  3. Motor issues when running ESC calibration
esc
108 Posts 3 Posters 65.5k Views 1 Watching
    Also, which SDK are you using? i am surprised to see this issue.
    Also, can you please double check the ESC bootup sequence:
    • apply power
    • 4 blue leds flash quickly for 1 second, then turn off
    • 4 blue leds blink twice
    • motor makes a quick chirp (three tones based on the latest params that provided)
    rdjarvisR Offline
    rdjarvisR Offline
    rdjarvis
    @Alex-Kushleyev ESC gave
    4 LEDs quickly flashing
    4 LEDs flash 3 times
    Motor chirps
    rdjarvisR Alex KushleyevA 2 Replies Last reply
    • rdjarvisR rdjarvis
      Motor chirps
      rdjarvisR Offline
      rdjarvisR Offline
      rdjarvis
        • apply power
        One more suggestion, it often helps to use a direct connection between the ESC and your linux PC and run the voxl-esc tools there. This way you can see the plots instantly during testing and also if there are some issues with communication to the ESC, you can always connect it to the PC and check the ESC that way.
        Do you have a USB to serial adapter cable that plugs into the ESC <-> PC ?
        rdjarvisR 1 Reply Last reply
          Motor chirps
          @rdjarvis said in Motor issues when running ESC calibration:
          Motor chirps
          OK that is good!
            rdjarvisR Offline
            rdjarvisR Offline
            rdjarvis
            @Alex-Kushleyev, yes we have the USB/Serial connector.
              @rdjarvis , ok great. Lets take a step back and just make sure you can talk to the ESC from the PC.
              I will test SDK 1.2.0 to make sure it works fine with voxl-esc tools with my esc.
              rdjarvisR Alexander SaundersA 2 Replies Last reply
                rdjarvisR Offline
                rdjarvisR Offline
                rdjarvis
                @Alex-Kushleyev Copy all, thank you
                  Alexander SaundersA Offline
                  Alexander Saunders
                  @Alex-Kushleyev
                  Also to confirm, I followed the README from dev branch to update.
                  • Alexander SaundersA Alexander Saunders
                    @Alex-Kushleyev
                    @Alexander-Saunders , thank you for confirming. I see that you are using SDK 1.2.0, which is very recent, so it already has (almost) the latest voxl-esc tools.
                    I am in the process of testing the tools on voxl2 using SDK 1.2.0, please try to connect to your PC directly and this should properly detect your ESC.
                      rdjarvisR Offline
                      rdjarvisR Offline
                      rdjarvis
                      @Alex-Kushleyev
                      ssh'd into Linux PC.
                      Connected to ESC with USB to SERIAL
                      voxl2:/usr/share/modalai/voxl-esc-tools/voxl-esc-scan.py
                      received same error as Windows PC.
                      No ESCs detected
                        @Alex-Kushleyev
                        No ESCs detected
                        @rdjarvis,
                        What do you mean "ssh'd into Linux PC" ?
                        I am suggesting to connect the ESC to a standalone Linux PC and run the voxl-esc-scan.py on the linux PC (not on VOXL2).
                        Just wanted to clarify..
                        I tested the SDK 1.2.0 and the tools are working fine, it seems.
                        rdjarvisR 2 Replies Last reply
                          @rdjarvis,
                          rdjarvisR Offline
                          rdjarvisR Offline
                          rdjarvis
                          @Alex-Kushleyev
                          On the Linux PC we are directly connected to 4 pin JST on ESC to USB.
                          I ssh'd into VOXL2 from the Linux PC terminal.
                          I ran voxl-esc-scan.py in VOXL2 (same results) No ESCs detected.
                          I ran same command in Linux terminal (not ssh'd into VOXL2) same results. No ESCs detected.
                          This is including running same command in /usr/share/modalai/voxl-esc-tools/.voxl-esc-scan.py
                          RDJ
                            @rdjarvis,
                            rdjarvisR Offline
                            rdjarvisR Offline
                            rdjarvis
                            @Alex-Kushleyev power is on the UAV and ESC gave proper Flashes/Tones.
                              @rdjarvis , which serial to usb cable are you using? have you tested it with an ESC before? I am wondering if the RX/TX connections are correct and not swapped.
                              Also, do you have any other Modalai ESC you can test just to make sure the cables are working?
                                rdjarvisR Offline
                                rdjarvisR Offline
                                rdjarvis
                                wrote on last edited by rdjarvis
                                #55
                                @Alex-Kushleyev
                                MCBL-00091-1
                                USB to Serial UART Cable from ModalAI
                                Both right out of the new bag.
                                We have 2 of these. Tested both. Same results.
                                  @Alex-Kushleyev
                                  MCBL-00091-1
                                  #56
                                  @rdjarvis , ok so just to clarify.. as soon as you uploaded the new params that I provided, the esc stopped communicating? Can you please check to make sure you did not modify the baud rate in the param file before uploading?
                                    rdjarvisR Offline
                                    rdjarvisR Offline
                                    rdjarvis
                                      rdjarvisR Offline
                                      rdjarvisR Offline
                                      rdjarvis
                                      @Alex-Kushleyev The params you sent worked. I tested the new motors params, with the aggressive test procedures you sent.
                                      They worked. Motors performed well and we confirmed the sinusoidal spin-up.
                                      Binded Spektrum DSMX RX/TX and calibrated through QGC.
                                      RC channels successfully calibrated in QGC.
                                      Programed switches for Flight Modes.
                                      ARM/DISARMED Motor kill all successful.
                                      Armed for maiden flight. Slowly increased throttle with no motor response.
                                      This led us to where we are now.
                                        @rdjarvis , thank you for clarifying.
                                        it seems there is some hardware issue. Can you please confirm that nothing is making contact with the ESC components, which could cause a short or something like this? Also please inspect the 4-pin UART connector on the ESC (and around it) to make sure there is no short or anything like that cause by loose debris or anything else.
                                        rdjarvisR Alexander SaundersA 4 Replies Last reply
                                          rdjarvisR Offline
                                          rdjarvisR Offline
                                          rdjarvis
                                          #60
                                          @Alex-Kushleyev
                                          We just verified all solder and JST connections on the ModalAI FPV 4n1 ESC and VOXL2.
                                          All connections are good. No shorts, no solder balls. 4 PIN USB JST connections to and from ESC and VOXL are in perfect condition and reflect no sign of wear and tear. The first time they have been disconnected for either board was for this test.
                                          Upon reconnecting, and power being applied all lights and tones are heard from ESC, and able to ssh into VOXL2 with no issues.
                                          Ran esc scan and esc detect, resulting in NO ESCs DETECTED.
