    Request for QURT Compatibility for OSD Program
    2020
    • JP DroneJ
      JP Drone
      I am currently working on configuring the OSD program (msp_dp_osd) on VOXL 2 Mini. I have successfully confirmed that the OSD works using Pins 4/5 on J10 (/dev/ttyHS0).
      However, Pins 4/5 on J10 (/dev/ttyHS0) are required for other critical purposes, and as a result, I would like to utilize J19 Pins 2/3 (SSC_QUP6) for OSD UART communication.
      As these pins are connected to the DSP (SLPI processor), the current OSD implementation cannot access SSC_QUP6 directly because it requires QURT compatibility.
      I kindly request that the OSD program be extended for QURT compatibility so it can function over SSC_QUP6 (J19 Pins 2/3). This modification would free up /dev/ttyHS0 for other critical tasks and allow more efficient use of the VOXL 2 Mini's available UART resources.
      Thank you for considering this request. I look forward to your response and any guidance on potential workarounds or a timeline for implementing QURT compatibility for the OSD program.
      • Eric KatzfeyE
        Eric Katzfey ModalAI Team @JP Drone
        @JP-Drone Okay, I will try to get it running on the DSP side to use J19. I'm guessing that you don't use GPS so it's okay to use that UART port for OSD? I should be able to complete this by the end of the year.
        JP DroneJ 1 Reply Last reply Reply Quote 0
        • JP DroneJ
          JP Drone @Eric Katzfey
          @Eric-Katzfey Thank you for your response.
          Yes, that's correct. I don't use GPS for indoor flight, so it's fine to use that UART port on J19 for OSD.
          I appreciate your support and look forward to the update.
          • Eric KatzfeyE
            @JP-Drone Can you try this voxl-px4 package and see if msp_dp_osd works for you on the GPS UART? You will need to add the driver start command in /usr/bin/voxl-px4-start. For example: qshell msp_dp_osd start -d 6. Download the package with wget http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.87-202412180935_arm64.deb or use the link http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.87-202412180935_arm64.deb
            JP DroneJ 2 Replies Last reply Reply Quote 0
            • JP DroneJ
              @Eric-Katzfey Thank you for providing the updated package.
              I will test it within the next three days.
              I’ll get back to you with the results shortly.
              • JP DroneJ
                @Eric-Katzfey Thank you for your support and the updated package.
                I have successfully verified that the OSD works using J19 pins for UART communication. The msp_dp_osd program is displaying the OSD as expected.
                However, I noticed an issue where a STATUS message or similar text is displayed in two locations. One appears correctly in the lower-left corner, as configured, but another is also visible near the center-left of the screen (please see the attached image).
                Could you confirm if this behavior is expected?
                Current configurations:
                OSD_DIS_COL 1
                OSD_DIS_ROW 11
                OSD_STATUS_COL 1
                OSD_STATUS_ROW 17
                I would also be happy to handle long error messages.
                Eric KatzfeyE 2 Replies Last reply Reply Quote 0
                • Eric KatzfeyE
                  @JP-Drone No, that isn't expected. Can you send the values of all OSD parameters? What type of VTX unit are you connecting to? If you set OSD_STATUS_ROW to -1 do both messages disappear or only one of them? I see it is also showing the VIO status which is controlled by the parameters OSD_VIO_COL and OSD_VIO_ROW.
                  • Eric KatzfeyE
                    @JP-Drone Does it work as expected when you try it from the J10 port (/dev/ttyHS0)?
                    • JP DroneJ
                      @Eric-Katzfey
                      Here is the OSD params
                      1	1	OSD_BAND	5	6
                      1	1	OSD_BATT_COL	44	6
                      1	1	OSD_BATT_ROW	17	6
                      1	1	OSD_CBATT_COL	44	6
                      1	1	OSD_CBATT_ROW	16	6
                      1	1	OSD_CHANNEL	1	6
                      1	1	OSD_CH_COL	-1	6
                      1	1	OSD_CH_HEIGHT	0	6
                      1	1	OSD_CH_ROW	-1	6
                      1	1	OSD_CURR_COL	-1	6
                      1	1	OSD_CURR_ROW	-1	6
                      1	1	OSD_DIS_COL	1	6
                      1	1	OSD_DIS_ROW	11	6
                      1	1	OSD_DWELL_TIME	500	6
                      1	1	OSD_FM_COL	1	6
                      1	1	OSD_FM_ROW	9	6
                      1	1	OSD_HDG_COL	21	6
                      1	1	OSD_HDG_ROW	0	6
                      1	1	OSD_HOME_COL	-1	6
                      1	1	OSD_HOME_ROW	-1	6
                      1	1	OSD_LAT_COL	-1	6
                      1	1	OSD_LAT_ROW	-1	6
                      1	1	OSD_LOG_LEVEL	3	6
                      1	1	OSD_LONG_COL	-1	6
                      1	1	OSD_LONG_ROW	-1	6
                      1	1	OSD_REMOTE	0	6
                      1	1	OSD_RSSI_COL	-1	6
                      1	1	OSD_RSSI_ROW	-1	6
                      1	1	OSD_SCROLL_RATE	125	6
                      1	1	OSD_STATUS_COL	1	6
                      1	1	OSD_STATUS_ROW	17	6
                      1	1	OSD_SYMBOLS	16383	6
                      1	1	OSD_VIO_COL	38	6
                      1	1	OSD_VIO_ROW	0	6
                      Thank you for the advice.
                      Both messages are disappeared when I set OSD_STATUS_ROW to -1
                      Also it was working as expected when I try it from the J10 port
                      • JP DroneJ
                        JP Drone @JP Drone
                        @Eric-Katzfey
                        I think the messages of OSD_STATUS_ROW appear on both, OSD_STATUS and OSD_FM.
                        Problem seems the message is appear to OSD_FM_ROW when OSD_STATUS_ROW is enabled.
                        • Eric KatzfeyE
                          @JP-Drone Looks like there was an issue with the handling of strings in the DSP version of the code. I made an update, can you try it now? http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.89-202412270902_arm64.deb
                          • JP DroneJ
                            @Eric-Katzfey
                            Thank you for your quick update.
                            I was able to confirm that it is functioning properly.
                            Really appreciate your support. Wishing you a wonderful New Year!
