  3. GPS streaming
GPS streaming
8 Posts 2 Posters 1.1k Views 1 Watching
  • groupoG Offline
    groupoG Offline
    groupo
    I'd like to pull GPS positions off of my drone as it is flying. I am not sure the best way to approach this. I know GPS info is part of the MAVLink stream being sent to QGC. Is it possible to have voxl-mavlink-server stream a specific message to a different IP in parallel? Or, is it simple enough to pull the GPS data off of QGC in realtime? I tried consulting the docs for mavlink-server, but that entry is particularly sparse. TIA
    • groupoG groupo
      @groupo You can modify voxl-mavlink-server to send to a parallel IP. Or you can write a separate application that listens to the mavlink pipe published by voxl-mavlink-server and have it forward GPS info to another IP. The voxl-vision-hub application reads mavlink messages this way and can be used as an example. Check the file: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-vision-hub/-/blob/master/src/mavlink_io.c?ref_type=heads#L120
      groupoG 1 Reply Last reply
        groupoG Offline
        groupoG Offline
        groupo
        @Eric-Katzfey by parallel IP do you mean changing secondary_static_gcs_ip to whichever IP I desire?
        • groupoG groupo
          @groupo Oh, yeah, that should work. Did you try it?
            groupoG Offline
            groupoG Offline
            groupo
            @Eric-Katzfey not yet, had to shift gears but will be coming back to the drones soon though.
            For clarity, you are saying that the Sentinel will stream to both primary and secondary GCS, both on port 14550, even if a GCS connection is established on the primary?
            • groupoG groupo
              @groupo Yes, that's the intention.
                groupoG Offline
                groupoG Offline
                groupo
                @Eric-Katzfey I put up another post yesterday inquiring about this from a different angle. I stayed away from this because, while I can write C code, I am a little lost on how to compile and run it. I am particularly bad at setting up dev environments and try to leave that to the software engineers, haha. Even if I wrote what you were suggesting, it is still a mavlink message I would have to parse yeah? I have had trouble parsing the ulog files with pyulog. I can that messages exist, but I am not sure how to view them. At the end of the day, I really just want ideally a way to stream/send GPS truth data to a matlab process I am running on a host PC
                • groupoG groupo
                  @groupo I responded to your new post.
