  3. qvio_overlay "ERR CAM_MISSING CAM_BAD_RES STALLED" on Starling 2
starling
4 Posts 2 Posters 870 Views
  • N Offline
    N Offline
    nuallaino
    wrote on last edited by nuallaino
    I recently received a Startling 2 drone and have been trying to get the Mapper functionality to work.
    I tried SDK 1.3.3 and then tried 1.3.4-202409192201.
    TOF seems to be working fine, as is the tracking_front camera however QVIO is not. See the attached screenshot and logs.
    Any advice on how to resolve this would be appreciated.
    voxl2:/$ voxl-inspect-qvio
    waiting for server
     dt(ms) |    T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)|features|quality| state| error_codes |
       31.1 |    0.00    0.00    0.00|   0.0   -0.0    0.0|     0  |   -1% | FAIL | CAM_MISSING CAM_BAD_RES STALLED ^C
    received SIGINT Ctrl-C
    closing and exiting
    voxl2:/$ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  |   Running   |    93.9%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.3%
     voxl-imu-server          |  Enabled  |   Running   |     3.6%
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mavlink-server      |  Enabled  |   Running   |     3.1%
     voxl-neopixel-manager    | Disabled  | Not Running |
     voxl-open-vins-server    | Disabled  | Not Running |
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |    24.1%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    21.6%
     voxl-qvio-server         |  Enabled  |   Running   |     5.0%
     voxl-rangefinder-server  |  Enabled  |   Running   |     0.5%
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-vision-hub          |  Enabled  |   Running   |     4.1%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
    voxl2:/$ cat /etc/modalai/voxl-camera-server.conf
     * voxl-camera-server Configuration File
     * Each camera has configurations for up to 4 HAL3 streams:
     *    - `preview` stream for raw unprocessed images from CV cameras
     *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
     *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
     *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
     * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
     * This file is generated from default values by voxl-configure-cameras.
     * Do not expect arbitrary resolutions to work, the ISP and video compression
     * pipelines only support very specific resolutions.
     * The default video compression mode is cqp or Constant Quantization Parameter
    	"version":	0.1,
    	"fsync_en":	true,
    	"fsync_gpio":	109,
    	"cameras":	[{
    			"type":	"ar0144",
    			"name":	"tracking_front",
    			"enabled":	true,
    			"camera_id":	0,
    			"fps":	30,
    			"en_rotate":	true,
    			"en_preview":	true,
    			"preview_width":	1280,
    			"preview_height":	800,
    			"en_raw_preview":	true,
    			"ae_mode":	"lme_msv",
    			"ae_desired_msv":	60,
    			"exposure_min_us":	20,
    			"exposure_max_us":	33000,
    			"gain_min":	54,
    			"gain_max":	8000,
    			"exposure_soft_min_us":	5000,
    			"ae_exposure_period":	1,
    			"ae_gain_period":	1
    			"type":	"imx412",
    			"name":	"hires",
    			"enabled":	true,
    			"camera_id":	1,
    			"fps":	30,
    			"en_preview":	false,
    			"preview_width":	640,
    			"preview_height":	480,
    			"en_raw_preview":	false,
    			"en_small_video":	true,
    			"small_video_width":	1024,
    			"small_video_height":	768,
    			"small_venc_mode":	"h265",
    			"small_venc_br_ctrl":	"cqp",
    			"small_venc_Qfixed":	30,
    			"small_venc_Qmin":	15,
    			"small_venc_Qmax":	40,
    			"small_venc_nPframes":	9,
    			"small_venc_mbps":	2,
    			"en_large_video":	true,
    			"large_video_width":	4056,
    			"large_video_height":	3040,
    			"large_venc_mode":	"h265",
    			"large_venc_br_ctrl":	"cqp",
    			"large_venc_Qfixed":	38,
    			"large_venc_Qmin":	15,
    			"large_venc_Qmax":	50,
    			"large_venc_nPframes":	29,
    			"large_venc_mbps":	30,
    			"en_snapshot":	true,
    			"en_snapshot_width":	4056,
    			"en_snapshot_height":	3040,
    			"exif_focal_length":	3.0999999046325684,
    			"exif_focal_length_in_35mm_format":	17,
    			"exif_fnumber":	1.2400000095367432,
    			"ae_mode":	"isp"
    			"type":	"pmd-tof-liow2",
    			"name":	"tof",
    			"enabled":	true,
    			"camera_id":	2,
    			"fps":	10,
    			"en_rotate":	true,
    			"ae_mode":	"off",
    			"exposure_max_us":	6000,
    			"standby_enabled":	false,
    			"decimator":	5
    			"type":	"ar0144",
    			"name":	"tracking_down",
    			"enabled":	true,
    			"camera_id":	3,
    			"fps":	30,
    			"en_rotate":	false,
    			"en_preview":	true,
    			"gain_min":	54,
    			"gain_max":	8000,
    			"ae_gain_period":	1
    voxl2:/$ cat /etc/modalai/voxl-qvio-server.conf
     * This file contains configuration that's specific to voxl-qvio-server.
