  2. Software Development
  3. How to use UART in custom applications
8 Posts 2 Posters 4.3k Views 2 Watching
  • Samuel LehmanS Offline
    Samuel Lehman
    I am currently trying to make a simple application that gets imu data and sends it out through uart. I am using the voxl-cross-template project as a base for this application. I have tried using some of the code in the libqrb5165-io project to get the uart to work however I have been unable to compile it. I believe it might be an issue with my cmake files.
    [ 50%] Linking C executable hello-cross
    CMakeFiles/hello-cross.dir/main.c.o: In function `_helper_cb':
    main.c:(.text+0xb8): undefined reference to `voxl_uart_write'
    main.c:(.text+0xfc): undefined reference to `ERROR'
    CMakeFiles/hello-cross.dir/main.c.o: In function `main':
    main.c:(.text.startup+0x3c): undefined reference to `voxl_uart_init'
    main.c:(.text.startup+0xcc): undefined reference to `voxl_uart_close'
    main.c:(.text.startup+0xec): undefined reference to `ERROR'
    main.c:(.text.startup+0x100): undefined reference to `ERROR'
    collect2: error: ld returned 1 exit status
    src/CMakeFiles/hello-cross.dir/build.make:99: recipe for target 'src/hello-cross' failed
    make[2]: *** [src/hello-cross] Error 1
    CMakeFiles/Makefile2:97: recipe for target 'src/CMakeFiles/hello-cross.dir/all' failed
    make[1]: *** [src/CMakeFiles/hello-cross.dir/all] Error 2
    Makefile:135: recipe for target 'all' failed
    make: *** [all] Error 2
    starting building Debian Package
    mkdir: cannot create directory 'pkg/DEB': No such file or directory
    Is there a better way to send data out through uart? Is there an example of something similar to what I'm trying to do out there that I can look at?
    Here is my current main function and helper_cb for reference:
    int main(int argc, char *const argv[])
        enable_signal_handler();
        main_running = 1;
        int uart_res = voxl_uart_init(device, baud, 1.0, 0, 1, 0);
        if (uart_res < 0)
            ERROR("Failed to open port");
            resurn 1;
        pipe_client_set_simple_helper_cb(0, _helper_cb, NULL);
        pipe_client_set_disconnect_cb(0, _disconnect_cb, NULL);
        int pipe_open_res = pipe_client_open(0, imu_name, CLIENT_NAME,
                                             EN_PIPE_CLIENT_SIMPLE_HELPER,
                                             IMU_RECOMMENDED_READ_BUF_SIZE);
        if (pipe_open_res < 0)
            pipe_print_error(pipe_open_res);
            printf(ENABLE_WRAP);
            return -1;
        // keep going until the  signal handler sets the running flag to 0
        while (main_running)
            usleep(500000);
        // all done, signal pipe read threads to stop
        printf("\nclosing and exiting\n" RESET_FONT ENABLE_WRAP);
        pipe_client_close_all();
        int ret = voxl_uart_close(device);
        if (ret < 0)
            ERROR("Failed to close UART device");
            return 1;
    static void _helper_cb(__attribute__((unused)) int ch, char *data, int bytes, __attribute__((unused)) void *context)
        const uint8_t MIN_WRITE_LEN = 32;
        uint8_t write_buf[MIN_WRITE_LEN];
        // validate that the data makes sense
        int n_packets;
        imu_data_t *data_array = pipe_validate_imu_data_t(data, bytes, &n_packets);
        if (data_array == NULL)
            return;
        // print everything in one go.
        if (!en_newline)
            printf("\r" CLEAR_LINE);
        printf("%7.2f|%7.2f|%7.2f|%7.2f|%7.2f|%7.2f",
               (double)data_array[n_packets - 1].accl_ms2[0],
               (double)data_array[n_packets - 1].accl_ms2[1],
               (double)data_array[n_packets - 1].accl_ms2[2],
               (double)data_array[n_packets - 1].gyro_rad[0],
               (double)data_array[n_packets - 1].gyro_rad[1],
               (double)data_array[n_packets - 1].gyro_rad[2]);
        if (en_newline)
            printf("\n");
        int write_res = voxl_uart_write(device, write_buf, MIN_WRITE_LEN);
        if (write_res < 0)
            ERROR("Failed to write to UART");
            return;
        fflush(stdout);
        return;
    • Samuel LehmanS Samuel Lehman
          main_running = 1;
          if (uart_res < 0)
              resurn 1;
              return -1;
              usleep(500000);
          if (ret < 0)
              return 1;
          int n_packets;
              return;
          if (!en_newline)
          if (en_newline)
              printf("\n");
          if (write_res < 0)
              return;
          fflush(stdout);
          return;
      @Samuel-Lehman ,
      In your application, you should be including <voxl_io.h> and linking against voxl_io library:
      in cmake file:
      target_link_libraries(${app_name} LINK_PUBLIC voxl-io)
      Both the header and library (.so) are part of libqrb5165-io package that is built from this project: https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/
      So, if you are building your app using cross-compiler, make sure to install the libqrb5165-io inside the cross compiler docker before building the application. Typically all our projects have a script for installing build deps, here it is for the libqrb5165-io library (which obviously does not include the library itself as a dependency, because we are actually building it here ) : https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/blob/master/install_build_deps.sh
      You can also just run apt update && apt install libqrb5165-io after you spin up your cross compile docker.
