Stereo camera bit rate customization?
Can you please confirm that in your 30cm extension use case you are using:
(starting from VOXL side..)- M0076 interposer
- 2x M0036 15cm flexes (connected back to back)
- M0010 stereo splitter
- 2x M0015 OV7251 cameras
Also, are the cameras being detected when using
voxl-camera-server -lbut the stream does not work? or neither detection nor streaming work?We will try to reproduce your test case first and lets go from there..
