  3. Starling HITL no serial port data or connection made
starling
4 Posts 2 Posters 881 Views 1 Watching
  • J Offline
    JoeAR_21
    Hi, I've been having issues setting up the HITL simulator using this cable connected to the VOXL2 J18 port on the Starling: https://www.modalai.com/collections/accessories/products/mcbl-00010
    and I've been following this tutorial: https://docs.modalai.com/voxl2-PX4-hitl/
    When I connect this cable to the host-PC running Ubuntu 20.04 there is no USB-serial connection detected or made other than the existing USB-C port and it is not found in /dev/ttyUSB# and dmesg -w does not show any connection being made. I am unsure if this is a cable issue (I've tried numerous mini-usb cables) or a problem with the way Linux handles the connection as this tutorial video has a similar setup: https://youtu.be/ysvpJdXFWaM?si=1ltYazXT03agZOAl
    Any help is appreciated, thanks!
    • J JoeAR_21
      @JoeAR_21 Sounds like you don't have the right cable then. When you plug in the USB to serial cable then you will see a new /dev/ttyUSBx connection show up on the host-PC, regardless of whether it is attached to VOXL 2 or not. If that isn't happening then you don't have the correct cable.
      J 1 Reply Last reply
        JoeAR_21
        @Eric-Katzfey Is there a reliable link to a working version we can purchase or exchange it with? Thanks!
        • J JoeAR_21
          @JoeAR_21 I would just buy something like this: https://www.adafruit.com/product/954?gad_source=1&gclid=CjwKCAjwyo60BhBiEiwAHmVLJQuZ-9b9QJJtpK_PN6k5qN0jQMigyLn_nbWc5deXCZ8ZnSInlYXwrhoCxZAQAvD_BwE
