  3. QGC keeps crashing when sentinel drone is reconnected
3 Posts 2 Posters 819 Views 1 Watching
  • Dawid MościckiD Offline
    Dawid Mościcki
    Hi, Im using sentinel drone.
    When drone is connected for the first time to QGC everything works. After lost of signal and reconnection or just powering off drone then powering up QGC is crashing.
    Output :
    Settings location "/home/autonomylab/.config/QGroundControl.org/QGroundControl.ini" Is writable?: true
    Filter rules "*Log.debug=false\nGStreamerAPILog.debug=true\nqt.qml.connections=false"
    System reported locale: QLocale(English, Latin, United States) ; Name "en_US" ; Preffered (used in maps): "en-US"
    MAVLinkLogManagerLog: MAVLink logs directory: "/home/autonomylab/Documents/QGroundControl/Logs"
    Map Cache in: "/home/autonomylab/.cache/QGCMapCache300" / "qgcMapCache.db"
    qml: QGCCorePlugin(0x5559f952fc80) []
    setCurrentPlanViewSeqNum
    _recalcFlightPathSegments homePositionValid false
    "v4.3.0"
    Adding target QHostAddress("192.168.88.243") 14550
    ParameterManagerLog: Attemping load from cache
    ParameterManagerLog: Parameters cache match failed /home/autonomylab/.config/QGroundControl.org/ParamCache/1_1.v2
    QCoreApplication::postEvent: Unexpected null receiver
    VideoReceiverLog: Stop called on empty URI
    corrupted size vs. prev_size while consolidating
    Aborted (core dumped)
    In my other project this type is behavior was caused by my custom px4 module with new set of parameters. Maybe it's possible in Your software as well?
      Dawid Mościcki
      @Zachary-Lowell-0 This could be probably caused by missing sdlog_mode parameter. Maybe it was introduced in one of the commits that modified logger.cpp in src/modules/logger ?
      • Dawid MościckiD Dawid Mościcki
        @Dawid-Mościcki Perhaps you can ask the QGC development team for some help in narrowing down what is causing QGC to crash. If you think there is a missing parameter then in your /usr/bin/voxl-px4-start script add a new line to touch the parameter so that QGC will see it. (e.g. param touch SDLOG_MODE)
