Placement of Order without Battery
Dear ModalAI,
Can you confirm the size and capacity of the battery cells used in Starling 2 Max? Does it use Sony VTC6 18650 battery cells like the Starling 2 or are they larger like 21700 cells? I'm afraid the datasheet and forums weren't helpful in answering this query so your help would be much appreciated.
Additionally, is it possible to purchase the Starling 2 Max C29 drone + controller without the battery? This specific option is not mentioned on the website. If yes, what is the procedure for going ahead with this purchase?
Thank you
Dear ModalAI,
Thank you
@Usama-Hamayun you can order the drone without battery.
The Starling 2 and Starling 2 Max both use the same battery packs. They can be either Sony VTC6 or Amprius 18650 cells
