    How to make UVC Server running on VOXL for testing USB Camera
    VOXL Accessories
    • R
      riteshsharma
      How to make UVC Server running on VOXL for testing USB Camera? Can someone help me in running uvc server running?
      I even tried running using systemctl to start uvc server.
      configuration file:
      • This file contains configuration that's specific to voxl-uvc-server.
      • parameter descriptions:
      • width: Desired image width. (e.g. 640)
      • Default is 640.
      • height: Desired image height. (e.g. 480)
      • Default is 480.
      • height: Desired frame rate in fps (e.g. 15).
      • Default is 30.
      • pipe-name: Desired MPA pipe name in /run/mpa (e.g. webcam).
      • Default is uvc.
      "pipe_name": "uvc",
      "width": 640,
      "height": 512,
      "fps": 30,
      I am sure my usb camera is connected and I can see the device
      voxl:~$ show-video-device-info.sh
      /dev/video2: Boson 09cb:4007
      • tomT
        tom admin @riteshsharma
        @rsr4z Check out voxl-configure-uvc and it's options
        R 1 Reply Last reply Reply Quote 0
        • R
          riteshsharma @tom
          @tom I see following message when I run voxl-configure-uvc
          Since, I am using Boson, I tried voxl-configure-uvc boson and rebooted VOXL.
          Upon running voxl-inspect-services, I am still not seeing voxl-uvc-server running.
          tomT 2 Replies Last reply Reply Quote 0
          • tomT
            @rsr4z What does /etc/modalai/voxl-uvc-server.conf look like? It is weird that sed is failing I'll try to replicate.
            It appears you're using an unreleased SDK, how did you install that SDK?
            • tomT
              @rsr4z There appears to be an extra comma after 30 in "fps": 30, , that will need to be removed. It's possible this is a bug in the config script.
              You can run systemctl status voxl-uvc-server to see the status of the service if it is showing as "Not running"
              • R
                riteshsharma @tom
                @tom Yes. I removed "," from the config file and it worked. Thanks
