  3. Voxlio board Sbus lagging
14 Posts 4 Posters 3.8k Views 2 Watching
  • Jeffrey MaoJ Offline
    Jeffrey Mao
    wrote on last edited by Jeffrey Mao
    Hi Modalai,
    Recently we connected a Jeti receiver to our voxl2 board using Sbus through the voxlio board with the px4 running on the voxl2 and ESC connected to the main Voxl2 board
    We noticed there is a significant lag between the remote’s command and the reaction from the Voxl2. The throttle/pitch/roll/arm/killswitch on our remote lags behind the real action. This problem does NOT exist if we directly plug the spectrum receicer to our voxl2 board, so this is NOT a control parameter issues
    We were wondering if you noticed this issue when using other remotes like Graupner sbus to the voxl2 board?
    Jeff
    • Jeffrey MaoJ Jeffrey Mao
      Hi Modalai,
      Jeff
      @Jeffrey-Mao , We have been testing using Graupner and there is no issue. However we have had a few reports that some SBUS receivers are causing the behavior that you are describing. I suspect that some radios may be using a modified SBUS protocol, or something like that.
      Just to double check, which version of the VOXL2 IO board (M0065 are you using) ?
      We can investigate it further.
      Jeffrey MaoJ 1 Reply Last reply
        Jeffrey Mao
        @Alex-Kushleyev Quick question how do we check the M0065 Version?
        Also have you guys tried Futaba remotes are they OK? Just wondering since they are on the list of RC with Graupner, but it seems Graupner's remotes are sold out everywhere
        https://docs.modalai.com/voxl2-rc-configs/
          @Jeffrey-Mao , I am checking whether we tried Futaba rx (the docs page says it is not supported).
          Meanwhile, I have a Ghost rx which can be configured in SBUS output mode, which has been reported to behave in the way you are describing. I will try it, perhaps there is a common issue related to Ghost and your Jeti receiver. I will try to get back to you today or tomorrow.
            if you look at voxl-px4 startup log (using journalctl or you can run voxl-px4 in foreground). Please ignore my firmware hash of M0065 (i am using a custom firmware, so it won't match yours, but it should match this one: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl2-io/-/blob/master/voxl2-io-tools/firmware/modalai_m0065_firmware_v0_2_RC1_f94baad1.bin )
            voxl2:/$ journalctl -u voxl-px4 | grep VOXL2_IO
            May 30 17:51:33 m0054 voxl-px4[3932]: ESC=VOXL2_IO_PWM_ESC
            May 30 17:51:33 m0054 voxl-px4[3932]: ESC: VOXL2_IO_PWM_ESC
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Driver starting
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_BAUD  : 921600
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC1 : 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC2 : 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC3 : 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC4 : 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC5 : 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC6 : 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC7 : 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC8 : 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_DIS   : 1000
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_MIN   : 1100
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_MAX   : 2000
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_CMIN  : 1050
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_CMAX  : 2000
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Opening UART device 2, baud rate 921600
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Successfully opened UART device
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Detecting M0065 board...
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO:         VOXL2_IO ID: 0
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO:         Board Type : 35: ModalAi I/O Expander (M0065)
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO:         Unique ID  : 0x4304296039364B560671FF36
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO:         Firmware   : version    2, hash f94baad1*
            May 30 17:51:36 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO:         Bootloader : verINFO  [qshell] Send cmd: 'voxl2_io start'
            May 30 17:51:37 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO:         Reply time : 524us
            May 30 17:51:37 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Driver initialization succeeded
            May 30 17:51:37 m0054 voxl-px4[3932]: INFO  [muorb] SLPI: VOXL2_IO: Detected VOXL2 IO SBUS RC
              Jeffrey Mao
              @Alex-Kushleyev We have the current thing
              Attempting to start M0065 SBUS RC driver for original M0065 FW
              INFO [muorb] SLPI: qshell gotten: dsp_sbus start
              INFO [muorb] SLPI: arg0 = 'dsp_sbus'
              INFO [muorb] SLPI: arg1 = 'start'
              INFO [qshell] Send cmd: 'dsp_sbus start'
              ERROR [muorb] SLPI: Failed to execute command: dsp_sbus start
              Starting M0065 SBUS RC driver for original M0065 FW failed
              Attempting to start M0065 SBUS RC driver for new M0065 FW
              INFO [qshell] Send cmd: 'voxl2_io start -d -p 7'
              INFO [muorb] SLPI: Ok executing command: voxl2_io start -d -p 7
              We will try updating the firmware and let you know how ti goes based on what you say
                @Jeffrey-Mao , which version of px4 are you using?
