  2. VOXL SDK and Software
  3. VOXL Flight image will not flash
voxl-sdk
19 Posts 2 Posters 3.1k Views 1 Watching
    @Kiazoa-Joao If you think there's a chance your cameras are plugged in incorrectly then it doesn't hurt to try.
    When the script is hanging, what do you see with lsusb? and fastboot devices?
    Kiazoa JoaoK Offline
    Kiazoa Joao
    @tom I don't see anything. The drone loses connection and the adb devices disappear. Also, when I try to check fastboot devices, nothing shows up
    • Kiazoa JoaoK Kiazoa Joao
      @Kiazoa-Joao Did you add the device via pass-through to the VM?
      If possible I would highly recommend not using a VM and running Ubuntu natively if possible
      Kiazoa JoaoK 1 Reply Last reply
        Kiazoa Joao
        @tom yes I did. I don't have a linux system. I tried WSL, but It won't show the adb devices. However, I'll try to borrow a Linux system from someone on Monday and will let you know if it works. Thank you for your assistance.
          @Kiazoa-Joao No problem, we've just found it much easier to run native linux for this specific reason, sometimes windows can be difficult when it comes to passing in the USB devices
            Kiazoa Joao
            @tom I managed to get WSL to work and the same thing is happeing, I don't know if running it on a Linux system will be any better, but I'll will give it a try.
              @Kiazoa-Joao It's possible you're missing some necessary fastboot drivers on your windows machine
              Kiazoa JoaoK 2 Replies Last reply
                Kiazoa Joao
                @tom I see. Can they be easily installed?
                  Kiazoa Joao
                  @tom you were right. I used a Linux system and it worked flawlessly. Thank you for your assistance. I am just curious to know if the fastboot drivers can be installed on my windows device, just for the future. Please let me know
                    @Kiazoa-Joao We don't use windows here so I can't provide much help there, it should be possible though.
                      Kiazoa Joao
                      @tom Thank you. I'll look it up.