      You can also build your app directly on voxl2, as the libqrb5165-io library should already be installed as part of our SDK.
      Samuel LehmanS 1 Reply Last reply
        @Samuel-Lehman ,
        in cmake file:
        Samuel Lehman
        @Alex-Kushleyev thank you for your response, however I am still unable to build the project. I have libqrb5165-io added to my install_build_deps.sh and I do have the voxl_io header included in my main file. Maybe I am placing the cmake line in the wrong spot or in the wrong cmake file altogether as I have two of them. Here are the cmake files in my src folder and root folder respectively:
        // ./src/CMakeLists.txt
        cmake_minimum_required(VERSION 3.3)
        SET(TARGET hello-cross)
        # Build from all source files
        file(GLOB all_src_files *.c*)
        add_executable(${TARGET}
        	${all_src_files}
        include_directories(
            ../include
        find_library(MODAL_JSON  modal_json  HINTS /usr/lib /usr/lib64)
        find_library(MODAL_PIPE  modal_pipe  HINTS /usr/lib /usr/lib64)
        find_library(VOXL_CUTILS voxl_cutils HINTS /usr/lib /usr/lib64)
        find_library(VOXL_IO libvoxl_io HINTS /usr/lib /usr/lib64)
            ${TARGET}
            pthread
            ${MODAL_JSON}
            ${MODAL_PIPE}
            ${VOXL_CUTILS}
        # make sure everything is installed where we want
        # LIB_INSTALL_DIR comes from the parent cmake file
        install(
            TARGETS			${TARGET}
        	LIBRARY			DESTINATION ${LIB_INSTALL_DIR}
        	RUNTIME			DESTINATION /usr/bin
        	PUBLIC_HEADER	DESTINATION /usr/include
        // ./CMakeLists.txt
        project(voxl-hello-cross C)
        	"include/"
        # Strawson's list of standard list of default gcc flags. Yes, I treat
        # warnings as errors. Warnings exist to point out sloppy code and potential
        # failure points for good reason. We do not approve of sloppy code.
        # set(CMAKE_C_FLAGS "-std=gnu99 -Werror -Wall -Wextra -Wuninitialized \
        # 	-Wunused-variable -Wdouble-promotion -Wmissing-prototypes \
        # 	-Wmissing-declarations -Werror=undef -Wno-unused-function ${CMAKE_C_FLAGS}")
        set(CMAKE_C_FLAGS "-std=gnu99 -Wuninitialized \
        	-Wmissing-declarations -Werror=undef ${CMAKE_C_FLAGS}")
        # for VOXL, install 64-bit libraries to lib64, 32-bit libs go in /usr/lib
        if(CMAKE_SYSTEM_PROCESSOR MATCHES "^aarch64")
        	set(LIB_INSTALL_DIR /usr/lib64)
        else()
        	set(LIB_INSTALL_DIR /usr/lib)
        endif()
        # include each subdirectory, may have others in example/ or lib/ etc
        add_subdirectory (src)
        here is the output when I run the install and build scripts:
        using qrb5165 sdk-1.0 debian repo
        Ign:1 http://voxl-packages.modalai.com ./dists/qrb5165/sdk-1.0/binary-arm64/ InRelease
        Ign:2 http://voxl-packages.modalai.com ./dists/qrb5165/sdk-1.0/binary-arm64/ Release
        Get:3 http://voxl-packages.modalai.com ./dists/qrb5165/sdk-1.0/binary-arm64/ Packages [23.2 kB]
        Fetched 23.2 kB in 0s (61.3 kB/s)
        Reading package lists... Done
        installing:
        libmodal-json
        libmodal-pipe
        libvoxl-cutils
        libqrb5165-io
        Building dependency tree
        libmodal-json:arm64 is already the newest version (0.4.3).
        libvoxl-cutils:arm64 is already the newest version (0.1.1).
        libqrb5165-io:arm64 is already the newest version (0.4.7).
        libmodal-pipe:arm64 is already the newest version (2.10.4).
        0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
        Done installing dependencies
        -- The C compiler identification is GNU 7.5.0
        -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-7 - skipped
        CMake Error at src/CMakeLists.txt:22 (target_link_libraries):
          The LINK_PUBLIC or LINK_PRIVATE option must appear as the second argument,
          just after the target name.
        Im new to cmake so I have no idea what I am doing.
