    OpenVINS Reinitializing Issue
    GPS-denied Navigation (VIO)
    • S
      SKA
      OpenVINS starts up as expected, then starts reinitializing repeatedly. The intrinsics and extrinsics are set up and working as expected with qvio.
      Running voxl-open-vins-server -d, I get the following:
      ====> Using EXTERNAL feature tracker <====
      >>>>>>>>>> Current reference counts:
      trackDB: 1
      trackFEATS: 1
      propagator: 2
      updaterMSCKF: 1
      updaterSLAM: 1
      active_tracks_initializer: 1
      initializer: 1
      create_server_pipes
      connecting client pipes
      imu pipe name: imu_apps
      Number of Cameras active: 1
      Camera merge --- > ch: 1 to cam id: 0
      Opening camera pipe: tracking
      tmp_camera_pipe_names.push_back(): tracking
      VFT connected
      client "voxl-portal38440978" connected to overlay
      [INFO] world : 1.000000 1.000000  (2)
      FAILED TO FETCH IMG RINGBUF at time 0 -2 -2 -2 -2 -2
      [THERMAL] Resume processing done
      [ERROR] In init too long, timeout, retry  RESET 5012286699
      [ERROR] Triggered RESET type: 4
      [INFO] restarting managers STATELESS
      Set camera intrinsics and extrinsics
      How can I get past the reinitializing issue and run OpenVINS?
      • Cliff WongC
        Cliff Wong ModalAI Team
        Hi there, typically when OVINS is resetting constantly, that means there's no image stream or feature data being sent to it. Since we see a video the image stream is ok.
        You want to run in a adb shell:
        a. cat /etc/modalai/voxl-open-vins-server.conf and confirm en_ext_feature_tracker: true
        b. run voxl-inspect-services and ensure voxl-feature-tracker is running. You can also check voxl-portal and confirm a feature_overlay video feed is present.
        c. then restart voxl-open-vins-server -d as you did above.
        The drone should be on a level surface when ovins is initializing.
        If that doesn't work, can you post your /etc/modalai/vio_cams.conf.
        • S
          SKA @Cliff Wong
          @Cliff-Wong Thanks for your response! I have en_ext_feature_tracker: true. I tried running voxl-feature-tracker and it ended in a seg fault (included below).
          I also noticed that after running voxl-open-vins-server, when I run voxl-inspect-services, voxl-open-vins-server remains Disabled and Not Running even though the ov_overlay video stream is visible and updating, and the voxl-open-vins-server has not been quit.
          voxl2:~$ voxl-feature-tracker
          num_features:                   30
          en_blur:                                0
          en_normalization:                       0
          en_stereo_sync_ts:                      0
          pixel_filter_size:                       2.000
          pixel_search_radius:                    10.000
          octave_search_radius:                    3.000
          vio_cam config:
          cam 0:
              enable:                1
              pipe_for_preview:      tracking
              pipe_for_tracking:     tracking
              is_occluded_on_ground: 0
              imu:                   imu_apps
              is_extrinsic_present:  1
              extrinsic cam wrt imu:
              parent:                imu_apps
              child:                 tracking
              T_cam_wrt_imu:        -0.017  -0.016   0.015
              RPY_imu_to_cam:        0.0     0.0     0.0
              R_cam_to_imu:          1.000  -0.000   0.000
                                     0.000   1.000  -0.000
                                     0.000   0.000   1.000
              cal file:              opencv_tracking_intrinsics.yml
              is_cal_present:        1
              cam cal intrinsics:
              width:                 640
              height:                480
              fx:                    277.865
              fy:                    278.515
              cx:                    310.027
              cy:                    230.207
              n_coeffs:              4
              is_fisheye:            1
              D: -0.0091 0.0038 0.0082 -0.0059
          thread is locked to cores: 0 1 2 3
          cvp_set_pixel_search_radius: 10.000000
          cvp_octave_search_radius: 3.000000
          cvp_en_id_sort: true
          opening pipe: tracking
          Setup completed! Waiting for images...
          Connected to cam 0 tracking
          ERROR: Width/Height mismatch, optic flow w/h should be [640 400]                 , instead got [320 240]
          ERROR getting cvp feature tracker handle
          created output pipes:
          Feature Pipe: tracked_feats
          Overlay Pipe: feature_tracker_overlay
          starting publisher thread
          Segmentation fault:
          Fault thread: voxl-feature-tr(tid: 4606)
          Fault address: (nil)
          Address not mapped.
