  3. AT commands to a Sierra Wireless EM9291
cellular
42 Posts 4 Posters 28.0k Views 4 Watching
  • modaltbM modaltb
    @groupo jumping in a bit and hopefully am in context.
    We do mount from host to docker here:
    https://gitlab.com/voxl-public/system-image-build/qrb5165-kernel-build-docker/-/blob/qrb5165-ubun1.0-14.1a/docker-run-image.sh?ref_type=heads#L9
    During the build, you'll get 'copies' of everything at something like:
    qrb5165-build-docker/workspace/qrb5165-ubun-1-0_amss_oem/lu.um.1.2.1/apps_proc/build-qti-distro-ubuntu-fullstack-perf/
    Don't edit those...
    If you edit files in say this dir directly:
    apps_proc/src/kernel/msm-qrb5165-4.19/drivers/
    Then they should get picked up by the build. Easy way to tell, throw a compiler error on purpose in a file and try to build it.
    groupoG Offline
    groupoG Offline
    groupo
    wrote on last edited by groupo
    #41
    @modaltb hey Travis, thanks for chiming in. I can confirm that throwing in a syntax error in files in that path does break the build - so now I know where those changes need to be made. I appreciate the clarity.
      @groupo /dev/ttyUSB0 only enumerates if the driver recognizes the hardware of having said capability. In this case, the driver that controls that port doesn't recognize that modem hardware, likely the driver is from before that hardware existed.
      In these cases we usually have to make custom tweaks to the linux kernel drivers in order to add the support for the hardware.
      If you'd like to experiment with doing that you can, building custom kernels allows adding custom support for new or existing hardware.
      You can read more about building a custom kernel here: https://docs.modalai.com/voxl2-kernel-build-guide/
      groupoG Offline
      groupoG Offline
      groupo
      hey not sure if this is an @tom or @modaltb inquiry, but when following the steps for the kernel build guide, stuff is off with the drone. It boots up and I can adb fine, but there are issues with the wifi, similar to another post Tom helped me with two weeks ago, but for definitely not the same hardware-related reason. The wifi adaptable does not turn on and when you run voxl-wifi the mac address is undefined. I remember stepping through those scripts while troubleshooting the hardware issues and recall that script queries to find its mac address, which must be returning something invalid.
      I have tested this with both of my drones. I can very easily flash them back with https://docs.modalai.com/sentinel-factory-reset/ and they operate as expected. While my desire is to edit part of the usb driver scripts, the kernel I am attempting to put on the drone is the unchanged version following the steps here https://docs.modalai.com/voxl2-kernel-build-guide/. The only deviation from the guide is that the guide is written for SDK 1.1.3. I have put 1.3.0 on both of my drones, and from my understanding the docker scripts pull the default branch of each repo which has the same commit tags as 1.7.8. I have included the output of dmesg for both the 1.3.0 image available from the downloads page, and the results when following the custom kernel build steps.
      https://drive.google.com/drive/folders/14L5gLbAOfF2OcSW2rHFTI4VIoREkTCFJ?usp=sharing