          	${all_src_files}
              ../include
              ${TARGET}
              pthread
              ${MODAL_JSON}
              ${MODAL_PIPE}
              ${VOXL_CUTILS}
          install(
              TARGETS			${TARGET}
          // ./CMakeLists.txt
          	"include/"
          else()
          endif()
          installing:
          libmodal-json
          libmodal-pipe
          libvoxl-cutils
          libqrb5165-io
          I think you need to update the target_link_libraries entry to:
              ${TARGET}
              pthread
              ${MODAL_JSON}
              ${MODAL_PIPE}
              ${VOXL_CUTILS}
              voxl-io
          or $(VOXL_IO) instead of voxl-io since you already defined it using:
          Please try
                ${TARGET}
                pthread
                ${MODAL_JSON}
                ${MODAL_PIPE}
                ${VOXL_CUTILS}
                voxl-io
            Please try
            Samuel Lehman
            @Alex-Kushleyev after adding $(VOXL_IO) i get:
            -- Build files have been written to: /home/root/build
            [ 50%] Building C object src/CMakeFiles/hello-cross.dir/main.c.o
            /home/root/src/main.c: In function '_helper_cb':
            /home/root/src/main.c:88:21: warning: implicit declaration of function 'voxl_uart_write'; did you mean 'voxl_spi_write'? [-Wimplicit-function-declaration]
                                 voxl_spi_write
            /home/root/src/main.c: In function 'main':
            /home/root/src/main.c:105:20: warning: implicit declaration of function 'voxl_uart_init'; did you mean 'voxl_i2c_init'? [-Wimplicit-function-declaration]
                                voxl_i2c_init
            /home/root/src/main.c:134:15: warning: implicit declaration of function 'voxl_uart_close'; did you mean 'voxl_i2c_close'? [-Wimplicit-function-declaration]
                           voxl_i2c_close
            [100%] Linking C executable hello-cross
            main.c:(.text.startup+0x44): undefined reference to `voxl_uart_init'
            main.c:(.text.startup+0xd0): undefined reference to `voxl_uart_close'
            src/CMakeFiles/hello-cross.dir/build.make:100: recipe for target 'src/hello-cross' failed
            Package Name:  voxl-cross-template
            version Number:  0.0.1
            Consolidate compiler generated dependencies of target hello-cross
                                   voxl_spi_write
                                  voxl_i2c_init
                             voxl_i2c_close
              This is odd because the uart function definitions are here :
              Link Preview Image
              apps/library/include/voxl_io/uart.h · master · voxl / VOXL SDK / Core Libs / libqrb5165-io · GitLab
              GitLab.com
              favicon
              GitLab (gitlab.com)
              Are you sure that you are including <voxl_io.h> in your app? implicit declaration of function warning is a clear sign that the function declaration is not found (from voxl_io.h, well actually from voxl_io/uart.h, latter being included from voxl_io.h.
              Please double check.
                Link Preview Image
                GitLab.com
                favicon
                GitLab (gitlab.com)
                Samuel Lehman
                @Alex-Kushleyev I have it included, heres my full main file:
                #include <stdio.h> // for fprintf
                #include <unistd.h>
                #include <getopt.h>
                #include <string.h>
                #include <modal_pipe.h>
                #include <voxl_cutils.h>
                #include <voxl_io.h>
                #include "hello_cross.h"
                #define CLIENT_NAME "hello-cross"
                static char en_newline = 0;
                static char imu_name[64];
                static int opt = 0;
                static int device = 1; // default. /dev/ttyHS1
                static int baud = 115200;
                void printHelloCross(void);
                // called whenever we disconnect from the server
                static void _disconnect_cb(__attribute__((unused)) int ch, __attribute__((unused)) void *context)
                    fprintf(stderr, "\r" CLEAR_LINE FONT_BLINK "server disconnected" RESET_FONT);
                    return;
                // called when the simple helper has data for us
                    int n_packets;
                        return;
                    if (!en_newline)
                    if (en_newline)
                        printf("\n");
                    if (write_res < 0)
                        //ERROR("Failed to write to UART");
                        return;
                    fflush(stdout);
                    return;
                    main_running = 1;
                    if (uart_res < 0)
                        //ERROR("Failed to open port");
                        return 1;
                        return -1;
                        usleep(500000);
                    if (ret < 0)
                        //ERROR("Failed to close UART device");
                        return 1;
                void printHelloCross()
                    printf("   Imu Acceleration and Gyro\n");
                    printf("   X   |   Y   |   Z   |  X   |   Y   |   Z\n");
                  #include <unistd.h>
                  #include <getopt.h>
                  #include <string.h>
                  static int opt = 0;
                      return;
                      int n_packets;
                          return;
                      if (!en_newline)
                      if (en_newline)
                          printf("\n");
                      if (write_res < 0)
                          return;
                      fflush(stdout);
                      return;
                      main_running = 1;
                      if (uart_res < 0)
                          return 1;
                          return -1;
                          usleep(500000);
                      if (ret < 0)
                          return 1;
                  @Samuel-Lehman , Not sure what is going on but i was able to build your example with the following command on VOXL2. I had to comment out #include "hello_cross.h" because i did not have it.
                  voxl2:~$ gcc -O2 -Wall voxl_io_uart_test.c -o voxl_io_uart_test -lmodal_pipe -lvoxl_io -L/usr/lib64
                  voxl_io_uart_test.c:14:12: warning: 'opt' defined but not used [-Wunused-variable]
                   static int opt = 0;
                  voxl2:~$
                  I am not sure what's going on, you can enable verbose CMake file to see what compile command CMake is generating and compare that to the above.
