  3. Mechanical Integration
4 Posts 3 Posters 813 Views
  • A Offline
    ayrric
    wrote on last edited by ayrric
    1. Does ModalAI have recommendations for spacers between adapter boards so that we use the mounting holes to secure the stackup in place?
    2. Are there any heat sinking considerations, particularly as we stack add-ons?
    3. For the Camera adapter board it seems that the users are expected to mount the microcoax cables prior to connecting the adapter board to the VOXL2 carrier board. Is this the intention? And if so, does this help secure the connectors in place or do you think we should back up the connectors with foam?
    4. We notice an interference with connector "E" using the STEP files when the camera adapter board is inserted, is there something we are missing? We will receive our first parts next week.
    ModeratorM JacobJ 2 Replies Last reply
    • A ayrric
      @ayrric If there is active airflow, there should not be a thermal issue. We have a writeup on the topic here: https://docs.modalai.com/voxl2-thermal-performance/
      For the other mechanical integration topics, we will try to get back to you early this week.
      A 1 Reply Last reply
      • ModeratorM Moderator
        ayrric
        @Moderator Thank you for the feedback and looking into the other questions we had. You can disregard #4 as we received the parts and see that we used a step file that wasn't the camera adapter board so the actual boards don't have this interference.
        • A ayrric
          JacobJ Offline
          JacobJ Offline
          Jacob
          @ayrric
          1. We currently use a mix of 4 and 5mm spacers (we have used threaded on older model drones, current ones utilize unthreaded).
          • 4mm are used on certain boards that connect to the underside of the Voxl, such as on the Starling 2 and Starling 2 Max.
          • 5mm are used on most B2B connections on the top side of a Voxl. This has been used on Sentinels and all Starling variants for the Wi-Fi or Modem boards.
          1. I personally am not overly familiar with the components to answer this with certainty, but can say that we do not use any additional heat sinking on Starling model drones. Drones such as a sentinel with an add-on board will have a small fan pre-installed, but that is standard with the base model and on the other side of the board. We do have a small heat sink included with the ToF assembly on Starling 2 and Starling 2 Maxes.
          2. If you are referring to the Starling 2 Image Sensor Adapter, then it can be done in a variety of ways. Our current production process involves connecting the coax to both the image sensors the adapter board before installed to the Voxl 2. In some instances, we do use a bit of foam to secure some of them in place to prevent accidental release. (However, this is primarily a concern with the ToF flex cable, and not the mechanically held in place coax connectors.)
            We do also use a little bit of ESD safe tape (Kapton) to hold down some of the thin errant coax wires to prevent them from being pinched in the process of connecting the two boards.
            These coax connectors are fairly robust once installed but only rated for (as far as I am aware) roughly 30 connection cycles. So regardless of how or when you choose to install them, take caution in having to do it repeatedly. As long as you provide careful and even pressure when installing them it should be okay.
          Hopefully that answered your questions well enough!
