  3. Haze over ov7251 Tracking Camera.
image-sensor
2 Posts 2 Posters 495 Views 1 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hey @Alex-Kushleyev @James-Strawson
    I'm using a Starling 2 with VOXL 2 setup on a custom airframe build. I'm currently testing the setup with SDK release 1.2.0.
    In the initial testing, in the QVIO server as from the input pipeline was displaying a clear display of features. But over time, the QVIO server output feed has been blurry with a kind of haze being formed around camera frame as seen in the feed. This reduces the features being captured, and the drone loses VIO many a times ultimately loosing position.
    Is there any way we can clear this haze and initialise the QVIO server?
    Note: Also checked if it was a physical damage to the Lens or hardware but hardware seems to be fine.
    • Jetson NanoJ Jetson Nano
      @Jetson-Nano ,
      Can you please double check your /etc/modalai/voxl-camera-server.conf to make sure that the tracking camera has "en_raw_preview" set to true?
      It is hard to tell whether there is haze in the image (the tracking camera has 640x480 resolution and if you zoom in, it may appear that the details are blurry). If you have another tracking camera to compare to, please try. Also please try looking at the image from voxl-portal (original tracking image and overlay image).