          Segmentation fault
          Thanks for your help, let me know what you think! 🙂
          Cliff WongC 1 Reply Last reply Reply Quote 0
          • Cliff WongC
            Cliff Wong ModalAI Team @SKA
            @SKA Can you post your output from running on the drone:
            voxl-version?
            As well as what aircraft model is this? (appears to be Sentinel?)
            Older versions (pre Jan 2025) we may need to have yo run the ovins internal-mode tracker. Otherwise it maybe worth to upgrade to the latest SDK.
            • S
              SKA @Cliff Wong
              @Cliff-Wong Hi, thanks for your response! Here is the ouput of voxl-version:
              voxl2:~$ voxl-version
              kernel:       #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
              hw platform:  M0054
              mach.var:     1.0.0
              voxl-suite:   1.4.1-202502092201
              Packages:
              Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
              Last Updated: 2025-02-10 20:13:48
              List:
              libfc-sensor                              1.0.7
              libmodal-cv                               0.5.16
              libmodal-exposure                         0.1.3
              libmodal-json                             0.4.4
              libmodal-pipe                             2.10.6
              libqrb5165-io                             0.4.9
              libvoxl-cci-direct                        0.2.5
              modalai-slpi                              1.1.19
              qrb5165-dfs-server                        0.2.0
              qrb5165-imu-server                        1.1.2
              qrb5165-rangefinder-server                0.1.4
              qrb5165-system-tweaks                     0.3.4
              voxl-bind-spektrum                        0.1.1
              voxl-camera-calibration                   0.5.9
              voxl-camera-server                        2.1.0
              voxl-configurator                         0.9.7
              voxl-cpu-monitor                          0.5.3
              voxl-cross-template                       0.0.1
              voxl-docker-support                       1.3.1
              voxl-eigen3                               3.4.0
              voxl-elrs                                 0.4.1
              voxl-esc                                  1.5.1
              voxl-feature-tracker                      0.5.2
              voxl-flow-server                          0.3.6
              voxl-io-server                            0.0.4
              voxl-jpeg-turbo                           2.1.3-6
              voxl-lepton-server                        1.3.3
              voxl-lepton-tracker                       0.0.4
              voxl-logger                               0.4.9
              voxl-mavcam-manager                       0.5.7
              voxl-mavlink                              0.1.2
              voxl-mavlink-server                       1.4.4
              voxl-modem                                1.1.5
              voxl-mpa-to-ros                           0.3.9
              voxl-mpa-tools                            1.3.7
              voxl-open-vins                            0.4.16
              voxl-open-vins-server                     0.3.0
              voxl-opencv                               4.5.5-2
              voxl-osd                                  0.0.5
              voxl-portal                               0.7.5
              voxl-px4                                  1.14.0-2.0.94
              voxl-px4-params                           0.6.2
              voxl-qvio-server                          1.1.1
              voxl-remote-id                            0.0.9
              voxl-reset-slpi                           0.0.1
              voxl-state-estimator                      0.0.4
              voxl-streamer                             0.7.5
              voxl-suite                                1.4.1-202502092201
              voxl-tflite-server                        0.3.9
              voxl-utils                                1.4.4
              voxl-uvc-server                           0.1.7
              voxl-vision-hub                           1.8.17
              voxl-vtx                                  1.1.6
              voxl2-io                                  0.0.3
              voxl2-system-image                        1.8.02-r0
              I've upgraded to the latest SDK. I'm not using an aircraft, I'm working with the voxl 2 board only, with a tracking fisheye ov7251 camera. The intrinsics and extrinsics are set up correctly, I was able to confirm this because qvio works well.
              I've traced back the error message
              to voxl-feature-tracker/src/main.cpp line 650:
              cvp_tracker_vec[ch].init(ch, width, height);
              This leads back to mcv_cvp_feature_tracker_init from libmodal_cv which is closed source.
              How can I run the ovins internal-mode tracker? Let me know if you have any further ideas to help me get ovins working Thanks!
              • S
                SKA @SKA
                Looks like modalcv feature tracking is only set up for the ar0144 camera and not the ov7251 camera. Could you please extend feature tracking capability to other cameras? Is there any way I can do this on my end?
                • Cliff WongC
                  @SKA Yes, VFT is actually deprecated in 1.4.1
                  Please replace your ovins config with this and give it a try:
