Flash Flat Build Fails in QDL recovery steps
I'm trying to unbrick a VOXL 2 that has gone into EDL mode (Reading as QUAL_BULK). I've got the system into QDL mode and it is being read as (QDL MODE). No issues provisioning or flashing CDT.
Once I get to the Flash Flat Build stage, the system immediately sends the following failure {"message": "Flash flat build failed\n"}. I've tried on a Virtual Machine and on a dedicated Linux PC. Any thoughts as to why it may be failing?
Flash Flat Build: 2024-06-17-1.7.4-M0054-1
VOXL2: QRB 5165M
VOXL2: QRB 5165M
@swickliff I am using Ubuntu 20.04 on both the VM and Linux PC
@yardy Folks recover using that tool all of the time. When it doesn't work, it's due to hardware damage. Often from ESD, or simply crashing the drone. See https://modalai.com/handling
