  2. VOXL SDK and Software
  3. Setting up Voxl2 MicroDDS Communication with PX4
ros
8 Posts 3 Posters 2.5k Views
  • James KDHJ Offline
    James KDHJ Offline
    James KDH
    Hello, I tried following this guide to set up Voxl2 MicroDDS Communication with PX4. After running the two commands given in the documentation:
    1. apt install -y voxl-microdds-agent
    2. voxl-configure-microdds
    I don't see any uORB topics published in ROS2. I have tried using voxl-inspect-services and the micro-dds-agent is indeed running in the voxl2. Am I missing something here? Thanks!
      James KDHJ Offline
      James KDH
      I am running SDK version 1.35 on starling 2.
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        Hi @James-KDH - just to confirm have you installed ros2 foxy and the mpa-to-ros2 deb's on there as well? Those packages contain all the prebuilt ros2 messages that allow you to see the topics.
        apt-get install voxl-ros2-foxy && apt-get install voxl-mpa-to-ros2
        followed by voxl-configure-mpa-to-ros2 - then please do a reboot o nthe entire system and then check the output of the dds via ros2 topic list and if nothing is there please paste the following:
        systemctl status voxl-microdds-agent and paste the output here.
        James KDHJ 1 Reply Last reply
          James KDHJ Offline
          James KDHJ Offline
          James KDH
          @Zachary-Lowell-0 Yes I have installed ros2 foxy and the mpa-to-ros2 deb. Running the command:
          Gives this output:
          Meanwhile running :
          ros2 topic list
          Still gives nothing:
            James KDHJ Offline
            James KDH
            Hello, I managed to fix this issue. Turns out the ROS domain ID needs to be 0 (by default), I set it to 1 previously and could not echo out the fmu topics. By simply setting it to 0 again i am able to see the /fmu topics now.
            export ROS_DOMAIN_ID=0
            However I encounter another issue where I am unable to see the /fmu out topics in an external computer but voxl2 can see topics that are being published by the computer as shown in the image below.
            Also is there a way to remap the topic names ? i.e from /fmu to /drone_1.
            To give some context, me and my lab is trying to experiment with indoor swarming. Thus it is essential for the drones to be able to communicate with each other (such as via ROS2).
            • B Offline
              B Offline
              brahim
              Make sure these variables are set on the voxl2 and external pc:
              ROS_DOMAIN_ID = 0
              ROS_LOCALHOST_ONLY = 0
              You can check if multicast is enabled on both sides with this command (assuming external pc is linux):
              ifconfig | grep -i multicast
              This should show multicast enabled for the interface (wifi or ethernet) connected to the external pc via network.
              • B brahim
                ROS_DOMAIN_ID = 0
                James KDHJ Offline
                James KDHJ Offline
                James KDH
                @brahim I tried setting on both the voxl2 and external PC
                ROS_DOMAIN_ID = 0
                and I am still unable to see the /fmu topics on the external pc. Running
                Results in something like in both the external pc and voxl2.
                bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST>  mtu 1500
                docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
                wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                Which indicates that multicast enabled on both the external pc and voxl2.
                  James KDHJ Offline
                  James KDH
                  Okay I managed to solve the problem. The reason why my external pc is unable to see the /fmu topics is probably due to the voxl-microdds-agent service starting before the network is fully "set up". From this stack overflow topic, I edited my /etc/systemd/system/voxl-microdds-agent.service file to include the line ExecStartPre=/bin/sh -c 'until ping -c1 google.com; do sleep 1; done; (this is the only "hacky" method that somehow worked). My entire service file is:
                  [Unit]
                  Description=voxl-microdds-agent
                  SourcePath=/usr/bin/MicroXRCEAgent
                  After=network.target
                  After=multi-user.target
                  # After=network-online.target
                  # Wants=network-online.target
                  [Service]
                  User=root
                  Type=simple
                  ExecStartPre=/bin/sh -c 'until ping -c1 google.com; do sleep 1; done;'
                  ExecStart=/usr/bin/MicroXRCEAgent udp4 -p 8888
                  [Install]
                  WantedBy=multi-user.target
                  After modifying the service file and rebooting the voxl2, the external computer can now see and echo topics from the /fmu. This will obviously not work if the voxl2 is not connected to the internet.. However you can still manually fix this by ssh or adb shell into the voxl2 and restart the service using the commands:
                  systemctl stop voxl-microdds-agent
                  systemctl start voxl-microdds-agent
                  and the external computer should be able to see /fmu topics.
                  On a side note, to customize & add a prefix to the /fmu topic such that it is /drone1/fmu/ in ROS2, edit the px4 start up script /usr/bin/voxl-px4-start. There is a line that starts the microdds_client for px4 where:
                  # Start microdds_client for ros2 offboard messages from agent over localhost
                  microdds_client start -t udp -h 127.0.0.1 -p 8888
                  Simply add -n <desired _name> such that it becomes:
                  microdds_client start -t udp -h 127.0.0.1 -p 8888 -n drone2
                  • T teddy.zaremba referenced this topic on
