  3. Connecting Teensy to VOXL 2
voxl2
3 Posts 2 Posters 1.5k Views 1 Watching
  • B Offline
    B Offline
    bkim1301
    wrote on last edited by bkim1301
    I purchased a Starling 2 Max drone, and want to connect a Teensy 4.1 to the UART7 port on the M0151 B2B expansion. I followed the instructions for VOXL 2 Connecting an External Flight Controller, to get pinouts and ran a pyserial script from the home directory of the VOXL to test sending messages for the Teensy to read. Debugging with pyserial indicates that I connect to /dev/ttyHS1, but I do not read anything from the Teensy.
    #!/usr/bin/env python3
    import sys
    import serial
    import time
    class SerialPort:
        def __init__(self, port='/dev/ttyHS1', baudrate=115200):
            try:
                self.ser = serial.Serial(port=port,
                                         baudrate=baudrate,
                                         bytesize=serial.EIGHTBITS,
                                         parity=serial.PARITY_NONE,
                                         stopbits=serial.STOPBITS_ONE,
                                         timeout=1.0
                print(f"Connected to {port} at {baudrate} baud")
            except serial.SerialException as e:
                print(f"Error opening serial port: {e}")
                sys.exit(1)
        def write(self, data):
            """Write data to serial port"""
            try:
                self.ser.write(data.encode())
                self.ser.flush()
                print(f"Error writing to serial port: {e}")
        def close(self):
            """Close serial port"""
            if self.ser.is_open:
                self.ser.close()
    def main():
        # Initialize serial port
        ser = SerialPort()
        # Run TX/RX test (Send test messages)
        try:
            while True:
                # Send test message
                ser.write('Test\n')
                print("Sent: 'Test'.")
                # Wait before next test run
                time.sleep(1)
        except KeyboardInterrupt:
            print("\nClosing serial port...")
        finally:
            ser.close()
    if __name__ == '__main__':
        main()
    What are possible next steps? Different changes to config files than documentation? Logic level shifter?
    TL;DR: I want to connect a Teensy to VOXL2 via UART7 port using standard Linux practices.
    • B bkim1301
      import sys
      import serial
      import time
      class SerialPort:
              try:
                                           baudrate=baudrate,
                                           timeout=1.0
                  sys.exit(1)
              try:
                  self.ser.flush()
          def close(self):
                  self.ser.close()
      def main():
          ser = SerialPort()
          try:
              while True:
                  # Send test message
                  ser.write('Test\n')
                  time.sleep(1)
          finally:
              ser.close()
          main()
      Eric KatzfeyE Online
      @bkim1301 I would start by connecting the VOXL 2 UART 7 to a PC with a serial to USB cable. Make sure you can communicate back and forth using that setup and then do the same with the Teensy before connecting the Teensy and the VOXL 2 together. It's often very helpful to use an oscilloscope on the rx / tx lines to verify that there is actually data flowing.
      B 1 Reply Last reply
        B Offline
        B Offline
        bkim1301
