  3. Indoor Altitude Estimate Divergence
starling
2 Posts 1 Posters 509 Views
  • G Offline
    G Offline
    griffin
    Hey All,
    Testing indoors I've had several instances of altitude estimate divergence requiring reversion to manual control and an emergency landing on a starling 2 max.
    It seems that the error begins when I activate the offboard mode with the default figure 8 loaded.
    My assumption is that as the drone yaws it loses some of the VIO points and is uncertain about its altitude causing a rapid climb in offboard and position modes.
    What would the best way be to correct this issue?
    • I could try to add visual markers (i.e. april tags) to the warehouse walls to provide more references?
    • Does the starling 2 max use both forward and downward facing cameras for VIO? I thought I saw a post about this feature being enabled in the nightly builds but am unsure.
    • Should I expect these issues to improve inherently by moving into a more visually active space (inside an unoccupied office area)? I am hesitant to fly in more confined areas without being confident in the aircraft estimate and position holding reliability.
    Kind regards,
    Griffin
    G 1 Reply Last reply
    • G griffin
      Hey All,
      Kind regards,
      Griffin
      G Offline
      G Offline
      griffin
      @admin @Moderator Any suggestions on how to prevent this altitude divergence? This happens somewhat regularly and requires reversion to manual control.
