  3. Calibration for VOXL SDK 1.1.3
3 Posts 2 Posters 414 Views 1 Watching
  • Phi NguyenP Offline
    Phi NguyenP Offline
    Phi Nguyen
    wrote on last edited by Phi Nguyen
    I did upgrade the RB5 Flight with VOXL SDK Platform 1.1.3.
    When I try to calibrate the IMU, it happend:
    rb5:/$ voxl-check-calibration
    Calibration File Status:
    Missing /data/px4/param/parameters_mag.cal
    rb5:/$ voxl-calibrate-imu
    ERROR: in json_read_file, config file is empty or unreadable
    ERROR: Malformed calibration file: /data/modalai/voxl-imu-server.cal
    Please make a new calibration file with voxl-calibrate-imu
    ERROR: Neither IMU pipe appear to be open
    Make sure the voxl-imu-server service is running and try again
    and
    voxl-imu-server | Enabled | Not Running
    After calibration with QGroundControl, I realized that the orientation was wrong, I do not exactly which orientation is, it was mentioned in this link https://docs.modalai.com/px4-calibrate-sensors/ is:
    When you click on the Compass or Accelerometer calibration buttons, QGroundControl rightly asks you to confirm the board orientation. If using the PX4 master branch or the ModalAI build 1.10 then use ROTATION_NONE. The default orientation in the parameters file you uploaded before takes this into account. NOTE: the 1.10 release from PX4 for Flight Core is not recommended as there have been fixes including a orientation change.
    what should I need to do for the first flight.
    Thank all!
    • Phi NguyenP Phi Nguyen
      and
      Thank all!
      @Phi-Nguyen The magnetometer rotation is specified directly with the magnetometer driver so you don't need to set it with that parameter. The /usr/bin/voxl-px4-start startup script will attempt to launch the magnetometer driver with the -R 10 option to specify the rotation.
        @Eric-Katzfey So you probably just need to do the magnetometer calibration procedure to be ready for flight.
