    Need VOXL2 with 256GB Flash
    • H
      henrytrinh
      I am using VOXL2 in my application.
      This SOM has 128GB Flash. I need more storage (256GB Flash).
      Is it possible to request 256GB Flash on the VOXL2?
      Thanks and Best Regards,
      -Henry T.
      • Zachary Lowell 0Z
        Zachary Lowell 0 ModalAI Team
        @henrytrinh yes this is possible with external storage - you can leverage a USB2.0 or 3.0 and connect a microsd adapter and then mount the drive.
        Zach
        H 1 Reply Last reply Reply Quote 0
        • H
          henrytrinh @Zachary Lowell 0
          @Zachary-Lowell-0 Thanks for the info. I was hoping to see if ModalAI could populate the VOXL2 with 256GB Flash instead of the default 128GB Flash (like a custom order for us). I don't have the option to use a microsd adapter in my application.
          -Henry
          • VinnyV
            Vinny ModalAI Team @henrytrinh
            Hi @henrytrinh
            For us to do that there is a significant validation NRE needed and then a minimum commitment buy.
            This would not be a cheap option.
            Likely well above $25K validation effort, possibly more. 200 units+ MOQ for starters most likely. Our standard builds are above 500 units.
            If that is something you are willing to think about, feel free to reach us on our contact page and we can work up a quote for you. Do not "quote" my numbers above 🙂 , but it is in the magnitude you need to be thinking about for this customization.
            https://www.modalai.com/pages/contact-us
            • H
              henrytrinh @Vinny
              @Vinny Thank you for your info. I will review with my team and see if it makes sense for us to pursuit that direction/option.
              Best Regards,
              -Henry
