qvio ros2 topics
Hi, i would appreciate some clarification from dev team or others using qvio with ros topics
i have installed voxl-mpa-to-ros2 and noticed that the /qvio topic publish 2 different messages - one is PoseStamped interface the other odometry - i guess each hold same data and one message is just more extended than the other?
Yes you can look at it that way. Pose is just the generic positional data inclusive of the quaternion and imu wrt vio/camera - odometry is that as well as things like the twist or better known as velocity wrt to the vio instance/camera and the angular velocity wrt to the vio/camera.
Let me know if this better helps you understand - all the code is open sourced btw so feel free to take a gander for a programatic understanding:
