  3. ToF v2 ground level error
image-sensor
3 Posts 2 Posters 856 Views
  • Gyeongmin KimG Offline
    Gyeongmin Kim
    Hello there!
    I've been trying to change the depth sensor from ToF v1 to v2 because it is't supported anymore. And I've connected ToF v2 on voxl2 successfully.
    But I have been encountering the critical error about the ground level.
    The left red line is showing the pointcloud from the ground. As you can see, the level of ground is higher than the bottom of wall. I think it should be connected with the bottom of wall.
    I've tried the same experience with ToF v1 at the same place and time. It's showing the same ground level as I expected.
    May I have any comment about it? Thank you!
      Gyeongmin Kim
      Any update?
      ModeratorM 1 Reply Last reply
      • Gyeongmin KimG Gyeongmin Kim
        Any update?
        @Gyeongmin-Kim We don't have any great insight at this point. Those sensors are new. It looks like you are seeing some ghosting. You could try different frame rates or exposure times to try and minimize the artifacts