     * voxl-qvio-server also uses parameters from the following config files:
     * /etc/modalai/extrinsics.conf
     * /data/modalai/opencv_tracking_intrinsics.yml
     * parameter descriptions:
     * mask_file_path: A file path for qvio mask.
     * 1/4 resolution image (w.r.t. VGA), 160 x 120,
     * PGM format, the part of the camera view for which
     * pixels are set to 255 is blocked from feature
     * detection useful, e.g., to avoid detecting & tracking
     * points on landing gear reaching into camera view.
     * imu_name: VOXL uses imu1 by defualt since it's the most reliable. On
     * VOXL-FLIGHT you can optionally try imu0 which is a newer icm42688
     * voxl-configure-mpa will decide which IMU to use for you.
     * cam_name: camera to use, defaults to tracking0
     * odr_hz: Output data date is independent from the camera frame rate so you can
     * choose the desired output data rate. Note that voxl-imu-server defaults to
     * 500hz imu sampling but new data is received by voxl-qvio-server at 100hz by
     * default so requesting qvio data faster requires updating voxl-imu-server.
     * use_camera_height_bootstrap: When enabled, the feature estimator will assume
     * the system starts up with the camera pointed partially at the ground and use
     * this to make an intial guess of the feature's depth. This should be enabled
     * for drones that have known-height landing gear.
     * camera_height_off_ground_m: camera distance above ground (meters) for the
     * above bootstrap feature.
     * enable_init_while_moving: optionally allow the algorithm to initialize or
     * reinitialize while moving. Use this if you want to be able to reinitialize
     * during flight. Based on camera motion, not IMU motion. Recommended to leave
     * this off unless absolutely desired.
     * cam_imu_timeshift_s: Misalignment between camera and imu timestamp in
     * seconds.
     * cam_imu_timeshift_s_uncertainty: uncertainty in camera imu timestamp
     * misalignment
     * T_cam_wrt_imu_uncertainty[3] & R_cam_to_imu_uncertainty[3]: uncertainty in
     * camera-imu translation
     * accl_fsr_ms2 & gyro_fsr_rad: Full scale range used to detect clipping. By
     * default this is set to a little under the real 16G and 2000DPS FSR so
     * clipping is detected reliably
     * accl_noise_std_dev & gyro_noise_std_dev: standard deviation of accl and gyro
     * noise
     * cam_noise_std_dev: Standard dev of camera noise per pixel.
     * min_std_pixel_noise: Minimum of standard deviation of feature measurement
     * noise in pixels.
     * fail_high_pixel_noise_points: Scales measurement noise and compares against
     * search area (is search area large enough to reliably compute measurement
     * noise covariance matrix).
     * limited_imu_bw_trigger: To prevent tracking failure during/right after (hard)
     * landing: If sum of 3 consecutive accelerometer samples in any dimension
     * divided by 4.3 exceed this threshold, IMU measurement noise is increased (and
     * resets become more likely); if platform vibrates heavily during flight, this
     * may trigger mid- flight; if poseQuality in mvVISLAMPose drops to
     * MV_TRACKING_STATE_LOW_QUALITY during flight, improve mechanical dampening
     * (and/or increase threshold). QC default is 35, we prefer 25.
     * gps_imu_time_alignment_s: Misalignment between GPS and IMU time in seconds
     * T_gps_wrt_imu: location of gps with respect to the IMU in meters
     * enable_mapping: rudimentary lightweight mapping of feature points, leave this
     * on.
     * enable_gps_vel: allow gps velocity to be added to VIO, requires ModalAI
     * custom PX4 firmware to expose this data. This is an Alpha feature, don't
     * enable this unless instructed to.
     * en_auto_reset: on by default. If any one of the following thresholds are met
     * voxl-qvio-server will assume an otherwise undetected fault has occured in
     * the inderlying algorithm and will hard reset the QVIO library.
     * auto_reset_max_velocity: meters per second, if velocity faster than this is
     * detected then an auto-reset is triggered
     * auto_reset_max_v_cov_instant: if the covariance of the velocity estimate ever
     * exceeds this for a since sample then an auto-reset is triggered
     * auto_reset_max_v_cov: if th covariance of the velocity estimate ever exceeds
     * this for more than auto_reset_max_v_cov_timeout_s then an auto-reset is triggered
     * auto_reset_max_v_cov_timeout_s: time period for auto_reset_max_v_cov criteria
     * auto_reset_min_features: if fewer than this number of features are tracked for
     * more than auto_reset_min_feature_timeout_s then an auto-reset is triggered.
     * it is okay for feature tracking to be lost for short periods of time.
     * en_standby_mode: When enabled, qvio will skip camera frames while voxl-cpu-monitor
     *                  reports that the CPU is in standby mode.
