Lepton board
@Vinny
I was looking into getting a lepton camera to interface with Voxl 2.
I was looking through the forums and datasheets and needed some advice and additional details.For Leption-server
- I2C and SPI connections: Which port should we utilize for this and if the following boards can be used
https://groupgets.com/products/purethermal-micro-breakout-board
For UVC camera:
I am currently utilizing USB for wifi with M0141[USB Type A breakout board]. If I want to connect both the camera and have wifi setup how do I do it.
It is out of option for me to switch to LTE based communications. - I2C and SPI connections: Which port should we utilize for this and if the following boards can be used
@Vinny
For UVC camera:
It is out of option for me to switch to LTE based communications.@Projects-a If you go with an LTE add on module or a Microhard add on module then you can use one of the USB ports on them to attach the Lepton.
@Vinny
For UVC camera:
It is out of option for me to switch to LTE based communications.@Projects-a You can connect the i2c to the J5 connector on M0141 and spi to J10 on VOXL 2 board if you want to stay with M0141
