-mavcam-manager                       0.5.7
            voxl-mavlink                              0.1.2
            voxl-mavlink-server                       1.4.4
            voxl-modem                                1.1.5
            voxl-mpa-tools                            1.3.7
            voxl-open-vins                            0.4.16
            voxl-open-vins-server                     0.3.0
            voxl-opencv                               4.5.5-2
            voxl-osd                                  0.0.5
            voxl-portal                               0.7.5
            voxl-px4                                  1.14.0-2.0.94
            voxl-px4-params                           0.6.2
            voxl-qvio-server                          1.1.1
            voxl-reset-slpi                           0.0.1
            voxl-state-estimator                      0.0.4
            voxl-streamer                             0.7.5
            voxl-suite                                1.4.1-202502092201
            voxl-tflite-server                        0.3.9
            voxl-utils                                1.4.4
            voxl-vision-hub                           1.8.17
            voxl-vtx                                  1.1.6
            voxl2-system-image                        1.8.02-r0
            I've upgraded to the latest SDK. I'm not using an aircraft, I'm working with the voxl 2 board only, with a tracking fisheye ov7251 camera. The intrinsics and extrinsics are set up correctly, I was able to confirm this because qvio works well.
            I've traced back the error message
            to voxl-feature-tracker/src/main.cpp line 650:
            cvp_tracker_vec[ch].init(ch, width, height);
            This leads back to mcv_cvp_feature_tracker_init from libmodal_cv which is closed source.
            How can I run the ovins internal-mode tracker? Let me know if you have any further ideas to help me get ovins working Thanks!
            • S SKA
              hw platform:  M0054
              mach.var:     1.0.0
              Packages:
              List:
              libmodal-cv                               0.5.16
              libmodal-json                             0.4.4
              libqrb5165-io                             0.4.9
              modalai-slpi                              1.1.19
              voxl-eigen3                               3.4.0
              voxl-elrs                                 0.4.1
              voxl-esc                                  1.5.1
              voxl-logger                               0.4.9
              voxl-mavlink                              0.1.2
              voxl-modem                                1.1.5
              voxl-opencv                               4.5.5-2
              voxl-osd                                  0.0.5
              voxl-portal                               0.7.5
              voxl-streamer                             0.7.5
              voxl-utils                                1.4.4
              voxl-vtx                                  1.1.6
              S Offline
              S Offline
              SKA
              Looks like modalcv feature tracking is only set up for the ar0144 camera and not the ov7251 camera. Could you please extend feature tracking capability to other cameras? Is there any way I can do this on my end?
              • S SKA
                Cliff WongC Offline
                Cliff WongC Offline
                Cliff Wong
                @SKA Yes, VFT is actually deprecated in 1.4.1
                Please replace your ovins config with this and give it a try:
