Automatic syncing object models across multiple VOXL2s
I'm trying to get an object-detection-model-guided drone. I am also trying to get it so that I can have an object detection model (like the MobileNet) on one VOXL2 and then be able to sync that same model onto other VOXL2s. I would like to have it so that the modifications I make to the model (weights, parameters, training data, etc), can automatically be pushed or synchronized across all the other VOXL2s I am using.
How can I do this?
I typed voxl-{TAB}{TAB} in terminal, and it seems to me like
voxl-configure-docker-support,voxl-configure-mavlink-server,voxl-configure-tflife,voxl-inspect-mavlink,voxl--mavcam-manager,voxl-mavlink-server, andvoxl-tflife-serverare the places to start, but I am not sure as I am new to this.Where should I start?
Thank you!
How can I do this?
Thank you!
@Moderator So is
voxl-tflite-serverwhat is used to communicate and transfer the model across different voxls? -
@Moderator So is
voxl-tflite-serverwhat is used to communicate and transfer the model across different voxls?@Denver-Bennett Hi Denver, no voxl-tflite-server is a TensorFlow Lite runtime environment for VOXL.
You will need to write your own code if you want to somehow mesh models together over a network. We aren't familiar with any software that handles that today
