    Cant Connect to Q Ground Control after SDK Update
    VOXL m500 Reference Drone
    • Samuel BryanS
      Samuel Bryan
      I recently updated the Voxl SDK on my Modal M500 from 0.9.5 to 1.2.0, and now the aircraft won't connect to Q Ground Control. When I open Q Ground Control, it says disconnected. The aircraft still connects to my laptop via wifi and I can SSH into the aircraft from a terminal.
      • Eric KatzfeyE
        Eric Katzfey ModalAI Team @Samuel Bryan
        @Samuel-Bryan Are you using SoftAP mode in WiFi (e.g. The drone WiFi is the access point) or are you using station mode (e.g. where your laptop and drone connect to an external router)?
        Samuel BryanS 1 Reply Last reply Reply Quote 0
        • Samuel BryanS
          Samuel Bryan @Eric Katzfey
          @Eric-Katzfey I am using SoftAP mode in Wifi.