                BTW, i figured out the issue. When VOXL2_IO is not used for motor outputs (VOXL2_IO_FUNCx are all set to zero), the module updates at a very low rate (every 200-300ms) because the schedule thinks the mixer module is unused. This causes the data from M0065 board coming into VOXL2 (and voxl2_io driver) to be dropped and delayed.
                I am looking at a temporary workaround for this and a fix. As a workaround, setting param set VOXL2_IO_FUNC8 108 makes the module update at full rate (800hz) but i need to check to see what happens if you have a quad and what happens to motor 8 in that case.
                What are you using as motor outputs? voxl esc or also planning to use voxl2_io ?
                Meanwhile, please update the PX4 from sdk 1.3.0 , and you will also need to update M0065 firmware. Old M0065 firmware (V1) and old voxl2_io driver had some issues.
                • https://docs.modalai.com/voxl2-io-user-guide/#voxl-px4-configuration
                • https://docs.modalai.com/voxl2-io-firmware/
                  OK, it seems the workaround (not affecting motor output) is to set any of the VOXL2_IO_FUNCx to values 402-422, which forces the module to update at 250hz, which is enough to solve this issue without changing code. Note that this will output the value of the function to VOXL2_IO board, but if you don't have anything connected to the corresponding pwm output, it should be fine (i suggest doing something like this param set VOXL2_IO_FUNC8 408 since PWM channel 8 is rarely used anyway.
                  You could try doing the same with your old M0065 firmware (which only supports 4 channels, however), so you would set param set VOXL2_IO_FUNC4 408 . However, i strongly recommend using the latest M0065 firmware and modal2_io drivers. see changelog: https://docs.modalai.com/voxl2-io-firmware/#voxl-sdk-12x-wip
                    Jeffrey Mao
                    Oh glad to hear something from your end.
                    Currently we are using VoxlESC and the Px4 from SDK 1.1.1. Recently I flashed the board but the remote control is no longer detected. Also how do we set the parameter of the voxl2_io_func8 is this in the start up /usr/bin/voxl-px4-start?
                    Thanks again for the help,
                    Jeff
                      Jeff
                      @Jeffrey-Mao , you can use QGC to update the param or from voxl2, “px4-qshell param set VOXL2_IO_FUNC8 …..” . This is standard px4 param setting.
                      Rishabh VermaR Jeffrey MaoJ 2 Replies Last reply
                        Rishabh VermaR Offline
                        Rishabh Verma
                        @Alex-Kushleyev
                        Hey Alex, I am working with Jeffrey. I can't seem to find the VOXL2_IO_FUNCx parameters. Is it on the VOXL2_IO board or the VOXL2 main board? Because while running px4 on foreground this was not listed and its not listed even at QGC
                          Jeffrey Mao
                          @Alex-Kushleyev hi Alex thank you so much for the help. We figured it out after updating some of the firmware. It flies much smoother with the jeti RC now
                            @Jeffrey-Mao , this issue has been properly fixed, details here : https://github.com/modalai/px4-firmware/commit/636ffefcb1a96ad2b53e988d23bf6419955b69ea . The fix is in voxl-dev branch of px4-firmware and will be included in the next nightly build and thereafter.
                              @Alex-Kushleyev The fix is available in this build: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.77-202406051703_arm64.deb
