  3. Need VOXL2 with 256GB Flash
5 Posts 3 Posters 739 Views 1 Watching
  • H Offline
    H Offline
    henrytrinh
    I am using VOXL2 in my application.
    This SOM has 128GB Flash. I need more storage (256GB Flash).
    Is it possible to request 256GB Flash on the VOXL2?
    Thanks and Best Regards,
    -Henry T.
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @henrytrinh yes this is possible with external storage - you can leverage a USB2.0 or 3.0 and connect a microsd adapter and then mount the drive.
      Zach
      H 1 Reply Last reply
        Zach
        H Offline
        H Offline
        henrytrinh
        @Zachary-Lowell-0 Thanks for the info. I was hoping to see if ModalAI could populate the VOXL2 with 256GB Flash instead of the default 128GB Flash (like a custom order for us). I don't have the option to use a microsd adapter in my application.
        -Henry
        VinnyV 1 Reply Last reply
        • H henrytrinh
          -Henry
          VinnyV Offline
          VinnyV Offline
          Vinny
          Hi @henrytrinh
          For us to do that there is a significant validation NRE needed and then a minimum commitment buy.
          This would not be a cheap option.
          Likely well above $25K validation effort, possibly more. 200 units+ MOQ for starters most likely. Our standard builds are above 500 units.
          If that is something you are willing to think about, feel free to reach us on our contact page and we can work up a quote for you. Do not "quote" my numbers above 🙂 , but it is in the magnitude you need to be thinking about for this customization.
          https://www.modalai.com/pages/contact-us
          • VinnyV Vinny
            Hi @henrytrinh
            H Offline
            H Offline
            henrytrinh
            @Vinny Thank you for your info. I will review with my team and see if it makes sense for us to pursuit that direction/option.
            Best Regards,
            -Henry
