  3. voxl-mpa-to-ros node crashes when /uvc topic is echoed (VOXL2, version 1.1)
5 Posts 2 Posters 1.4k Views
  • Isaac Stephan RemyI Offline
    Isaac Stephan Remy
    Hey there,
    I have a Sentinel drone equipped with a VOXL2 onboard (running Ubuntu 18 + ROS Melodic). I also have a FLIR Lepton 3.5 thermal camera plugged into the VOXL2 via a USB connection. I can RTSP stream the Lepton's camera data from the VOXL2 to QGroundControl on my laptop when I run the voxl-uvc-server (with the proper parameters), but when I run the voxl_mpa_to_ros node and echo or subscribe to the /uvc topic to get the camera data, the ros node crashes with this error:
    terminate called after throwing an instance of 'std::bad_alloc'
    what(): std::bad_alloc
    [voxl_mpa_to_ros_node-2] process has died [pid 2409, exit code -6, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/5567d258-c2e7-11ee-a3cf-00c0cab38e43/voxl_mpa_to_ros_node-2.log].
    log file: /home/root/.ros/log/5567d258-c2e7-11ee-a3cf-00c0cab38e43/voxl_mpa_to_ros_node-2*.log
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      Hi @Isaac-Stephan-Remy that tends to happen when the conversion from the frame in MPA to the ros1 or 2 image is not allocated the proper amount of size. I will do some testing with a FLIR thermal camera over UVC and get back with a fix for a PR - you will need to most likely build from source for ros1.
      Also I do recommend swapping over to ROS2 FOXY on the voxl2 as it is more supported and ROS1 is at EOL.
      Zach
      Isaac Stephan RemyI 1 Reply Last reply
        Zach
        Isaac Stephan Remy
        Hi @Zachary-Lowell-0,
        Thanks for the support! Will the PR be available over GitHub? I will look into ROS2 in the meantime.
          Zachary Lowell 0
          Yes it will be available on the gitlab under a new branch most likely by EOD tomorrow. I wll post the branch that you can build from source - once approved it iwll be merged into the next stable release, etc.
            Zachary Lowell 0
            @Isaac-Stephan-Remy please pull down the most recent iteration of https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/tree/dev and build within the qrb5165 docker image and deploy the deb. This will allow you to convert UVC 422/UYVY images from the MPA to ros2. In the meantime I am working on the fix for ros1 as well.
            Zach
            • Isaac Stephan RemyI Isaac Stephan Remy referenced this topic on
