  3. Unable to see rostopics published by mpatoros2 foxy in my humble docker container
4 Posts 3 Posters 953 Views 1 Watching
  • Darshit DesaiD Offline
    Darshit Desai
    Pretty much what the topic line says
    Gary HolmgrenG 1 Reply Last reply
      Gary HolmgrenG Offline
      Gary Holmgren
      @Darshit-Desai Hi, wondering if you were able to solve this.
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        @Darshit-Desai are your ROS_ID's the same between the docker and disk? If not how are you sharing the interfaces into the ros docker instance?
        If it is easier you can just share the /opt/ros/foxy/mpa_to_ros2 directory as a volume as well as the /run/mpa directory as a volume and run the ros2 node in the docker instance. The other thing to note is I am unsure if there is compatibility between foxy and humble in terms of the nodes or if there are some internal conflicts happening behind the scenes.
        Zach
        Darshit DesaiD 1 Reply Last reply
          Zach
          Darshit Desai
          @Zachary-Lowell-0 I am not sure how I resolved this, but as far as I remember there was px4_msgs versioning issue where I wasn't using either the correct ones or something
