    VOXL Flight image will not flash
    VOXL SDK
    2112
    • Kiazoa JoaoK
      Kiazoa Joao
      I am trying to re-flash (VOXL_SDK_1.2.0) my M500 drone, but whenever I try to run the ./install.sh script, the vehicle loses communication and I get the following message. Please let me know how I can fix this. Thank you!
      • tomT
        tom admin @Kiazoa Joao
        @Kiazoa-Joao It looks like you're using a virtual machine which likely means that the VOXL's USB device in fastboot is not being passed through to your VM. You'll likely have to add it separately, similarly to how you did so for the device in ADB.
        Kiazoa JoaoK 1 Reply Last reply Reply Quote 0
        • Kiazoa JoaoK
          Kiazoa Joao @tom
          @tom thanks for replying. How can I do that?
          • tomT
            @Kiazoa-Joao https://www.eltima.com/article/virtualbox-usb-passthrough/#:~:text=Click File | Tools | Extension Pack Manager.&text=Plug the required USB device,appear in your guest OS.
            • Kiazoa JoaoK
              Kiazoa Joao @tom
              @tom thank you. I appreciate it
              • Kiazoa JoaoK
                Kiazoa Joao @Kiazoa Joao
                @tom another thing, how do I make sure the vehicle is in fastboot mode?
                • tomT
                  @Kiazoa-Joao The script will put it into fastboot. You can also do so manually by running adb reboot bootloader
                  • Kiazoa JoaoK
                    Kiazoa Joao @tom
                    @tom I did that. I tried to run it again, but I got the same error. I also tried running adb reboot bootloader, the drone lost connection, the same as running the script. Any other ideas? I saw a post on here talking about disconnecting the tracking cameras, do you think that'd solve it?
                    https://forum.modalai.com/topic/1144/info-waiting-for-fastboot/5
                    • tomT
                      @Kiazoa-Joao If you think there's a chance your cameras are plugged in incorrectly then it doesn't hurt to try.
                      When the script is hanging, what do you see with lsusb? and fastboot devices?
                      • Kiazoa JoaoK
                        Kiazoa Joao @tom
                        @tom I don't see anything. The drone loses connection and the adb devices disappear. Also, when I try to check fastboot devices, nothing shows up
                        • tomT
                          @Kiazoa-Joao Did you add the device via pass-through to the VM?
                          If possible I would highly recommend not using a VM and running Ubuntu natively if possible
                          • Kiazoa JoaoK
                            Kiazoa Joao @tom
                            @tom yes I did. I don't have a linux system. I tried WSL, but It won't show the adb devices. However, I'll try to borrow a Linux system from someone on Monday and will let you know if it works. Thank you for your assistance.
                            • tomT
                              @Kiazoa-Joao No problem, we've just found it much easier to run native linux for this specific reason, sometimes windows can be difficult when it comes to passing in the USB devices
                              • Kiazoa JoaoK
                                Kiazoa Joao @tom
                                @tom I managed to get WSL to work and the same thing is happeing, I don't know if running it on a Linux system will be any better, but I'll will give it a try.
                                • tomT
                                  @Kiazoa-Joao It's possible you're missing some necessary fastboot drivers on your windows machine
                                  Kiazoa JoaoK 2 Replies Last reply Reply Quote 0
                                  • Kiazoa JoaoK
                                    Kiazoa Joao @tom
                                    @tom I see. Can they be easily installed?
                                    • Kiazoa JoaoK
                                      Kiazoa Joao @tom
                                      @tom you were right. I used a Linux system and it worked flawlessly. Thank you for your assistance. I am just curious to know if the fastboot drivers can be installed on my windows device, just for the future. Please let me know
                                      • tomT
                                        @Kiazoa-Joao We don't use windows here so I can't provide much help there, it should be possible though.
                                        • Kiazoa JoaoK
                                          Kiazoa Joao @tom
                                          @tom Thank you. I'll look it up.
