  3. [URGENT] RB5 VOXL2 doesn't recognize replaced hires camera
rb5
11 Posts 2 Posters 2.5k Views 1 Watching
  • S Offline
    S Offline
    smilon
    wrote on last edited by smilon
    Dear ModalAI team,
    I just had to replace my M0025 hires camera on my RB5. After replacing the new camera as instructed in one of your videos, I noticed first of all that the hires pipe is not recognized even though my voxl-camera-server.conf is untouched.
    Even so, I have triple-checked the camera is undamaged and installed properly. I never had a similar issue before and just ordered the camera fresh (ordered last week). Also note, that when I briefly have connection I verified that all the rest cameras are streaming fine through voxl-streamer.
    Please advise ASAP as it is a time-sensitive issue.
    Installation video (@2:55)
    • S Offline
      S Offline
      smilon
      systemctl status voxl-camera-server:
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: setting ov7251 BLC register for cam id 1
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: Starting Camera: tracking (id #2)
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: Using gain limits min: 54 max: 3451
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: setting ov7251 BLC register for cam id 2
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: Starting Camera: hires (id #3)
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: WARNING: cam hires (id 3) does not seem to be alive
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: ------ voxl-camera-server: Started 2 of 3 cameras
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: ------ voxl-camera-server: Camera server is now running
      Feb 07 11:59:55 m0052 voxl-camera-server[1528]: WARNING: Camera stereo Received much newer master than child (33.3ms), discarding child
      Feb 07 13:01:59 m0052 voxl-camera-server[1528]: WARNING: Camera stereo Received much newer child than master (33.8ms), discarding master
      lines 3-18/18 (END)
      • S smilon
        lines 3-18/18 (END)
        Hi @smilon,
        Are you able to test the original camera that was connected before you replaced it?
        Regarding the following statement, "Also note, that when I briefly have connection I verified that all the rest cameras are streaming fine through voxl-streamer." -- are you saying that after replacement the M0025 camera briefly worked but stopped working?
        Please check any interposers / flex cables between the camera and main board.
        S 2 Replies Last reply
          Hi @smilon,
          S Offline
          S Offline
          smilon
          • S Offline
            S Offline
            smilon
              Hi @smilon,
              S Offline
              S Offline
              smilon
              @Alex-Kushleyev Dear Alex,
              I ended up re-flashing SDK1.1.2 on the RB5 and now I don't get an "unrecognized error" on the hires camera, however I still haven't managed to get it to work. The problem now seems to be that it's not able to recognize several imx214 supported resolutions and therefore the hires camera doesn't start up. For example in the following voxl-camera-server.conf:
              			"type":	"imx214",
              			"name":	"hires",
              			"enabled":	true,
              			"camera_id":	3,
              			"fps":	30,
              			"en_preview":	false,
              			"preview_width":	640,
              			"preview_height":	480,
              			"en_raw_preview":	false,
              			"en_small_video":	true,
              			"small_video_width":	640,
              			"small_video_height":	480,
              			"small_venc_mode":	"h265",
              			"small_venc_br_ctrl":	"cqp",
              			"small_venc_Qfixed":	30,
              			"small_venc_Qmin":	15,
              			"small_venc_Qmax":	40,
              			"small_venc_nPframes":	9,
              			"small_venc_mbps":	2,
              			"en_large_video":	true,
              			"large_video_width":	640,
              			"large_video_height":	480,
              			"large_venc_mode":	"h265",
              			"large_venc_br_ctrl":	"cqp",
              			"large_venc_Qfixed":	38,
              			"large_venc_Qmin":	15,
              			"large_venc_Qmax":	50,
              			"large_venc_nPframes":	29,
              			"large_venc_mbps":	30,
              			"en_snapshot":	true,
              			"en_snapshot_width":	4208,
              			"en_snapshot_height":	3120,
              			"ae_mode":	"isp"
              I get the following status info from the voxl-camera-server:
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: WARNING: Failed to start cam hires due to invalid resolution
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: WARNING: assuming cam is missing and trying to compensate
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: Starting Camera: stereo_rear (originally id #5) with id offset: 1
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: Using gain limits min: 54 max: 3451
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: WARNING: Camera stereo_front Received much newer master than child (33.2ms), discarding
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: setting ov7251 BLC register for cam id 4
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: setting ov7251 BLC register for cam id 3
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: ------ voxl-camera-server: Started 3 of 4 cameras
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: ------ voxl-camera-server: Camera server is now running
              Feb 10 13:48:55 m0052 voxl-camera-server[2929]: WARNING: Camera stereo_rear Received much newer child than master (33.3ms), discarding m
              I obviously tried with the Sentinel default config before modifying the resolutions to 640x480. I would appreciate if you provided a list of the supported resolutions for the M0025 sensor, just for my own sanity checks.
              More info:
              I am using voxl-camera-server 1.8.9+1. And to clarify with my previous post, no I haven't seen the hires cam working yet. Also a link to the shop for the replacement: https://www.modalai.com/products/msu-m0025-2?srsltid=AfmBOop_qPdLSNdkIYk-s1uaBYXFxWmQ77v__3fUlWISbT7HQM_sLcW0
              • S Offline
                S Offline
                smilon
                • Alex KushleyevA Offline
                  @smilon ,
                  I believe what is happening is that your IMX214 is still not being detected and camera server is trying to skip the undetected camera.
                  In your config, you specified that imx214 is camera id 3, but the camera server prints the following, which means it detected ov7251 as camera id 3:
                  if you run voxl-camera-server -l, does camera server detect imx214 at the very top of the output?
                  If something seems confusing, you can try physically disconnecting all cameras except for your IMX214 and modify the voxl-camera-server.conf to only use one camera (imx214, which should be camera id 0, the only camera). That would be a good start to confirm the single hires camera is working.
                  S 1 Reply Last reply
                    @smilon ,
                    S Offline
                    S Offline
                    smilon
                    @Alex-Kushleyev
                    Ok so you were right. Think I just found the issue 🙂
                    (the backplate of the sensor is detached)
                    I didn't notice that when we got it a few weeks ago. Can we send it back and you can send us over a new one? Or try to see if it can be repaired? Who can we talk to, its kind of time-sensitive.
                    Thanks a lot again,
                    Milton
                    • S smilon
                      @Alex-Kushleyev
                      Thanks a lot again,
                      Milton
                      @smilon , Can you please clarify what this is a picture of? I don't recognize it from this angle.
                        S Offline
                        S Offline
                        smilon
                        It's the M0025-002 high resolution camera. Perhaps the connection sodder was loose and it popped off real easily. In hindsight, perhaps it's not worth anyone's time. If you can provide any repair tricks that'd be neat otherwise I'll probably have to send a new order in.
                        Best,
                        Milton