     * standby_skip_frames: number of frames to skip before processing one. default is 1,
                            meaning skip every other frame. 30 -> 15hz
    	"imu_name":	"imu_apps",
    	"cam_name":	"tracking_front",
    	"lens_cal_path":	"/data/modalai/opencv_tracking_front_intrinsics.yml",
    	"cam_extrinsics_name":	"tracking_front",
    	"use_second_cam_if_stereo":	false,
    	"odr_hz":	30,
    	"use_camera_height_bootstrap":	true,
    	"camera_height_off_ground_m":	0.085000000894069672,
    	"enable_init_while_moving":	false,
    	"cam_imu_timeshift_s":	-0.0020000000949949026,
    	"cam_imu_timeshift_s_uncertainty":	0.0010000000474974513,
    	"T_cam_wrt_imu_uncertainty":	[0.00050000002374872565, 0.00050000002374872565, 0.00050000002374872565],
    	"R_cam_to_imu_uncertainty":	[0.00499999988824129, 0.00499999988824129, 0.00499999988824129],
    	"accl_fsr_ms2":	156,
    	"gyro_fsr_rad":	34,
    	"accl_noise_std_dev":	0.31600001454353333,
    	"gyro_noise_std_dev":	0.00999999977648258,
    	"cam_noise_std_dev":	100,
    	"min_std_pixel_noise":	0.5,
    	"fail_high_pixel_noise_points":	1.6650999784469604,
    	"limited_imu_bw_trigger":	25,
    	"gps_imu_time_alignment_s":	0,
    	"T_gps_wrt_imu":	[0, 0, 0],
    	"enable_mapping":	true,
    	"enable_gps_vel":	false,
    	"en_auto_reset":	true,
    	"auto_reset_max_velocity":	10,
    	"auto_reset_max_v_cov_instant":	0.10000000149011612,
    	"auto_reset_max_v_cov":	0.00999999977648258,
    	"auto_reset_max_v_cov_timeout_s":	0.5,
    	"auto_reset_min_features":	3,
    	"auto_reset_min_feature_timeout_s":	1,
    	"en_standby_mode":	true,
    	"standby_skip_frames":	1,
    	"mask_file_path":	""
    voxl2:/$
    ModeratorM 2 Replies Last reply
    • N nuallaino
      waiting for server
      closing and exiting
      	"version":	0.1,
      	"fsync_en":	true,
      	"fsync_gpio":	109,
      	"cameras":	[{
      			"type":	"ar0144",
      			"enabled":	true,
      			"camera_id":	0,
      			"fps":	30,
      			"en_rotate":	true,
      			"en_preview":	true,
      			"gain_min":	54,
      			"gain_max":	8000,
      			"ae_gain_period":	1
      			"type":	"imx412",
      			"name":	"hires",
      			"enabled":	true,
      			"camera_id":	1,
      			"fps":	30,
      			"ae_mode":	"isp"
      			"name":	"tof",
      			"enabled":	true,
      			"camera_id":	2,
      			"fps":	10,
      			"en_rotate":	true,
      			"ae_mode":	"off",
      			"decimator":	5
      			"type":	"ar0144",
      			"enabled":	true,
      			"camera_id":	3,
      			"fps":	30,
      			"en_rotate":	false,
      			"en_preview":	true,
      			"gain_min":	54,
      			"gain_max":	8000,
      			"ae_gain_period":	1
       * seconds.
       * misalignment
       * noise
       * noise in pixels.
       * on.
      	"odr_hz":	30,
      	"gyro_fsr_rad":	34,
      voxl2:/$
      • N nuallaino
        waiting for server
        closing and exiting
        	"version":	0.1,
        	"fsync_en":	true,
        	"fsync_gpio":	109,
        	"cameras":	[{
        			"type":	"ar0144",
        			"enabled":	true,
        			"camera_id":	0,
        			"fps":	30,
        			"en_rotate":	true,
        			"en_preview":	true,
        			"gain_min":	54,
        			"gain_max":	8000,
        			"ae_gain_period":	1
        			"type":	"imx412",
        			"name":	"hires",
        			"enabled":	true,
        			"camera_id":	1,
        			"fps":	30,
        			"ae_mode":	"isp"
        			"name":	"tof",
        			"enabled":	true,
        			"camera_id":	2,
        			"fps":	10,
        			"en_rotate":	true,
        			"ae_mode":	"off",
        			"decimator":	5
        			"type":	"ar0144",
        			"enabled":	true,
        			"camera_id":	3,
        			"fps":	30,
        			"en_rotate":	false,
        			"en_preview":	true,
        			"gain_min":	54,
        			"gain_max":	8000,
        			"ae_gain_period":	1
         * seconds.
         * misalignment
         * noise
         * noise in pixels.
         * on.
        	"odr_hz":	30,
        	"gyro_fsr_rad":	34,
        voxl2:/$
        @nuallaino you can see how that error is generated here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-qvio-server/-/blob/master/server/main.cpp?ref_type=heads#L683
        N 1 Reply Last reply
        • ModeratorM Moderator
          N Offline
          N Offline
          nuallaino
          @Moderator Yes, I did see that. However I expected this to work out of the box. I haven't changed anything.
